Mid range cnc circuit board mill wanted.
2016-12-01 by mark.phillis@...
Archive for Homebrew_PCBs.
Hi all
I wanted to reach out to those far more experienced than I am. I'm looking at purchasing at a cnc circuit board milling machine . I know there's plenty to choose from but I wanted a good priced well made machine.
If anyone can offer any suggestions on this as I don't want to waste any money.
Thanks in advance
2016-12-01 by M phillis
On Thursday, 1 December 2016, mark.phillis@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:Hi all
Thanks in advance
2016-12-01 by Boots Hughston
On Dec 1, 2016, at 7:00 AM, M phillis mark.phillis@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Are any of those Chinese ones on eBay any good?
Thanks in advance
On Thursday, 1 December 2016, Boots Hughston boots2b1@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:What you want is a very strong frame cast iron or aluminum. A spindle that runs at 40,000 or higher 100,000 is better. No run out air bearings. Software that is easy to use - in English. Ball screws are ok if high quility. My machine is J-Cut I have had it for 5 years, runs and works good. Copper cam is the best iso software to isolated traces. Buy the full version it's around 150. May of the other programs are junk.Good luck, Boots-2b1
On Dec 1, 2016, at 7:00 AM, M phillis mark.phillis@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com > wrote:Are any of those Chinese ones on eBay any good?
On Thursday, 1 December 2016, mark.phillis@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com > wrote:Hi all
Thanks in advance
2016-12-02 by Boots Hughston
On Dec 1, 2016, at 10:19 AM, M phillis mark.phillis@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Hi
Thanks for the advice. The Jcut what sort of prices are these? I've taken a look but it seems you have to enquire.Thanks
Thanks in advance
2016-12-02 by Larry Battraw
2016-12-02 by wb8nbs@...
On Dec 2, 2016, at 7:49 AM, wb8nbs@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
I know Adafruit uses a couple of Othermills to do proto boards. $3300, and there's much info on the Adafruit web site.
2016-12-02 by M phillis
On Friday, 2 December 2016, Boots Hughston boots2b1@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:Again - most important veryyyy sturdy frame and high spindle speed, min 40,000 preferred 100,000 if you really want to mill PCB's.Most Iso software have a tork setting which makes the start and stop smooth.Boots-2b1
Sent from my iPhoneI know Adafruit uses a couple of Othermills to do proto boards. $3300, and there's much info on the Adafruit web site.
