I am milling PCBs. I am using Flatcam to produce the gcode and autoleveller to "level" the code. Over all it does a great job. But I am noticing what looks like "threads" of copper in between the traces. Typically the "threads" hug the traces. I can remove them easy enough with a scribe but the process can be tedious.
I am using a 30deg etching bit .1mm. I set flatcam so it overlaps 22% and I am cutting 3 bit widths.
Well tried on the remaining bits of the board I was cleaning up and a brush didn't seem to help at all. Of course they were the most stubborn of the threads. I will try the brush right away next time.
Copper is notorious for its difficult machining characteristics. It has a tendency to be 'gummy' and 'catch the cutting tool. Careful selection of tool feed and speed go a long way to reduce those tendencies. A very sharp tool helps as well. As mentioned a brass brush to break off the tendrils wirks.
Wrong, use another two words: abrasive rubber (eraser with glass
powder inserts).
Specially produced to clean the PCBs.
See Farnell UK #141330 and #4208596, under the name of
ERASER/CLEANER BLOCK.
