Homebrew_PCBs
Archive for Homebrew_PCBs.
Printer
Printer
2017-02-01 by lists
I'm asking this on behalf of a friend
I make my own PCBs by a 'photo' process, which involves printing a
transparency from the PCB artwork I've created. Just plain black/clear.
This used to work perfectly when I first did it in the '90s. Using an
Epson Stylus printer - long since gone. The next printer - a Canon - was
just about OK, but that's gone now too.
I've now got an Epson XP-415 which simply doesn't print a dense enough
black - despite playing with all the settings.
I've kept some of those old transparencies from the older printers, and
you can clearly see the difference holding them up to the light.
I've also got a cheap mono laser printer - and that if anything is worse.
Can anyone recommend a printer I can buy new and they know will work
properly for this task?
Stuart Winsor
Tools With A Mission
sending tools across the world
http://www.twam.co.uk/
Re: [Homebrew_PCBs] Printer
2017-02-01 by Roland Harriston
Hi Stuart:
I had essentially the same problem using a cheap HP Inkjet printer.
My solution was to print my PCB images (artwork) on a good grade of
tracing paper.
I make two (yes two) copies. The copies will be exact images of each other.
Then, I overlay one copy over another. I can get perfect registration
between
the two identical copies.
This technique increases (doubles) the black density of the inkjet ink.
I then use photoresist coated copper-clad PCB stock and conventional
expose-develop-etch.
I etch with muriatic acid/peroxide solution.
Works good for me.
Roland F. Harriston
2017-02-01 by Jens Tunare
Hi Stuart,
I have made PCBs with transparencies for many years.
20 years ago I made the transparencies with an HP color laser printer
with good results.
Then when replacing the old color laser printer with a new eco black/white
laser printer the black areas were not completely black anymore. I tried
several different laser printer with similar result.
I then tried an ink jet printer which had higher resolution. The critical part is the transparencies used.
I tried several different before
During the last years I have used a Canon IX6550 ink jet printer and transparencies from
Mega Electronics LTD in UK. It is JetStar Inkjet Premium Artwork Film, order no 100-075.
This film gives a very good quality transparencies which I use for smd/microwave PCBs
Jens Tunare
2017-02-01 by Steve B.
I use the HP Laserjet 2300n printer with the yellow paper/heat transfer stuff and the black seems very dense to me.
These have a good toner density setting (via menu) on them.
They are available used from a bunch of sources. If you get one, use the factory HP toner cartridge for best results.
-Steve
On Wed, Feb 1, 2017 at 8:57 AM, lists Stuartlists@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Stuart Winsor
2017-02-02 by Russell Shaw
I'm using the gutenprint driver in linux and can get high ink density on an
epson Artisan 1430.
Some types of settings can override each other preventing high density if you
don't do it right.
Re: Printer
2017-02-02 by craigl2@...
Use your laser printer to make transparencies.
When I was trying toner transfer to make PCBs I bought some "Green TRF" from the "PCB Fab - in a - Box" site.  It is used to further  protect the toner while etching the board. I also bought some "Black TRF" and some "White TRF" to use in making labels. They apparently no longer sell the black.
I have used the "Black TRF" on laser transparencies to make a negative. It gives blacker areas than any inkjet or laser toner could ever possibly do. You can run it through any laminator, even a cheap $20 one, It does not need to be one capable of handling PCBs.
The foil is available in many colors from various sources including Amazon and eBay. Search for "reactive foil". One widely available brand seems to be "Heidi Swapp Minc Reactive Foil". Probably any color would work although the pigment colors may work better than metallic colors. One comment on Amazon about the black foil in particular said it was flimsier than the others and harder to use. Any tiny pin holes can be touched up with a Sharpie or other fine tip pen.
Craig
Re: [Homebrew_PCBs] Re: Printer
2017-02-02 by Rob
Cheap TRF experiment:
http://www.learnmorsecode.com/laminator/trf/index.html
Craig
Re: Printer
2017-02-02 by Kamen Lilov
Here is my setup:
* LaserJet 2100 - bought this refurb for about $80, including refilled cartridge
* LaserJer has ethernet module (otherwise it's LPT only, difficult to drive in this day and age)
* Drafting paper
* Set the density to 5 (default is 3, tried to do this via the new Universal Printer driver and failed, then did it by sending the specific escape codes via lpr to the network port where I have attached it)
I used to print two copies on the drafting paper and align and glue them perfectly. Worked well. Then I read about and bought a toner density spray. It's technically designed for transparencies, but works very well with the drafting printouts too.
