Homebrew_PCBs
Archive for Homebrew_PCBs.
HP technical pen ink does not work for etching
2016-11-22 by Rob
Not sure if the dating on this make a difference......
I bought HEWLETT PACKARD
Disposable Liquid-Ink drafting Pens
.5mm Medium Point   HP Part no 5061-7620
says For use on paper or vellum only on the package
and drew on copper .5 mm traces.
The ink looked very wet so I did two passes and let it dry on a heater vent.
Then.... etched in peroxide and muriatic acid.
All the black traces looked intact until the very last etching copper disappeared
BUT
one swipe with a light touch makeup brush simple wiped away the black traces to reveal ZERO
copper under the ink traces.
The package said USE BEFORE JAN 1992 so perhaps I would get a different result from
TODAYs inks instead of using 25 year old ink. Who knows if they even use the same chemistry now.
But for paper.... these are really nice pens.
Re: [Homebrew_PCBs] HP technical pen ink does not work for etching
2016-11-22 by Dennis Shelgren
There are still shops that sell resist ink that can be used in plotters. Cleaning and filling a pen is a PITA though. Now I'm trying the paint a board and laser burn it off route. Traces are getting really small in my work.
On Nov 21, 2016 6:06 PM, "Rob roomberg@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com> wrote:
BUT
2016-11-22 by Brad Thompson
> .5mm Medium Point HP Part no 5061-7620...
<snip>
> ...The package said USE BEFORE JAN 1992 so perhaps I would get a different
> result from
Hello--
I dimly recall investigating the use of an HP 7475 pen plotter for
ink-on-copperclad
direct trace layout-- the time frame would have been in the very early
1990s. There
was a fairly substantial amount of correspondence on whatever newsgroup
existed back then, and someone from Canada recommended using a red
plotter ink made by Stadler (sp?) which provided very good etchant
resistance.
I attempted to purchase some of the ink, only to be told by the local
drafting-supplies
seller that the ink contained a toxic ingredient that made its sale
illegal here in the U.S.
However, the ink was still available in Europe.
At that point, other projects diverted my attention and I lost track of
the original correspondence. If someone in the group was active back
then, perhaps they
recall using the ink?
73--
Brad AA1IP
I think magenta was the magic color. Modern epson printers can use it too. Fairly impervious for etching as it was for "anti-acid archival prints", whatever that means.
On Nov 21, 2016 6:37 PM, "Brad Thompson brad.thompson@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com> wrote:
<snip>
> result from
Hello--
ink-on-copperclad
1990s. There
resistance.
drafting-supplies
then, perhaps they
73--
Brad AA1IP
RE: [Homebrew_PCBs] HP technical pen ink does not work for etching
2016-11-22 by Dave Wade
> -----Original Message-----
> From: Homebrew_PCBs@yahoogroups.com
> [mailto:Homebrew_PCBs@yahoogroups.com]
> Sent: 22 November 2016 02:36
> Subject: Re: [Homebrew_PCBs] HP technical pen ink does not work for
> etching
> <snip>
> > different result from TODAYs inks instead of using 25 year old ink.
> Hello--
> I dimly recall investigating the use of an HP 7475 pen plotter for ink-on-
> copperclad direct trace layout-- the time frame would have been in the very
> early 1990s. There was a fairly substantial amount of correspondence on
> whatever newsgroup existed back then, and someone from Canada
> recommended using a red plotter ink made by Stadler (sp?) which provided
> very good etchant resistance.
I have an HP7475 plotter. I have once used a much modified RED Lumicolor pen to make one test board, and found the etch time fairly critical, but I would say it was usable with some tunning.
I would say it would probably work with refinement but a fine pen takes a long time to fill the lands on the plotter.
This must be around 2 or three years ago.
> I attempted to purchase some of the ink, only to be told by the local drafting-
> supplies seller that the ink contained a toxic ingredient that made its sale
The refill ink appears to be available on Amazon in the USA:-
https://www.amazon.com/Staedtler-Lumocolor-Permanent-Refill-Station/dp/B000WH0ZLA
but of course, the inks for the USA may be different
> At that point, other projects diverted my attention and I lost track of the
> original correspondence. If someone in the group was active back then,
> perhaps they recall using the ink?
I read the articles and tried myself. My big problem with this method is that I don't have a big demand for making boards, the Plotter is slow, especially on big fills.
I am currently investigating using my 3D printer with a Dremel for PCB production.
> 73--
> Brad AA1IP
Dave Wade
G4UGM & EA7KAE
2016-11-22 by Rob
I'm not looking to plot a massive circuit.
I just wanted to find the right ink for a .5mm technical pen
or
fine point marker
that would draw a trace on copper and resist acid etching.
FOR
touching up any missing or damaged TONER TRANSFERed traces.
I found that standard sharpies dry out and stop depositing ink.
I found that STAEDTLER LUMOCOLOR permanent 313 BLACK and GREEN ink
worked great...flowed freely..resisted etching......
so
I thought it would be interesting to see if there was an indutry standard
.5mm drafting pen ink that performed the same acid resist.
2016-11-22 by alienrelics@...
MIS PRO magenta or yellow, but yellow is reported to work better as an etch resist.
Ink Supply mentions us (via the Massmind site and the Inkjet_PCB_Construction yahoogroup) on the page for the specific yellow pigmented ink that works well.
Not sure if anyone has tried putting this ink into a plotter pen.
Steven Greenfield AE7HD
2016-11-23 by <n0tt1@...>
I'm a QSL card printer....you might try one of these or equivalent.
This co wants you to "register", but you might find one of
these locally at a well-stocked pressroom supply company.
They cost around $11.  They come in various sized points.
Best,
Charlie, N0TT
On Tue, 22 Nov 2016 11:24:49 -0500 "Rob roomberg@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com> writes:
or
fine point marker
FOR
so
