Homebrew_PCBs
Archive for Homebrew_PCBs.
Guillotine cutter
Guillotine cutter
2016-01-22 by alan00463@...
Does anybody in the USA know where I can buy a guillotine cutter like the one shown in this video (it's about halfway through at 7:35), for cutting copperclad boards?
Re: [Homebrew_PCBs] Guillotine cutter
2016-01-22 by Art Eckstein
video link???????
Posted by: alan00463@...
Re: Guillotine cutter
2016-01-22 by kbyrne10@...
I used a circular saw with a diamond tip blade mounted safely under a
plywood board when I had nothing but troubles with a paper cutter. Now I own
a 10 inch table saw for that purpose. A small hobby table saw  in a You Tube video of a dremel type is why. Any manufacture is ok. This has to be done safely but that is not hard to figure out how to do just that.
7 1/4 inch blade for circular saw and 4 inch blade for hobby saw. E-Bay
to buy, you tube to look up how to.
2016-01-23 by alan00463@...
OOPS!   Now who forgot to proofread!    Yeah, me.   Sorry..... Here's the URL
https://www.youtube.com/watch?v=u4paArvuYrs
"Does anybody in the USA know where I can buy a guillotine cutter like the one shown in this video (it's about halfway through at 7:35), for cutting copperclad boards?"
Re: [Homebrew_PCBs] Re: Guillotine cutter
2016-01-23 by Art Eckstein
That looks very much like the one that I use based on the short time I could see it.
I use a "Roberts Quik-Cut Vinyl Tile Cutter Model No # 30002"  that I bought off ebay.  Do a search and you will find all kinds of prices and knockoffs.
I got mine for less than $4 but the shipping was like $15 so make sure of what your looking at.
Art
Country Bubba
2016-01-23 by me@...
I use a brake I purchased at Harbor Freight for about $30.   Just score the copper and snap. Safer than a guillotine and many times safer than a table saw.
RE: [Homebrew_PCBs] Re: Guillotine cutter
2016-01-23 by keith printy
Where I used to work they used a metal shear like you cut a sheet of steel with by stepping on a pedal. They used to put the boards in an oven first maybe 150 degrees I don’t remember but it made them cut better without breaking
Sent: Friday, January 22, 2016 8:57 PM
Subject: [Homebrew_PCBs] Re: Guillotine cutter
2016-01-23 by Jean-Paul Louis
Keith,
That make sense as 150 degrees is about the glass transition temperature of regular FR4.
That was most likely to make clean cuts versus zillions of tiny glass shards when shearing.
Just my $0.02,
Jean-Paul
N1JPL
> On Jan 22, 2016, at 9:25 PM, 'keith printy' keethpr@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
2016-01-23 by kbyrne10@...
Does a brake prevent cracks as my diamond tip saw blade does and is safe while using the proper push sticks and feather boards as I am always looking for new ways to do any job.
2016-01-23 by Stefan Trethan
It depends on the angle of the shear blade. Professional PCB shears cut almost all the width at once so there is very little twisting of the material before it is cut. Sheetmetal shears or laminate flooring cutters cut more gradually (to reduce the required force) and will leave visible delamination a millimeter or so in from the edge.
Even with a professional shear the edge is not as nice, smooth, and square as a milled or sawn edge, but perfectly adequate for most applications. I always used to sand or file them to remove any rags.
ST
On Sat, Jan 23, 2016 at 12:16 PM, kbyrne10@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Thank you for the info. I will stay with my way as I don't have that type money
nor that amount of boards to cut besides I get perfect results with diamond tip saw blades.
2016-01-23 by AncelB
For many years I used a carbide tile cutting scribe to score/snap PCBs.
But with thinner PCBs they bend and distort. So a shear might be better.
But they do NOT work on FR1 boards which are more rigid and more flat.
I recently switched to this 4" desktop saw for more precision and faster
'production' type work as I am starting a kit series.
The diamond blade is awesome and the product captures the dust by using
it in the same box it came in - cut down to access the table.
http://www.amazon.com/gp/product/B00AEZ70AO?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
PCB distortion and dimensional precision is critical when trying to
build cavity filters etc.