I now only use only one copy. Blackness is perfect, going down to 12 mil traces every time and under than (e.g. for 0.65mm smd parts) with some care.
The critical part of my process now is getting a uniform thick coating (I use Positiv 20 on bare stock). Exposure and black opacity is no longer causing any troubles.
Re: Printer
2017-02-02 by Kevin Byrne
I know how to accomplish all that is talked about using  my printer a HP Lasarjet P2015dn but have one question if I may. Does anybody know of a tutorial for silkscreen
after green trf is done in my new Apache AL13p?
2017-02-02 by Harvey Altstadter
I did a search on toner density spray, to see what it is. From several sites that I found, unsurprisingly, that it appears to be a combination of solvents like toluene and acetone. Further research brought me to this thread:
http://www.ar15.com/forums/t_10_22/675026_Enhancing_the_contrast__density__of_laser_generated__toner__PCB_transparency_artwork_w__acetone.html
After reading it, it reminds me of two other activities that have been discussed on this forum. The first is the "setting" of the toner on Mark Lerman's direct laser print to the board, where he suspends the board over acetone to let the fumes reflow the toner, and the second is the cold toner transfer process that was discussed a while back. This also used acetone with denatured alcohol.
The thread describes various way to reflow the toner, but in  the end, they are variations of getting a small amount of solvent onto the surface, and letting it reflow the toner before evaporating. This thread brings us full circle to our other activities, that show that acetone, and possibly, some other solvents have the capability to improve the toner coverage in several different approaches to making PCBs.
Other items of interest in the thread have to do with testing printers and scanners for resolution. Some nice, detailed instructions.
Harvey
On 2/2/2017 2:58 AM, Kamen Lilov kamenl@... [Homebrew_PCBs] wrote:
Here is my setup:
* Drafting paper
Re: [Homebrew_PCBs] Re: Printer Is ACETONE a carcinogen
2017-02-02 by Rob
I was told by a 70 year old chemistry teacher that I should avoid using  ACETONE  because ACETONE is definitely a bad ass carcinogen.
any ideas here?
I always wear nitril gloves and run a low speed fan over the work for air flow when I do kitchen etching.
On 02/02/2017 11:59 AM, Harvey Altstadter hrconsult@... [Homebrew_PCBs] wrote:
Harvey
Here is my setup:
* Drafting paper
2017-02-02 by Al Moyle
Acetone is the main ingredient in fingernail polish remover.
On Thu, Feb 2, 2017 at 1:26 PM, Rob roomberg@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
any ideas here?
http://www.ar15.com/forums/t_ 10_22/675026_Enhancing_the_ contrast__density__of_laser_ generated__toner__PCB_ transparency_artwork_w__ acetone.html
Harvey
Here is my setup:
* Drafting paper
2017-02-02 by Stefan Trethan
No, acetone is not a carcinogen.
It is similar to ethanol in toxicity, your liver can break down small quantities.
ST
On Thu, Feb 2, 2017 at 7:26 PM, Rob roomberg@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
any ideas here?
Harvey
Here is my setup:
* Drafting paper
2017-02-02 by John Marshall
Rob,
I have found it useful to search the web for creditable, authoritative sources for questions like this. Wikipedia may not always fit those criteria, but it's a starting point:
< https://en.wikipedia.org/wiki/Acetone >
Here's one with a bit more depth, a link to a document from the US CDC, "Toxicological Profile for Acetone" (276 pages!):
< https://www.atsdr.cdc.gov/toxprofiles/tp21.pdf >
Quoting paragraph 2.2.1.8 Cancer:
"In a retrospective mortality study of 948 employees (697 men, 251 women) of a cellulose fiber plant where acetone was used as the only solvent, no significant excess risk of death from any cause, including malignant neoplasm, was found when compared with rates for the U.S. general population (Ott et al. 1983a, 1983b). The workers had been employed at the plant for at least 3 months to 23 years. Industrial hygiene surveys found that median time-weighted-average acetone concentrations were 380, 770, and 1,070 ppm, based on job categories."
Hope that helps,
John, KU4AF
Pittsboro, NC
> any ideas here?
