Homebrew_PCBs
questions about Hightechsystems1's homemade PCB router
2003-12-05 by Ted Huntington
The homemade PCB router Hightechsystems1 made is impressive. I have 3
questions:
1) Are those motors DC gear motors or stepper motors? They look like DC
Gear motors.
2) Did you have to make any gears for this device?
3) As far as I can see, each axis uses a long worm gear in between two
cylinder beams that keep the drill, etc...moving in a linear direction
(as opposed to rotating with the motor shaft). But I see what looks
like a very low thread on the worm gear cylinder in the center...that
makes me think that there is a different variety of worm gear
techniques/structures. Can somebody describe the gear structure for the
long worm cylinder-movable part?
I was glad to see https://sdp-si.com/ now has an online catalog with
prices for gears, that is awesome.
thanks
Ted
Ted Huntington
Programmer Analyst I
Main Library
University of California, Irvine
PO Box 19557
Irvine, CA 92623-9557
emesgs: thunting@...
web page: http://business.lib.uci.edu/webpages/ted.htm
8:00a-12:00p Business Office (949) 824-8926
1:00p-5:00p Multimedia Resource Center (949) 824-1674
"Stop violence, teach science."
Re: questions about Hightechsystems1's homemade PCB router
2003-12-06 by Moore
Just looking at the pics these are my guesses, comments interspersed:
like DC
> Gear motors.
Most likely Stepper motors, there is a great deal of software and
hardware available to driver steppers from the standard PC parallel
port for x,y,z CNC machining funtions
I didn't see any, and there really isn't a need of desire for gears.
two
direction
center...that
for the
A lot of homebrew machines use pipe or drill rod for linear ways,
ACME screws or conventional 1/4"-20 all thread(threaded rod). A good
resource for
you if interested is www.cnczone.com. Specifically under Home-Made
CNC Wood Routers. I'm working on my machine and have some material
links at: http://webpages.charter.net/pminmo/mycncpage.htm
Phil
