Homebrew_PCBs
Archive for Homebrew_PCBs.
Silkscreening with white toner
2017-06-02 by Brad
I finally got some white toner and made my first silkscreen!  I didn’t try to hard (the board was scrap), but the results are encouraging.  I’ve made a post on my blog here for those who like me just have to have a white silkscreen on their boards:
http://bradhodge.ca/blog/?p=1026
Re: Silkscreening with white toner
2017-06-03 by AncelB
Well, u can silk screen with regular toner, and then do a craft foiling
transfer pass with any type of color foil you prefer. Gets u
professional looking metallic labeling if u want.
RE: [Homebrew_PCBs] Re: Silkscreening with white toner
2017-06-03 by Brad
Yeah I tried that but never had much success with it.  Plus, if I can dial this in a bit better it’s one less step, one less thing to go wrong, right?
Sent: Friday, June 2, 2017 6:40 PM
Subject: [Homebrew_PCBs] Re: Silkscreening with white toner
Virus-free. www.avg.com
2017-06-03 by Marc OLANIE
Hi Ancel & all
>…. and then do a craft foiling
Could you pse give a reference or URL of such a « craft foiling » stuff ? I’m still looking for such material
Many thks
Mark
2017-06-04 by Marc OLANIE
Thank you, Ancel.
These foils have metallic particles. Unusable or risky for UHF and/or high voltage pcb. Just good enough for CC apps and arlui-like applications
I was looking for something more neutral.
Tnks agn
Marc
De : Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
Envoyé : dimanche 4 juin 2017 05:53
À : Homebrew_PCBs@yahoogroups.com
Objet : [Homebrew_PCBs] Re: Silkscreening with white toner
Craft foil for toner transfer: EBay item # 160937797413
2017-06-04 by Brad
I don’t know why but I couldn’t make the TRF work.  It always ended up lifting the toner from the board.  The rare spots where it adhered it looked awful.  I tried the recommended settings for an iron *and* their recommended laminator but no dice.  Just wouldn’t work.
I’ve been doing more experiments with the white toner and the results are pretty good.. I think this is much preferable to a process with additional steps.  The cart will do 2000 ‘pages’.. for $115.. that’s not bad..
Sent: Sunday, June 4, 2017 1:20 AM
Subject: RE: [Homebrew_PCBs] Re: Silkscreening with white toner
Get white trf instead as it is made for that application. I can supply a link to both green trf and white trf thru a site I buy from.
Virus-free. www.avast.com
2017-06-05 by AncelB
I have used the purple metallic foil up to 1Ghz on 0.8mm FR4 with no
probs....No apparent effect on permittivity etc.
2017-06-05 by Marc OLANIE
That's an important info :-)
just a last stupid question : did you try to use it to minimize toner porosity?  In other words,  does it resist to acid ?  (replacing some kind of "green trf" foil)
Marc
De : Homebrew_PCBs@yahoogroups.com <Homebrew_PCBs@yahoogroups.com> de la part de AncelB mosaicmerc@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com>
Envoyé : lundi 5 juin 2017 03:28:16
2017-06-05 by Dennis Shelgren
Just my two cents. White toner is probably the most direct route. Back in the late 90's alps wax printers could do decals that'd be fairly close to perfect. But there's been no new machines that work that way unless you look at "pro" machines. Hopefully some fellow maker out there will make a new version of the old alps.
On Jun 4, 2017 8:16 PM, "Marc OLANIE Marc.olanie@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com> wrote:
Marc
De : Homebrew_PCBs@yahoogroups.com <Homebrew_PCBs@yahoogroups.com > de la part de AncelB mosaicmerc@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com >
2017-06-05 by alan00463@...
Well I'm planning to do black silkscreen using Ed Chew's method
https://www.youtube.com/watch?v=GL0fVtREgRA   on the component
side of a TH board.     My idea is white is best for silkscreen, black
silkscreen is better than no silkscreen.
Kevin Byrne, when you figure out how to make white silkscreen using the toner reactive foil, let us know how you did it.    I'll be happy to switch to white silkscreen.
Re: [Homebrew_PCBs] Re: Silkscreening with white toner
2017-06-05 by Harvey White
>https://www.youtube.com/watch?v=GL0fVtREgRA https://www.youtube.com/watch?v=GL0fVtREgRA on the component
Take the silkscreen layer for the board (should not cover pads).
Reverse it and print it on paper, then laminate or iron it on the
board (whichever works for you).
Take the white toner foil put it over the board and laminate it. I
generally use at least two passes and at the highest temperature. You
might want to experiment with how many passes on a few board scraps,
although it can be removed with acetone.
Pull off the foil. You will notice that the foil pigment is thicker
and lumps up a bit, or comes off the board leaving large clumps. Those
clumps are just bare toner and are not attached.
Use either scotch tape or cheap (you don't want strong adhesive) tape
turned sticky side down to blot up the extra scraps. This should
leave the pattern behind and remove the scraps. Do this lightly. You
could remove the toner.
Harvey
2017-06-10 by AncelB
Craft foil for foiling toner on PCBs, to either remove any pitting when
etching the fills on the solder layer or for quality silk screening on
the component layer: Ebay item # 160937797413
2017-06-20 by dougholberg@...
Per your suggestion, I bought some.  Tried it today and it worked just great!  The stuff is so thin, it is tricky to get it to lay perfectly flat on the board as it goes through the laminator.  However, on my first try, I only had a couple of tiny wrinkles.  Still the board came out great.  I got one roll of 10ft and it will probably last forever.
2017-06-20 by Harvey White
try cutting it to size, then smoothing it down so it without wrinkles.
This can cause a static charge that helps hold the foil to the board.
Run it through the laminator and it might help.
Harvey
Good idea.  Another thing i am gonna try is to roll it over the end of the board and tape with Kapton and then hold some tension on it as it goes through.  Pretty impressive stuff.