I am always blown away when I go into the Nail parlor that my wife goes to. The smell of acetone in overpowering. It doesn't seem to bother anyone that they are inhaling the stuff. I use it, but only in a well ventilated area, and always keep it covered.
At one time, acetone was blamed for things that apparently were not true. It is shown as having low toxicity: https://en.wikipedia.org/wiki/Acetone
Just remember not to mix hydrogen peroxide and acetone together when you discard fluids, they form Acetone Peroxide which is extremely unstable and dangerous.
Harvey
On 2/2/2017 12:04 PM, Stefan Trethan stefan_trethan@... [Homebrew_PCBs] wrote:
ST
any ideas here?
Harvey
Here is my setup:
* Drafting paper
2017-02-02 by David Martin
wow, what would you mix it with during the cocktail hour !!  hi hi
David Martin - NA1MH - Mountain Home, Ar. -----------------------------------------
ST
any ideas here?
Harvey
Here is my setup:
* Drafting paper
RE: [Homebrew_PCBs] Re: Printer Is ACETONE a carcinogen
2017-02-02 by keith printy
Tolulene is bad. Kids used to get high off it sniffing glue. I’ve heard it can cause brain damage.
Sent: Thursday, February 02, 2017 4:22 PM
Subject: Re: [Homebrew_PCBs] Re: Printer Is ACETONE a carcinogen
ST
any ideas here?
Harvey
Here is my setup:
* Drafting paper
Another chemical used in nail salons is ethylmethacrylate  this one smells nasty and only a couple drops will stink up a room pretty good. It is used in the acrylic nails .
Sent: Thursday, February 02, 2017 3:32 PM
Harvey
ST
any ideas here?
Harvey
Here is my setup:
* Drafting paper
The main thing with acetone is how volatile it is. There is a UL flammability scale with 1 being most flammable and 10 being the least .
Gasoline comes in at 6   acetone at 1
Sent: Thursday, February 02, 2017 1:26 PM
any ideas here?
Harvey
Here is my setup:
* Drafting paper
2017-02-03 by Rob
thank you
On 02/02/2017 02:04 PM, Stefan Trethan stefan_trethan@... [Homebrew_PCBs] wrote:
ST
any ideas here?
Harvey
Here is my setup:
* Drafting paper
2017-02-03 by Brad Thompson
On 2/2/2017 3:32 PM, Harvey Altstadter hrconsult@... [Homebrew_PCBs]
<snip>
Hello--
nail parlor workers are indeed exposed to a variety of chemical hazards:
https://www.osha.gov/SLTC/nailsalons/
https://www.osha.gov/SLTC/nailsalons/chemicalhazards.html
(In looking over the list, I noted "Quaternary ammonium compounds"--
one of these chemicals used in a room humidifier bacteriostat solution
sent me to the hospital with an anaphylactic-shock reaction. Very
scary!)
73--
Brad AA1IP
2017-02-03 by Donald H Locker
"Quats" are also common constituents of anti-bacterial soaps. Nasty stuff. They do kill 99.9% of the germs, but the 0.1% (thousands) left behind are the ones that aren't affected. Super-bugs. Evolution in action.
Donald.
> From: "Brad Thompson brad.thompson@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
> Sent: Thursday, February 2, 2017 8:59:44 PM
> <snip>
> Hello--
> scary!)
> 73--
> Brad AA1IP
> Posted by: Brad Thompson <brad.thompson@...>
> Yahoo Groups Links
2017-02-03 by Stefan Trethan
Most solvents are not good for you.
The cheap widely used solvents derived from crude oil are pretty bad, paint thinner, brake cleaner, petrol, etc. These should only be used with good ventilation, but who is willing to do this in winter...
I find it most useful to stock the following relatively benign solvents for electronics work and general fooling around in the shop:
Ethanol (denatured): Mild solvent that does not attack any plastics (European denaturing agent). I have no use for Isopropyl alcohol (rubbing alcohol), but in the US where you can not always get clean denatured ethanol it is a good alternative.
Acetone: Stronger solvent, does attack some plastics (styrene based, etc..). Will make plastic (HDPE) bottles brittle after some years.
Ethyl acetate: Somewhere in the middle, useful for cleaning PCB flux residue with best visual appearance.
