What is the proper way to wire a 3 wire synchronous motor
2017-01-04 by Rob
Archive for Homebrew_PCBs.
2017-01-04 by Rob
2017-01-04 by K5ESS
Check this out
https://www.youtube.com/watch?v=C11NeRSxPD4
Mike N.
Sent: Wednesday, January 04, 2017 9:14 AM
Subject: [Homebrew_PCBs] What is the proper way to wire a 3 wire synchronous motor
What is the proper way to wire an AC 3 wire synchronous motor?
There is a wire diagram on this picture but it does not help me.
http://www.learnmorsecode.com/laminator/syncmotor.jpg
Do all 3 need to be attached to make it go clock wise?
counter clockwise?
Which wire is neutral?
Which wire is is hot?
2017-01-04 by Harvey Altstadter
Rob,
I think this is what you are looking for:
counter clockwise?
2017-01-04 by Rob
Rob,
I think this is what you are looking for: https://www.youtube.com/watch?v=C11NeRSxPD4
Harvey
counter clockwise?
2017-01-04 by Rob
counter clockwise?
2017-01-04 by Jim Pruitt
On Wed, Jan 4, 2017 at 9:34 AM, Rob roomberg@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:Thanks Mike and Harvey.
Thats the one.
On 01/04/2017 11:25 AM, Harvey Altstadter hrconsult@... [Homebrew_PCBs] wrote:
Rob,
I think this is what you are looking for: https://www.youtube.com/watch? v=C11NeRSxPD4
Harvey
http://www.learnmorsecode.com/ laminator/syncmotor.jpg
counter clockwise?
2017-01-04 by keith printy
Since there appears to be a capacitor present the motor in the picture is wired correctly. If there were no capacitor it would not run.
Sent: Wednesday, January 04, 2017 12:34 PM
Subject: Re: [Homebrew_PCBs] What is the proper way to wire a 3 wire synchronous motor
Thats the one.
Rob,
Harvey
counter clockwise?
2017-01-05 by Rob
Thats the one.On 01/04/2017 11:25 AM, Harvey Altstadter hrconsult@... [Homebrew_PCBs] wrote:
Rob,
Harvey
Wh at is the proper way to wire an AC 3 wire synchronous motor?
counter clockwise?
2017-01-05 by K5ESS
The motor is built with a number of magnetic poles arranged around the stationary part of the motor (the stator) alternate poles are wound with the two different windings. By connecting a capacitor in series with one of the windings (which results in a phase shift across that winding) you get a rotating magnetic field within the motor. The permanent magnet rotor aligns itself with that field and rotates to keep in alignment. The direction of rotation of the rotating magnetic field depends on which of the two windings the capacitor is connected in series with.
Mike N
Sent: Wednesday, January 04, 2017 6:40 PM
What is the purpose of the 0.15uF capacitor?
I find the next size smaller shows it also in this picture:
http://www.learnmorsecode.com/laminator/sync5.jpg
Rob,
Harvey
counter clockwise?
2017-01-05 by KeepIt SimpleStupid
Since there appears to be a capacitor present the motor in the picture is wired correctly. If there were no capacitor it would not run.From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
Subject: Re: [Homebrew_PCBs] What is the proper way to wire a 3 wire synchronous motorThanks Mike and Harvey.
Thats the one.On 01/04/2017 11:25 AM, Harvey Altstadter hrconsult@... [Homebrew_PCBs] wrote:Rob,I think this is what you are looking for: https://www.youtube.com/watch?v=C11NeRSxPD4HarveyOn 1/4/2017 8:14 AM, Rob roomberg@... [Homebrew_PCBs] wrote:Wh at is the proper way to wire an AC 3 wire synchronous motor?
counter clockwise?
2017-01-06 by Donald H Locker
> From: "Rob roomberg@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com>
> Sent: Wednesday, January 4, 2017 7:40:13 PM
> > *From:*Homebrew_PCBs@yahoogroups.com
> > *Sent:* Wednesday, January 04, 2017 12:34 PM
> > *To:* Homebrew_PCBs@yahoogroups.com
> > *Subject:* Re: [Homebrew_PCBs] What is the proper way to wire a 3 wire
> > synchronous motor
> > Thats the one.
> > <mailto:hrconsult@...> [Homebrew_PCBs] wrote:
> > Rob,
> > Harvey
> > counter clockwise?
