images for photoresist
2016-04-12 by Jeff Heiss
Archive for Homebrew_PCBs.
2016-04-12 by Harvey White
>I'm using laser transparencies for photoresist boards and I would like toYou want a professional place, one that does drawings, engineering
>test a real photographic film image. I understand real film has solid black
>this is excellent at blocking light. Can anyone suggest a type of place
>that can do photonegatives from a .jpg or .bmp? Can a CVS or Riteaid do
>this?
>Jeff
2016-04-12 by keith printy
That is simple to develop.i haven’t done it in a while but it was d76 developer , stop bath and fixer . you have to work in total dark until the fixer. If the size is 8 by 10 you could put it in a photo processing drum and let a motor do it for you. You would just need to drain the chemicals at the proper time.
A friend of mine used to do it with lithograph film . I don’t think it was as touchy and it could be handled under a yellow light if I recall.
Sent: Tuesday, April 12, 2016 5:24 PM
Subject: Re: [Homebrew_PCBs] images for photoresist
>this?
>Jeff
2016-04-13 by Andrew Volk
I did a bit of this in my college days. We used orthographic film (Kodalith, I think) that was not sensitive to reds and had very high contrast. It was fairly easy to use for me and give great results. I made contact prints from mylars taped with Bishop tapes and pad layouts. I used it under a ruby light with a carbon filament. (Something my Dad had in his basement photo area, along with an old enlarger and developing trays.) Ahh! The good old days.
Andy
Sent: Tuesday, April 12, 2016 4:23 PM
Subject: RE: [Homebrew_PCBs] images for photoresist
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew! _PCBs@yahoogroups.com]
>this?
>Jeff
2016-04-13 by Harvey White
>I did a bit of this in my college days. We used orthographic filmIt was kodalith. It may no longer be available. You had a two part
>contrast.
>It was fairly easy to use for me and give great results. I madeYou forgot the 8x10 view camera....
>The good old days.
>Andy
>That is simple to develop.i haven't done it in a while but it was d76
>the proper time.
>A friend of mine used to do it with lithograph film . I don't think it was
>>this?
>prints, and the like. They're likely to have the ability to make the
>image. Photolithographers, for instance. Riteaid or CVS barely know
>how t! o develop Tri-x Pan.
>Harvey
>>Jeff
>That is simple to develop.i haven't done it in a while but it was d76Kodak Kodalith, 2 part developer, stop and fixer. Red light is fine.
>the proper time.
>>this?
>how to develop Tri-x Pan.
>Harvey
>>Jeff
No view camera for my work, just direct contact printing. When I left college and went into the electronics business, then there were rubyliths (red cellophane image on a heavy mylar base) and the view camera was a room. The rubylith was hung against a wall-sized light board and the camera was mounted in an opposite wall. The reduction of size was about 20:1, but the whole process was essentially the same to get a master image. That was stepped down again 10:1 and step and repeated for a whole wafer full of images used to make integrated circuits. Mind you that was mid to late 1970’s. The process has changed a lot since then.
Sent: Tuesday, April 12, 2016 6:30 PM
>contrast.
>The good old days.
>Andy
>the proper time.
>>this?
>Harvey
>>Jeff
2016-04-13 by cs6061@...
>Way back in my hand taping days before CAD layout tools, we would lay a board out using Mylar film, ruby tape and Bishop dip and doughnut pads. This was done at 2:1 then sent to an industrial photo house to be reduced 2:1 on lito-film. IIRC it was about $20 to $50 for a set of negatives and more if you wanted a set of contact positives.There were two ways of doing this. One was to use black donuts and
>I saved some cost at home by doing my own contact positives. Making the contact prints was fairly easy -- just a couple pieces of glass to clamp the films together, a darkroom safe light, some slow litho-film, developer and fixer. Took around 20 minutes to do the entire process. The positives were used with boards spin coated with Shipley AZ111 positive resist, exposed then etched. Turn around for the photo house was 24 hours but you could pay for 1 hour service if you were in a rush. Eventually all the photo houses switched over to laser plotters once PCB CAD systems became available. Even the photo plotting houses went by the way sideAnd it took a bit to get there. Good computers and all sorts of
>once the PCB fabricators started to accept digital Gerber input files.
>Or do toner transfer, or send out to China for the boards, etc....
>You can still buy litho-film, the developer and fixer from places like Freestyle Photographic Supplies. Though the web site seems to be down. The ideal thing would be to build your own photo plotter
>Criag
