cheap TRF foil experiment is a success
2016-12-26 by Rob
Archive for Homebrew_PCBs.
2016-12-26 by Rob
2016-12-26 by kbyrne10@...
2016-12-26 by soffee83@...
2016-12-26 by Harvey White
>Rob,Every once and a while, the pulsar film almost completely
>Would you by chance have actual Pulsar TRF or anything on hand? It would be interesting to see how they compare. There are so many factors with this stuff it's hard to tell what's causing what sometimes. I've got the modded Apache, the eBay yellow transfer paper, and the real TRF, and I've still had bouts where the crap just wasn't working. My main issue is that I don't do transfers consistently enough to arrive at a solid setup. Seems like every time I set the stuff back up, I've forgotten what did or didn't work the last time I did it. I probably need to start jotting down notes.
>Thanks!
>Harvey,Actually, I don't think so, since I was doing a run and the ones
>That's crazy, as it's exactly what I was talking about. I think about two sessions ago I had the TRF come out looking almost exactly like it does going in. It just lifted right off the board with almost no part sticking. I think I ended up moving to my old iron and not using the laminator. I'm still of the belief that something in there has to be different. Maybe the laminator lies about its current temp or something??
>Take Care
2016-12-26 by me@...
2016-12-26 by Rob
On 26 Dec 2016 09:22:52 -0800, you wrote:
>Harvey,
before and after turned out ok.
I'm beginning to suspect the foil itself may have a contaminant on it,
or the toner, somehow.
Putting fresh foil on the board and reworking the board generally will
ruin something on the pattern.
Harvey
>Take Care
2016-12-26 by Rob
Rob,
Thanks!
2016-12-26 by Rob
Your traces are awfully wide. I would like to see experiments with more narrow traces.
This stuff looks interesting for transfers for things like silk layers and labeling project boxes.
But from my reading it looks like you now have 2 transfers to worry about. One for the toner, one for the foil. What is the advantage here other than some cool colors?
>Your traces are awfully wide. I would like to see experiments with more narrow traces.The green foil is used to seal the toner for microscopic holes. It
>That's possible too Harvey. I'll keep an eye out for it. I can't remember if I tried to reuse the stuff that didn't stick. Now that I think back, there were some hazy splotches, and I think it heated and smeared the toner, so I probably started over with all new stuff on the next successful pass.The foil that did not stick looked a bit more shiny than before, as if
>Take Care
