White TRF Clearcoat
2017-08-09 by alan00463@...
Archive for Homebrew_PCBs.
2017-08-10 by keith printy
What about using clear krylon spray ? it applies like paint but puts a clear plastic coating on whatever you spray it.
Sent: Wednesday, August 09, 2017 4:57 PM
Subject: [Homebrew_PCBs] White TRF Clearcoat
I am about to order White toner reactive foil to use as silkscreen (component outline). I was thinking about clearcoating the white-outlined component outlines (or black, depending on the fiberglass
color) with clear nail polish. Has anybody tried this already?
2017-08-10 by Harvey White
>What about using clear krylon spray ? it applies like paint but puts a clear plastic coating on whatever you spray it.Wouldn't covering the exposed pads be a problem?
2017-08-10 by duwaynes@...
I would think the coating is thin enough to just solder right through it. I’ve dealt with boards with a coating like that and was able to solder through
Sent: Wednesday, August 09, 2017 10:11 PM
Subject: Re: [Homebrew_PCBs] White TRF Clearcoat
2017-08-10 by alan00463@...
>Thank you for your comments.It depends on the board and which layers you use to print the silk
>Well, Harvey, covering the pads would be an issue for a SMT board, yes. That is what made me think of using nail polish---it already has a very small brush so you can overcoat the artwork while avoiding the pads. I don't think artwork would ever overlap a pad.
>You can, and I don't see a problem with either nail polish or krylon
>Now I don't know how durable nail polish is compared to Krylon. I simply thought you might be able to apply it to the top side of a THT board without having to mask the board with masking tape.
>I suppose I ought test these coatings to see which coating is more durable for this application. Maybe apply toner to a bare rectangular board divided into four quadrants by a vertical bisecting line and a horizontal bisecting line. 4 identical quadrants laminated with lettering denser than on the average board. I could coat quadrant I with cheap clear nail polish, quadrant II with expensive clear nail polish, quadrant III with Krylon, .....what about quadrant IV ?I think you'll have an interesting experiment, but not one that's
>Sounds about right, or perhaps a wire brush for the ultimate torture
>I'd need to invent some kind of flagrum for beating the board surface equally in all four quadrants in order to scratch it. Just to see which of the coatings is most resistant to scratching that might occur (while populating the board). I suppose I could use some kind of pegboard with through-hole resistor leads epoxied into the holes and sticking out a few mm.
>Hmmm....
>This 4-quadrant test might also reveal if any of the coatings change
>the reflectivity of the board--for example, making it glossy where you
>apply the coating and matte where you don't--making it look weird.
>Am thinking scratching the board surface is most likely when:
>* inserting metal screws into the four holes in the board's corners
>* inserting the leads of TH components when populating the board.
>* accidentally dropping something onto the board
>Am I missing something important?
