Homebrew_PCBs
Archive for Homebrew_PCBs.
Substitute for Sodium Persulphate
2016-05-28 by Harvey White
I have a commercial etching tank, composed of formed acrylic plastic
and two fish tank pumps.
It's designed for sodium persulphate etchant.
I can get a pool shock persulphate etchant for about 10 dollars for 1
KG, and you need about 1 KG for a single run (no idea how many boards
that is, but it's about 1-2 gallons of etchant).
The normal HCl/H2O2 etchant that I use would no doubt eat the pumps to
pieces.
So a question would be: Can I use high concentration H2O2 (say from a
beauty supply store, no idea how much that might be, but presumably
less than the 1.25 dollars/quart that I can get H2O2 for...)? Just by
itself, I suspect that it might not work, would activating that
etchant with a little chloride ions (perhaps salt?) work?
Has anyone looked for a substitute for Sodium persulphate (potassium
persulphate will also work, but equally expensive, I think)?
Is there an etchant that will work for this kind of situation?
Harvey
Re: Substitute for Sodium Persulphate
2016-05-28 by wb8nbs@...
Normally you use a bubbler to agitate a small tank, and the pumps are not in the solution. Bubbling also regenerates the cupric chloride which is what is actually performing the etch. The HCl/Peroxide mix will quickly eat nylon but most other plastics don't seem to be bothered. Epoxy glue is attacked but slowly. If you're building your own tank, test the materials first.
Adam Seychell used to have a web page describing the process, but his site seems to be gone.I had to get it from the wayback machine. Jim Williams has duplicated Seychell's page at Etching with Air Regenerated Acid Cupric Chloride
RE: [Homebrew_PCBs] Substitute for Sodium Persulphate
2016-05-28 by keith printy
What about ammonium persulfate ? when I worked at the electronics plant that was what we used to etch our boards. It is clear and turns blue as it etches . we used to put it in a corningware baking pan and warm it with a hot plate underneath . if you put more into the mix it of course eats away the copper faster. In time it will take the shine off the corningware in the area where the heat source was.
Have also used ferric chloride , it also works better if you warm it. Ferric chloride is usually used in sewage treatment plants to coagulate the solids.
Sent: Friday, May 27, 2016 8:07 PM
To: Homebrew_PCBs Mailing List
Subject: [Homebrew_PCBs] Substitute for Sodium Persulphate
pieces.
Harvey
Re: [Homebrew_PCBs] Substitute for Sodium Persulphate
Same kind of problem with price, I think. I could only buy it from a
chemical supply plant, and it's rather expensive.
Had used that for years, hard to find in good sized lots, 30
bucks/gallon or more plus shipping.
Peroxide and muriatic acid is far cheaper.
If I could find a cheap source of ammonium persulphate, that would be
nice.
The stuff in the pool supply stores (Oxy-shock) is 10 bucks/kilo, and
has trace ingredients (undisclosed). It does work, but I'm not happy
at that price.
Harvey
>pieces.
>Harvey
Re: [Homebrew_PCBs] Re: Substitute for Sodium Persulphate
This is what I normally do.
The tank I'm trying to use is a commercially made tank that flows the
etchant over the board. It uses two heaters and two aquarium pumps.
The instructions (as far as I've been able to find) specify peroxide,
and I'm rather certain that the metal and nylon in the tank will be
destroyed by the HCL/peroxide etchant.
I'm trying to figure out an alternate etchant that's inexpensive and
won't eat the tank.
Harvey
>Adam Seychell used to have a web page describing the process, but his site seems to be gone.I had to get it from the wayback machine. Jim Williams has duplicated Seychell's page at Etching with Air Regenerated Acid Cupric Chloride http://jimlaurwilliams.org/projects/seychellePaper/
> Etching with Air Regenerated Acid Cupric Chloride http://jimlaurwilliams.org/projects/seychellePaper/ Etching with Air Regenerated Acid Cupric Chloride By Adam Seychell (Last modified 5 November 2005)
> View on jimlaurwilliam... http://jimlaurwilliams.org/projects/seychellePaper/
> Preview by Yahoo
2016-05-28 by Russell Shaw
>> Have also used ferric chloride, it also works better if you warm it. Ferric
> nice.
> at that price.
If you use air agitation which adds oxygen and add half a cup of HCl to the
ferric chloride every few months, the etching will last for years, which is way
cheaper than any ammonium persulfate setup. No heating above room temperature is
needed either. I started with an equal part of water with the ferric chloride
atleast 5 years ago and it still works well.
2016-05-28 by LEON HELLER
When I etched my own boards I used hot ferric chloride. When it started getting slow I used to add a little hydrogen peroxide. I was able to use it indefinitely.
On Saturday, 28 May 2016, 16:02, "Russell Shaw rjshaw@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com> wrote:
> nice.
> at that price.
