CNC PCB mill...
2017-08-13 by Peter Tremewen
Archive for Homebrew_PCBs.
2017-08-13 by Bertho
Peter,
I do not think that is cost-effective today.
Your time and effort plus the cost of a good CNC engraver is significant.
Regardless, the result is not great: No through holes, no soldermask, limited resolution, not practical way to clear large areas.
Today PCB cost and turnaround time is very good.
Bertho
Sent: Sunday, August 13, 2017 11:04
Subject: [Homebrew_PCBs] CNC PCB mill...
Hi All,
I am considering buying a CNC engraver to manufacture protype PCBs on..
Just wondering What experiance everyone has with this...
Any information greatly apreciated..
Thanks in advance,
Peter T.
2017-08-13 by Boots Hughston
On Aug 13, 2017, at 8:03 AM, Peter Tremewen Ptremewe@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Hi All,
Thanks in advance,
Peter T.
2017-08-13 by Art Eckstein
Hi All,
Thanks in advance,
Peter T.
2017-08-20 by Peter Tremewen
2017-08-27 by Technotronic~Dimensions
2017-08-27 by roylowenthal@...
2017-08-27 by Harvey Altstadter
Steve,
This is Liquid Crystal Thermography. Find a detailed paper here: www.srmuniv.ac.in/sites/default/files/files/SpecialimagingTech.pdf or just Google Liquid crystal thermography, and find out more than you ever want to know.
In a previous life, my Failure Analysis lab used them to locate microscopic shorts in semiconductor devices. The ones we used had a very short temperature range under which they would show color, otherwise they were clear. We used them with a black coating between them and the device we were examining, so that we could see the colors. I think the entire range that they would show color was approximately 5°C, with different materials for different temperatures.
Harvey
Saw some videos on what looks like an LCD type of chemical that changes
color with temperature.
Im looking to experiment with some chemicals that change color with
temperature, sort of like
a thermometer read by color instead of numbers.
Any ideas or sugguestions out there? I remember a couple of people here
seemed very good with
knowledge of chemicals. I happened to skip chemistry class in high school -
hehe.
Steve Hearns
Technotronic Dimensions, VT [USA]
WWW.TECHNOTRONIC-DIMENSIONS.COM
1.518.663.3421 (MAIN)
1-877-817-9885 (Voice / Fax Toll Free - US Only)
E-Mail: Steve@...
Webmaster, Parts-Link: (http://www.parts-link.com)
Group Moderator:
TV-Repair (http://groups.yahoo.com/group/tv-repair)
Monitor-Repair (http://groups.yahoo.com/group/monitor-repair)
2017-08-27 by keith printy
I used to have one. I remember 2 digits showing but if you knew how you could accurately read it.as I recall it was green when it was exactly that temperature and would turn more brownish below that temperature,above that temperature it was more bluish.by which numbers were lit you could figure out within about a degree what the temperature was.
Also had a replica of a galileo thermometer with the floating spheres inside, this wasn’t very accurate the lcd was much closer.
Sent: Saturday, August 26, 2017 10:43 PM
Subject: [Homebrew_PCBs] Re: Chemical question
Probably a liquid crystal thermometer - they were sort of popular a few years ago, I haven't seen one in a while. From what I remember, their main problem was that they didn't jump discretely from one temperature reading to another - there were usually 2 different numbers showing at the same time.
Roy
2017-08-27 by Dennis Shelgren
On Aug 27, 2017 8:05 AM, "'keith printy' keethpr@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com> wrote:I used to have one. I remember 2 digits showing but if you knew how you could accurately read it.as I recall it was green when it was exactly that temperature and would turn more brownish below that temperature,above that temperature it was more bluish.by which numbers were lit you could figure out within about a degree what the temperature was.
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@ yahoogroups.com]
Roy
From: "Dennis Shelgren nojoeco@... [Homebrew_PCBs]"
Sent: Sunday, August 27, 2017 11:28 AM
Subject: RE: [Homebrew_PCBs] Re: Chemical question
Long ago I worked at Intel in "package, noise, and thermal". We had a bunch
of companies demo their individual products for finding hot spots, shorts,
etc.
One of the companies had a liquid crystal system. There were different ways
to apply it, and it was actually pretty neat to use. Of course the quicker
the process and more temperature zones we needed the more expensive it got.
For the boards we were working with, we actually had to "paint" it in
zones, i.e. broad temperature over most of the board, high temperature on 3
chips, and then some sensitive formula where needed.
Although it was cheaper than a thermal camera up front, we had to do a ton
of prep work each board. Afterward we had to photograph the board and
annotate the photos with the zones, temperatures, etc.
The sampler kit was something around $500, and it was composed of 75%
consumables.
After adding up all the prep time, unknown amounts of replacement "paint",
margin of error on thickness, and of course the occaisional need to replace
a chip on a coated board, it ended up being cheaper to get a $10-15k
thermal camera.
Nowadays, there are low res thermal cameras that snap onto a cell phone
starting at a couple hundred bucks. The software has only gotten better
over the years as well.
> *From:* Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@
> yahoogroups.com]
> *Sent:* Saturday, August 26, 2017 10:43 PM
> *To:* Homebrew_PCBs@yahoogroups.com
> *Subject:* [Homebrew_PCBs] Re: Chemical question
> time.
> < https://en.wikipedia.org/wiki/Liquid_crystal_thermometer >
> Roy
Steve,
There are two different types of temperature indicating "paints."
The type we have been discussing is part of a class of liquid
crystal materials that are reversible. In other words, when ever
you reach their temperature sensitivity range, they change color.
Outside that range they are clear or black. You can do this over
and over. As pointed out by Dennis, these materials are quite
expensive. The other type is a material that is available as a
paint or a waxy stick or as a stick on label. This material is
applied as a small drop that has a particular color. When it's
temperature range is exceeded, it undergoes a physical change,
such as changing from dull to glossy. This is frequently used to
determine if a piece of equipment has been subjected to excessive
temperatures. This is a one shot deal. Manufacturer website:
http://www.tempil.com/
Interesting.
So there is some kind of paint that I guess u can put on something,
and its color reflects the temperature of what its painted on?
Steve Hearns
E-Mail: Steve@...
Group Moderator:
etc.
consumables.
thermal camera.
> yahoogroups.com]
> time.
> Roy
