Re: Laminator Toner Transfer DIY Mod. Kit - Apache AL13P AND TRULAM
2016-12-20 by AncelB
Hi Kevin:
Does it also have four screws on the bottom of it for adjustments?................ Yes, identical to the Apache Al13P except for labeling.
How hard is your kit to install? ............About an hour to build and 10 minutes to install. You need about 3' of CAT5 cable
I need this info before I buy as trying to find the right deal on Apache is driveing me nuts. Kevin<<
Apache's appear off and on and go out of stock super fast.
>>What is the thickness that your new lam will handle?..........I run from 'scissors cut' up to 1.6mm thick PCB standard, but it can go thicker if you loosen the 4 tensioning bolts a bit.
