Got some single side boards
2016-03-31 by unclefalter@...
Picked up a bunch of these on ebay. Thought before I spend $400 I might as well see what I get with these and do some trial runs.
http://www.ebay.com/itm/361162323034?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I have a couple questions. I want to use, if possible, the original artwork provided to builders in 1973. Here is a sample of the mainframe artwork that I posted before:
http://www.swtpc.com/mholley/TV_Typewriter/page_18.pdf
This is literally all I have to work with, since an original copy of the artwork is impossible to get now. So questions:
Is it dark enough to be usable?
If not, what would be the best way to get it darker without altering it too much? I tried just ‘paint bucketing’ black onto it in Photoshop but it seeks out the less visible grey tones and ‘thickens’ the traces, and sometimes obliterates the drill holes.
I’m assuming using the toner transfer method I need to print the image in reverse? I assume this image was intended to be used with the presensitized boards, thus it would be printed on clear overhead film and laid on top for exposure.
What would be the best way to get it to print at the correct scale. On other artwork I’ve seen actual scales (or ruler edges) displayed. For some reason that is not done here. I guess these would have been printed on standard 8.5x11 pages or something as life size. But because these were scanned from pages of a magazine it’s not quite exact (I printed and compared to my ICs). I guess I could just scale it up a percent or so at a time, but I’m thinking there must be a more scientific way.
Anything else to consider?
Thanks guys!!