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBs
Yahoo Groups Links
<*> To visit your group on the web, go to:
<*> Your email settings:
    Individual Email | Traditional
<*> To change settings online go to:
    http://groups.yahoo.com/group/Homebrew_PCBs/join
    (Yahoo! ID required)
    Homebrew_PCBs-digest@yahoogroups.com
    Homebrew_PCBs-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
    Homebrew_PCBs-unsubscribe@yahoogroups.com
<*> Your use of Yahoo Groups is subject to:
    https://info.yahoo.com/legal/us/yahoo/utos/terms/
2016-05-28 by John Ferrell
Read the MDS. It is pretty safe stuff. About a million years ago I was a Lab Tech and HCl was used to wash ink off our hands.
Beauty shop peroxide is about 30% and over $30 per gallon. The drug store stuff works and $1 per Qt. I wash all wounds with the $1 peroxide and some people use it for mouth wash.
It also leaves bleach dot on you clothing.
John Ferrell W8CCW
   Julian NC 27283
 It is better to walk alone,
than with a crowd going the wrong direction.
                  --Diane Grant
Several things:
1) I've used ferric chloride, and never again.
2) I already have HCL and peroxide, and use them in a different
fixture.
3) I'm trying to make use of an existing etching system I bought
surplus, it has parts that will be damaged by HCL/Peroxide.
4) I'm finding the cost of the ammonium persulphate rather high.
5) I'm wondering if boosting the oxygen content with perhaps 2 quarts
of 3% and some more concentrated H2O2 would work if I added, say, some
sodium ions (or do I even need to?).
6) I'm looking for an inexpensive substitute for
sodium/potassium/ammonium persulphate that DOES NOT eat my etching
tank.
Harvey
2016-05-28 by Mark Lerman
If you use the Beauty Shop peroxide be aware that the etching is violently exothermic. Lots of heat and fumes. The etching goes very fast. Done in seconds.
I use the drug store version mixed 2:1 with muriatic acid from the hardware store. Instead of immersing the board I use a sponge and gently rub the copper. This allows you to control where you need the etching. Obviously, wear gloves.
I'm not sure who first described this technique, but it gives you good control and only takes a few minutes. It also lets you use a very small amount of etchant.
Mark
On May 28, 2016, at 2:53 PM, John Ferrell jferrell13@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
John Ferrell W8CCW
   Julian NC 27283
                  --Diane Grant
I'd be using it to boost the O2 concentration of the etchant, which
hopefully works, since the peroxide by itself I can see as not being
much different from the ammonium persulphate except for the ammonia
ions (and sulphate ions).
In theory, the drugstore peroxide might etch sufficiently by itself,
then the question is either to put a gallon or so of that in, or
refresh it by the beauty shop peroxide.
I'm trying to avoid the CuCl etchant, or at least, the HCL part of it.
Harvey
>Mark
>Sent from my iPhone
>> John Ferrell W8CCW
>> Julian NC 27283
>> --Diane Grant
RE: [Homebrew_PCBs] Re: Substitute for Sodium Persulphate
Another thought is possibly oxi clean . it is basically hydrogen peroxide although maybe a bit stronger than the 3% stuff you buy at the drug store
Sent: Saturday, May 28, 2016 2:54 PM
Subject: [Homebrew_PCBs] Re: Substitute for Sodium Persulphate
John Ferrell W8CCW
   Julian NC 27283
                  --Diane Grant
2016-05-29 by Jean-Paul Louis
Harvey,
The hydrogen peroxide alone will NEVER etch copper. it is H2O2 (very strong oxidizer),
so the only thing that it could do is to oxidize a thin layer of copper (black).
In order to etch, you need ions Cl- to create green cupric chloride CuCl2 (dissolve in water).
So you need the hydrochloric acid (muriatic) to convert the copper oxide to cupric chloride.
Hence the combination Hal-H2O2 that will etch copper very fast.
To regenerate the etchant, you use a bubbler that will bring O2 ( O= ions) in the solution.
My $0.02,
Jean-Paul
N1 JPL
> On May 28, 2016, at 6:05 PM, Harvey White madyn@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
> Harvey
> >Mark
> >Sent from my iPhone
> >> John Ferrell W8CCW
> >> Julian NC 27283
> >> --Diane Grant
2016-05-29 by Harvey White
On Sat, 28 May 2016 21:51:40 -0400, you wrote:
>Harvey,
Thanks, that's what I need. I understand regenerating the etchant. If
I supply chloride ions (say from salt), think it will work? I'm
guessing that the HCL is what makes CuCl so destructive to things like
nylon.
any opinions?
Harvey
>My $0.02,
>Jean-Paul
>N1 JPL
>> Harvey
>> >Mark
>> >Sent from my iPhone
>> >> John Ferrell W8CCW
>> >> Julian NC 27283
>> >> --Diane Grant
2016-05-29 by cs6061@...
