Homebrew_PCBs
Archive for Homebrew_PCBs.
Auto Heater shutdowwn for Laminator mod
2016-12-20 by mosaicmerc@...
Hi all:
I believe an auto shutdown of the laminator's (Apache/Trulam) heater is of safety value to the user. In such a case if a laminator is left unattended (no mode switching for the mod.) It will auto cool (power off) the heaters after a certain time, leaving the temperature set point unchanged.
I am thinking about 30 minutes of operation should be a reasonable time. Would any other members have thoughts on this?
Re: [Homebrew_PCBs] Auto Heater shutdowwn for Laminator mod
2016-12-20 by Rob
Sure.......
hack an appliance to run hotter than its intended design parameters..... then walk away.
I melted one plastic gear at 390 degrees in less than 10 minutes.
What would have happened if I left that 390 degree heat continue its dissipation into more parts?
It doesn't matter if it shuts off in 30 minutes if your fire starts in 15 minutes.
You ARE playing with heaters in a plastic case relying on electronics you hacked.
When you burn down your house .... free to explain to your insurance company how this is their bill to pay after voiding the laminator warranty by opening it and adding features to make it run hotter....hot enough to melt plastic... deform structures..that holds AC electricity in heaters.
DON't walk away.
I went a totally different route. Throw away all the plastic parts.
http://www.learnmorsecode.com/laminator/al9.html
Remove the metal rollers and heaters completely from the plastic shell and mount them
in metal brackets and a metal box.
Nothing heavy metal....just construction steel studs thin gauge metal.
Pretty much end up with a metal toaster with rollers.
I don't have it running yet because I lack metal gears.
I'll get to metal gears some day.
On 12/20/2016 12:59 PM, mosaicmerc@... [Homebrew_PCBs] wrote:
Hi all:
2016-12-20 by Jean-Paul Louis
Rob,
By someday, do you mean this century? LOL
I know the feeling, I have too many unfinished projects that
I will finish someday too.
One of them is a temperature controlled toaster oven to reflow SMT.
I have the degutted toaster oven laying around, I have the SSR relays also
I just need to install the thermocouples and the Microcontroller.
Someday, I will finish it too.
Meanwhile, I am getting ready to fly to my son’s home for the holidays.
Merry Christmas to the whole group.
Jean-Paul
N1JPL
> On Dec 20, 2016, at 2:08 PM, Rob roomberg@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
> Sure.......
> DON't walk away.
>> Hi all:
Rob,
Jean-Paul
N1JPL
> Sure.......
> DON't walk away.
>> Hi all:
2016-12-21 by Harvey Altstadter
Rob,
Since the recent posts on gears, I have been nosing around ebay looking for metal gears.
I found two sellers that have gears that fit a wide variety of shaft sizes, and have a variety of tooth counts:
1- speed_mart  http://stores.ebay.com/speed-mart?_trksid=p2047675.l2563
2- fivefive.co.ltd  http://stores.ebay.com/fivefive-co-ltd?_trksid=p2047675.l2563
There are other sellers, but they don't seem to have a wide variety of gears, and, for the most part, duplicate the ones carried by these two sources. I found them by searching for metal gears. IF you know your shaft size(s), you can search for metal gears xxmm. That will narrow the results to just those that you could use.
I am investigating a set of gears that look to be a fit for the Harbor Freight laminator.  That laminator has flatted shafts. These gears are for round shafts, but have collars with set screws. I will report back when I have determined whether these gears look good for that application.
Harvey
On 12/20/2016 12:08 PM, Rob roomberg@... [Homebrew_PCBs] wrote:
Sure.......
DON't walk away.
Hi all:
TrulamTL320B run stock to 390F
2016-12-21 by Rob
Well thats good to know... thank you... I did not know that.
I guess you get what you pay for.....
AMAZON $100
http://www.laminationdepot.com/Shop/Photo-Pouch-Laminators/
for $150
Either way...metal...silicone rollers..... stock 390F.......
the second you open one up you void the warranty and the HACK being discussed is about roller speed
so it doesn't make much difference to me..... don't walk away from any heat appliance you hack.
On 12/20/2016 09:42 PM, mosaicmerc@... [Homebrew_PCBs] wrote:
Rob, the Apache AL13P  & TrulamTL320B don't run on hacked heaters. They run stock to 390F and are all metal with silicone rollers.
I don't hack laminators' to run over temp...that's a dangerous practice.
