Homebrew_PCBs
Archive for Homebrew_PCBs.
Dual side PCB brd
Dual side PCB brd
2016-11-09 by kbyrne10@...
Does anyone know of a you-tube video that clearly does the entire process
or a site that clearly describes the process for pdf downloads? What I mean is alignment of top negative and bottom negative. I tried my first attempt yesterday with a two board project and this is the result. Bottom main brd,
good to etch with a couple of test holes drilled and good alignment with a pouch made up and brd slipped into three side closed pouch. Top LCD
display brd was off and one side of that brd has to be redone or start over with a wasted 4in by 4in brd scrap. I need a better system due to small traces and pads.Any help would be appreciated for a newbi.
Re: [Homebrew_PCBs] Dual side PCB brd
2016-11-09 by Harvey White
Go back and check some of the posts, please, there are several
methods. What I do is to drill VERY accurate alignment holes. I make
separate top and bottom boards, it does require thinner 0.020 to 0.032
single sided material.
The next step is to epoxy the boards together. The best epoxy is a
1/2 hour setting or more, it allows you to do a run of boards without
wasting epoxy.
I use push pins (relatively thick) that do not wobble, and then use it
to align the boards, one of which has been precoated with epoxy. tape
the boards together to keep them from moving, then remove the pins.
Put the boards between ceramic tiles (cheap) which keeps the boards
from warping. It can also help to cover the board copper with masking
tape to eliminate fingerprints.
Harvey
2016-11-09 by Kevin Byrne
Thank` you Harvey I will look into what you said all thou I have a large supply of dual sides brd stock. The brds I am doing now are freeware eagle size 4 in by 3 1/2 in
approx. If I have to change to get accurate thou I will.
Re: Dual side PCB brd
`Thank you Ancel, I have viewed your post and off to try out your way of alignment but with negatives done up in Eagle Free Ware & Hp Laser Jet P2015dn OEM ink.