I started out with Ferric Chloride many years back, worked well but was very messy and stained anything it touched.  Never tried to regenerate it but did heat the solution to help things etch and discarded when used up.  Then I moved over to Ammonium Persulfate, much cleaner, has a very fast etch with minimal undercut but it needs to be heated quite hot to work well.  For really fast etching add a few PPM of a mercury II salt.   Once mixed the AP degrades and becomes useless in a couple of weeks.  Worked great in my splash etch tank, I did a lot of boards with the stuff. Also helped that I had a free source.   For the most recent boards I tried H202 and  HCL,  works good  but more corrosive than the AP.
The actual etchant in the H202-HCL is the  Cupric Chloride  ie. Copper(II) chloride CuCl2 that is formed in the solution.  The etchant gets better with use as more CuCl2 is formed.  The etching is the result of a
Redox reaction, the copper on the board is oxidized to Cu+ ions and goes into the solution  while the CuCl2 is reduced to CuCl.  The H202 or air bubblier oxidizes CuCl back to CuCl2 making more etchant out of the board copper  The HCl provides the additional Cl ions as more Cu  goes into solution.   At some point the solution will become over saturated and you will need to dilute it down or start over.
Notes:  Beauty supply H202 is not 30%  it is 30 or 40  "Volume"  which is I think about 10 - 12%
           To remove ferric chloride stains use Oxalic acid
Craig
2016-05-29 by Norm
tion.
nylon.
any opinions?
Harvey
>> Harvey
Harvy -
You really need to get the Adam Sechelle (sp?) article on CuCl etching.  It explains the chemistry involved in removing the copper.  Just putting salt (NaCl) in water won't release free Cl ions.  When the copper is removed, it has to go somewhere, and that is into solution as CuCl.  The etching (removal of the copper) relies  on the formation of CuCl and the reversible reaction between CuCl+ and CuCl++.  I know this isn't what you want to hear, but the chemistry is factual.
Norm
On Sun, 29 May 2016 00:01:43 -0700, you wrote:
>Harvy -
>etching (removal of the copper)***/relies /*on the formation of CuCl and
Ok, so then the ammonium persulphate etching works (obviously)
different. I'm trying to duplicate *that* process without having to
buy expensive ammonium persulphate, or if I do, then figure out a way
to regenerate it.
It's the free hydrogen ions (I guess) that do in the plastic, or
perhaps the chlorine ions.
With ammonium persulphate, I'm guessing ammonium sulphate and lots of
free oxygen, which suggests copper sulphate as a possible outcome. In
which case we get oxidized copper somehow or somewhere. Guess I'd
better look up the chemistry on that one.
Harvey
>Norm
2016-05-29 by duwaynes@...
I use the Muriatic Acid, Hydrogen Peroxide mixture with 12% Peroxide from a beauty supply store with good success. If you do not want to use the HCL, another solution that is sometimes used is a mixture of Hydrogen Peroxide, Vinegar, and salt.
A short video of this at
…still messing with forces I don’t understand – the formula.
  DuWayne
2016-05-29 by Norm
But mixing vinegar (acetic acid) and salt (sodium chloride)  results  in HCl  !  Just another way of generating a weak solution of it. !
Norm
2016-05-29 by AncelB
Just as an FYI I use Nitric acid, and have been doing so since 1987.
Fairly easy to handle at the lowish concentration in the etchant tank. I
can handle the boards with bare fingers once I get them rinsed inside of
10 seconds so I etch next to the rinse tub sink, although I generally
use plastic tongs/tweezers. My etchant tank is an ice cream container
as nitric is plastic safe as well. No heating required, but minor
ventilation is, it self agitates due to some bubbling during etching. No
staining etc, clear liquid and does not degrade when dilute. Lasts for
many years.
Harder to come by in the U.S.A. but if you hold a tertiary degree you
can buy it from lab chemical supply companies. I am not in the U.S.A.
and obtain it direct from my old University in carboyles.
I mix down the concentrated stuff to 1.2 Sp. grav to 1.22 Sp grav. for a
fresh batch as required (acid adds to water). Resultant etch in 5 to 8
mins double sided, 1 oz. Detail traces to 8 mils using the toner
transfer/foiling method. No heating or agitation required. Suitable for
quick and dirty sharpie marker traces, black or silver pens, silver is
better. Black ink needs to be dried properly (hot air speeds that).
The waste is acidified copper nitrate which is not a hazmat. Good for
drain cleaning/sewer lines, anti fungal use etc.
Ancel
2016-05-29 by Norm
The question here has been a replacement for the persulfate.
From Wikipedia, the free encyclopedia
"The term persulfate (sometimes known as peroxysulfate) refers to ions or compounds containing the anions SO2−
5
or S
2
O2−
8
.    . . .   These salts are strong oxidizers."
I'm not sure what the copper reaction with the persulfate would be, but it obviously doesn't involve HCl, and since the persulfate is an oxidizer, won't require H2O2.  If you use the CuCl or FeCl etchants, you can't avoid HCl in the process - it's part of the reaction.
It's been too long (65+years) since my high school/college chemistry!
Norm
2016-05-30 by Russell Shaw
> many years.
What dilution of acid with water in terms of volume is that?