DOES TrulamTL320B run stock to 390F tag says 360F
2016-12-21 by Rob
DOES  TrulamTL320B run stock to 390F ..... tag says 360F
http://www.laminationdepot.com/TruLam-Pouch-Laminator-LED-Screen.jpg
AMAZON $100
for $150
Re: TrulamTL320B run stock to 390F
2016-12-21 by mosaicmerc@...
Actually 380F, typo.
I don't advocate walking away...walking away from a hot appliance is not a good idea, hacked or otherwise.
2016-12-21 by Cristian
At 04:33 AM 21-12-16, you wrote:
>Rob,
Why not isolate the plastic gear in a tin box and ventilate it with a
small fan?
Cristian
Re: Auto Heater shutdowwn for Laminator mod
2016-12-21 by kbyrne10@...
I have a TL902 Thermal laminator with a brand name Scotch and a question along the line of thought if I may. What is the proper way to determine the temps it runs at as all the manual says is two temps one 3mil  thin stock,second 5mil thicker stock? I have a MASIONE Infrared Thermometer (58 degrees to 716 degrees F). Will that be accurate when dot is ob board as soon as it can be seen coming out of lam? I am trying to figure out toner transfer and green trf transfer temps out for size before I buy a Apache ect.
Re: [Homebrew_PCBs] Re: Auto Heater shutdowwn for Laminator mod
2016-12-21 by KeepIt SimpleStupid
Hopefully your looking at this as an "inactivity timer" and not a timer from power-on?
On Wednesday, December 21, 2016 10:27 AM, "kbyrne10@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com> wrote:
Cristian,
The gears are the same shaft as the roller that is being heated by the heater. The gears are heated by both radiation and conduction. Providing a heat shield would cut down on radiated heat, but the main source is conduction. I suppose that the mechanics could be changed to extend the shafts with thermally insulating material. That would place the motor/gear mechanism outside the case. I am not sure I could identify a thermally insulating material that would be stiff enough at that temperature to give the required operation. Metal gears would be much simpler.
Harvey
>Rob,
small fan?
Cristian
When I was doing my gear melting experiments, I used a small bead type thermocouple in contact with one of the rollers. I placed it near the end of the roller so that it wouldn't mar the contact areas. I wedged it in so that it's own springiness would hold it in place against the roller. This was good enough for my experiments, but for permanence, I would have had to find a better way. It gave reasonably repeatable readings.
BTW- My thermal controller worked great at 200C. Cannot say the same for the gears:-)
Harvey
2016-12-22 by AncelB
I've been thinking about the inactivity approach which can permit a
tighter time control on the heaters = power savings & safety enhancement.
Some testing showed that when running a cool PCB thru the laminator the
sensor temperature dips by a few degrees before the temp. control
recovers as the PCB comes up to temp.
The current iteration of the mod, does monitor the temp sensor from a
good/bad POV based on its outputs.
I can reflash my mod. PIC to track this and do the following:
1) Once the temperature has achieved steady state, issue a single chirp
every 30 seconds or so to alert the user.
2) If the steady state is unchanged for more than 15 minutes it
indicates no activity and enables the heater shutdown/cooldown
3) If the temperature exceeds the max. setpoint of the laminator....also
execute a heater shutdown.
Once I get in the teflon flats I should be able to generate simple, hi
temp, spur gears once I have the gear & shaft diameter and teeth counts
required.
If the shaft is not D shaped and requires a set screw it gets more
complicated. In such a case I'd propose a drill/tap set screw on the
shaft and notching the gear to slot onto that.
What might be useful is I could re engineer the gear ratios to slow down
the laminator to better suit the purpose.
2016-12-26 by arvidj@...
Ancel,
Just my opinion but I'd prefer two short beeps every 30 seconds when it is up to temperature.
I bought the kit thru Jamesco when the Alpine's reappeared for $79. Is there any way to tell what version of the firmware it is running? And when you need beta testers for the new, improved version of the firmware I'd be happy to flash a new PIC and give it a try.
Arvid
2016-12-27 by mosaicmerc@...
>>Just my opinion but I'd prefer two short beeps every 30 seconds when it is up to temperature<<
I can look at that. I guess it's about averaging the temp sensor output and  assigning a reasonable hysteresis to assess the temp stability.
Give me a reminder though...
Have to finish a product beta for an Aussie client in the next 2 weeks and  I'm a bit behind.
