LJConfig 1.2 allows you to easily modify the settings of supported HP LaserJet printers ---> Re: [Homebrew_PCBs] Re: Asian toner transfer paper
2016-08-29 by Martin O'Shield
Leeleduc,
My replies inline:
On Sun, Aug 28, 2016 at 5:32 AM, leeleduc@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:What freeware do you use with your HP LaserJet P2015dn?
What Kevin replied to you with,
Laser Jet Configurator is what the program says at the top of it. i will search for it again if need be. just let me know. KevinSo I found it here:LJConfig 1.2 allows you to easily modify the settings of supported HP LaserJet printers from your desktop across any sort of printer connection. Version 1.2 allows you to change the Lines Per Page, Control Panel Display, Density, Tray Locking, Fuser Temperature, EconoMode, REt, and Resolution settings.
LJConfig supports the following LaserJet printers:
Some LaserJet 4s (4 Plus, 4Si, and some others)
http://www.victechsoftware.com/ljconfig.html
- LaserJet 5P, 5MP, 5L-FS, 5L Xtra
- LaserJet 6P, 6MP, 6L, 6L Xtra
- LaserJet 1100
- LaserJet 1200/1220
- LaserJet 2100/2200
- LaserJet 3200
- LaserJet 4000/4050/4100
- LaserJet 5000
- LaserJet 8000/8100/8150
This *may* work with your printer so please try it and let us know the results.Sincerely,Martin