Ancel
I don't to spend $30 to score 'n' snap copper-clad.   All I need is a small piece of plywood, a utility knife, a straightedge, and a counter-top.   I already have all of these things - so zero $.
Guillotine cutter is a misnomer because this machine looks and functions
nothing like the labor-saving device of the revolution in France.    I looked
up "brake", and the sixth-most-common definition  at dictionary.com is
"Also called press brake. a machine for bending sheet metal to a desired shape."
So it's not a brake.
The 17th definition of shear as a noun there was
a machine for cutting rigid material, as metal in sheet or plate form, by moving the edge of a blade through it."
So I guess it's a shear.   Now that I know what I'm looking for, that might speed things up.   :) No, am not looking for a machine made of crap just because it is cheap.   That's a one-use tool.    I want to use the tool for years,  at least 10,000 cycles, preferably 20,000.       When I was much younger, I made the mistake of buying a portable handheld jig saw.   It  broke on my first job.    I learned my lesson that day - don't buy cheap tools if you can only afford to buy one of each.   And don't buy power tools with the Craftsman brand name.
So I guess the shear I am looking for  basically does the same action as a heavy-duty version of a paper cutter, that slices copper-clad rather than paper, eh?
2016-01-23 by Hal Faulkner
On Sat, Jan 23, 2016 at 9:23 AM, alan00463@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
2016-01-25 by Stefan Trethan
I think a 22 gauge would go through a PCB just fine. ;-)
Joking aside it's 0.8mm in real units and I'm not sure if that is enough.
It depends on cutting geometry, FR4 is softer than steel (the epoxy at least), but stiffer.
The plate shear I use is just about OK with 1.5mm boards and rated for 4mm mild steel, although I think that would be mighty optimistic even with a gorilla operating it.
I think a couple of people have a 3-in-1 machine so hopefully they can advise.
ST
On Sun, Jan 24, 2016 at 10:24 PM, alan00463@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
I found this PCB board cutter for a little less,
http://www.grizzly.com/products/12-Combination-3-in-1-Sheet-Metal-Machine/T21320
But weighs 114 #, so freight makes up a bunch of the price difference.
Not sure--is 22 gauge steel thick enough to cut PCB's?   I don't know the 22 gauge.    Plus it bends as well as shears.   And slip rolls, whatever that means.     But I wouldn't buy it without a personal recommendation.
2016-01-25 by casy_ch@tbwil.ch
I have one since quite a number of years. To cut a few PCB'sit is expensive but I never tried as I cut them with a little table saw.!
Here I can cut and bend aluminum sheets up to 1.5mm thickness. The cutting quality is good. The bending at 90 deg angle is tedious to following the marking on the sheet and in fact does not bend completely at 90 degrees on a 1.5mm thickness, a bit better on 1mm thickness.
The handles are not the best for using the device as I have to knock on them with the palm of my hands because the lever is not long enough for the strength needed. I had to turn the two in aluminum.
All in all not a bad device if one is getting used to it and nice for relatively small pieces.
Jean-Claude
Am 24.01.2016 um 22:24 schrieb alan00463@... [Homebrew_PCBs]:
P
2016-01-25 by Bob Butcher
I have used a cheap paper cutter purchased from one of the office supply stores. It probably is not the best idea for keeping it sharp since the glass fibers in G10 are quite abrasive, but since I don't cut very many boards or paper with it, it has lasted for several years. The one in the video almost looked homemade, at least the cutting bar did.
Bob
2016-01-25 by Corey Minion
imo, if you spend the money buy a brake, not a multifunction machine.
If you can afford the expense, and do some metal bending work too, invest in a finger brake.
12"    http://grizzly.com/products/12-Pan-and-Box-Brake/G0556
24"    http://grizzly.com/products/24-Pan-and-Box-Brake/G0557
Or for very intermittent use
http://grizzly.com/products/4-Vise-Brake/H3243 (they offer 5 & 6 inch versions too)
Corey