ST
On Fri, Feb 3, 2017 at 12:27 AM, 'keith printy' keethpr@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@ yahoogroups.com]
David Martin - NA1MH - Mountain Home, Ar. ------------------------------ -----------
ST
On Thu, Feb 2, 2017 at 7:26 PM, Rob roomberg@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com > wrote:
any ideas here?
Harvey
Here is my setup:
* Drafting paper
2017-02-03 by alan00463@...
I asked my sister about acetone.   She uses it everyday at the beauty shop where she works, doing fingernails, pedicures, hairstyling.    She said they don't have ventilators where it is used.   So I guess acetone is NOT known to be a carcinogen.
But remember what Keith said.    Keep your acetone in a sealed airtight container just to make sure your house doesn't catch fire when you aren't home.
2017-02-03 by Tom Crawford
Usually a good idea to read the MSDS document for any chemical safety information.  Search with google for "msds acetone", and you will find lots of them.
In the summary section of the MSDS document, you will find the available Carcinogen assessment references for the chemical, if there are any.  This will probably cause you do more google searches (unless you are a chemist or industrial hygenist).  for Acetone, the assessment according to the ACGIH group is an "A4", which means "not considered carcinogenic to humans or animals".  Different chemical companies will write their MSDS documents with slightly different references, so you may want to reference a few of them, to get a better perspective.
Acetone may not be carcinogenic, but has lots of other health risks; you may want to read the MSDS in it's entirety (they usually run about  4 - 10 pages, in my experience), to get an understanding of what all the other toxic and acute health risks are, if you plan to use it...
fyi,
Tom
PS  Any other questions ("... what is an MSDS?" ), remember, google is your friend.  T.
This email has been checked for viruses by Avast antivirus software.
www.avast.com
2017-02-04 by sjlane60@...
Stephen Lane wrote:
     Wow what a long thread - I tend to agree with ST all solvents are not good as to how bad I refer to the MSDS's tho I would point out that Ethanol causes crazing on Perspex (Acrylic Plastic) it ususally takes a while but one exposure to it is all it needs.
    Anyway my 2c is use the MSDS''s they are changing all the time so keep them up to date.
Regards
Stephen
2017-02-04 by Stefan Trethan
It may depend on denaturing agents as well as the particular acrylic grade.
Personally I wouldn't hesitate to clean acrylic with denatured ethanol, since I have never observed this, but you are not the only one saying it has this effect.
You are right about the MSDS changing, I fully expect with the new US administration even cyanide will be certified safe for use as a food additive.
Also watch out where you expose yourself to those chemicals, some are apparently only dangerous if you are in the state of California. ;-)
To return to reality, as others have mentioned it is a good idea to look at several different MSDS. They change as scientific understanding of the health effects changes.
ST
On Sat, Feb 4, 2017 at 2:23 PM, sjlane60@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Regards
Stephen
2017-02-04 by Norm Stewart
On 2/4/2017 6:20 AM, Stefan Trethan stefan_trethan@... [Homebrew_PCBs] wrote:
Depend on what you use the acrylic for.  MANY years ago (1970 or so) at the Lawrence Radiation Lab, we used a pair of massive acrylic beams  (2" thick, 24" wide, 10ft long) to support a 3MV Cockroft -Walton generator.  Wiped them down with alky before sealing them in the HV pressure vessel, then had to replace the entire assembly because of stress cracks.  If it's not a structural element, you're probably safe.
Norm
OK Norm, I _would_ now hesitate in this or any similar application. ;-)
I'm sure you had the proper clean stuff too, not some cheap fuel alcohol.
ST
On Sat, Feb 4, 2017 at 7:20 PM, Norm Stewart w6nim@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Norm
2017-02-04 by Steve Wright
Acetoneis not carcinogenic. It is liable to cause respiratory irritation and in higher concentrations will cause nausea, sluggish behavior and possibly drowsiness. Prolonged exposure may be toxic to the Liver over time.
Try mixing equal parts of Bromine and Acetone and it will cause breathing difficultues and affect the eyes - tear gas!
Steve EI5DD
Go mbeith an fórsa leat
On 4 February 2017 at 19:14, Stefan Trethan stefan_trethan@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com > wrote:
ST
On Sat, Feb 4, 2017 at 7:20 PM, Norm Stewart w6nim@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com > wrote:
Norm
