Homebrew_PCBs
Archive for Homebrew_PCBs.
Toner refills
Toner refills
2015-04-02 by Robert Nickels
Like most of us I suspect, I make PC boards using the toner transfer
method. I have an HP Laserjet 5000 which is an office-grade printer
capable of up to 11" by 17", which is nice, but my toner transfers have
been of marginal quality. There's no problem in getting the transfer
to work, but the amount of toner that is transferred seems inadequate.
Before etching, the black areas where toner is present appears mottled
and not solid black, with tiny pinholes visible. Even though I use the
green film, the copper is rough after etching, traces are undercut and
of inconsistent width. I've already got my printer maxxed-out as far
as settings go.
I use the Pulsar transfer paper, and they advise that my problems are
due to using refilled toner cartridges which don't contain enough or the
right kind of materials. Even though the output looks fine on paper I
can accept this, but the refilled cartridges are a small fraction of the
cost of new HP brand toner cartridges (e.g. HP 29X which sells for $235).
My question is: are there any recommended alternatives which would give
me better results at a cost somewhere between the bargain refills and
the new HP 29X?
Thanks and 73,
Bob W9RAN
Re: [Homebrew_PCBs] Toner refills
2015-04-02 by Malcolm Parker-Lisberg
I use inkjet photo paper and refilled cartridges on an HP1010. The cartridges are icplus from ebay. After heating the paper to transfer (I use a domestic iron), put the board in the freezer for 20-30 minutes.
No rubbing or wetting the paper to remove it, just peel and all the toner stays on the PCB copper. The clay on the paper holds the toner to give a superb crisp image. You do get a white coating on the toner from the clay on the photo paper, but it has no effect when etching.
Malcolm
I don't suffer from insanity I enjoy it!
Mene, mene, tekel, upharsin
The writing is on the wall.
Ha-ktovet al ha-kir
On Thu, 4/2/15, Robert Nickels w9ran@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Subject: [Homebrew_PCBs] Toner refills
Date: Thursday, April 2, 2015, 3:25 PM
the toner transfer
inadequate.
appears mottled
though I use the
undercut and
maxxed-out as far
as settings go.
problems are
on paper I
fraction of the
sells for $235).
which would give
refills and
the new HP 29X?
Thanks and 73,
Bob W9RAN
#yiv3585390643 #yiv3585390643 --
#yiv3585390643ygrp-mkp {
0;padding:0 10px;}
#yiv3585390643 #yiv3585390643ygrp-mkp hr {
border:1px solid #d8d8d8;}
#yiv3585390643 #yiv3585390643ygrp-mkp #yiv3585390643hd {
0;}
#yiv3585390643 #yiv3585390643ygrp-mkp #yiv3585390643ads {
margin-bottom:10px;}
#yiv3585390643 #yiv3585390643ygrp-mkp .yiv3585390643ad {
padding:0 0;}
#yiv3585390643 #yiv3585390643ygrp-mkp .yiv3585390643ad p {
margin:0;}
#yiv3585390643 #yiv3585390643ygrp-mkp .yiv3585390643ad a {
#yiv3585390643 #yiv3585390643ygrp-sponsor
#yiv3585390643ygrp-lc {
font-family:Arial;}
#yiv3585390643ygrp-lc #yiv3585390643hd {
margin:10px
#yiv3585390643ygrp-lc .yiv3585390643ad {
#yiv3585390643 #yiv3585390643actions {
#yiv3585390643 #yiv3585390643activity {
#yiv3585390643 #yiv3585390643activity span {
font-weight:700;}
#yiv3585390643 #yiv3585390643activity span:first-child {
text-transform:uppercase;}
#yiv3585390643 #yiv3585390643activity span a {
#yiv3585390643 #yiv3585390643activity span span {
color:#ff7900;}
.yiv3585390643underline {
text-decoration:underline;}
#yiv3585390643 .yiv3585390643attach {
0;width:400px;}
#yiv3585390643 .yiv3585390643attach div a {
#yiv3585390643 .yiv3585390643attach img {
#yiv3585390643 .yiv3585390643attach label {
#yiv3585390643 .yiv3585390643attach label a {
#yiv3585390643 blockquote {
margin:0 0 0 4px;}
#yiv3585390643 .yiv3585390643bold {
#yiv3585390643 .yiv3585390643bold a {
#yiv3585390643 dd.yiv3585390643last p a {
#yiv3585390643 dd.yiv3585390643last p span {
span.yiv3585390643yshortcuts {
margin-right:0;}
#yiv3585390643 div.yiv3585390643attach-table div div a {
#yiv3585390643 div.yiv3585390643attach-table {
width:400px;}
#yiv3585390643 div.yiv3585390643file-title a, #yiv3585390643
div.yiv3585390643file-title a:active, #yiv3585390643
div.yiv3585390643file-title a:hover, #yiv3585390643
div.yiv3585390643file-title a:visited {
#yiv3585390643 div.yiv3585390643photo-title a,
#yiv3585390643 div.yiv3585390643photo-title a:active,
#yiv3585390643 div.yiv3585390643photo-title a:hover,
#yiv3585390643 div.yiv3585390643photo-title a:visited {
#yiv3585390643 div#yiv3585390643ygrp-mlmsg
#yiv3585390643ygrp-msg p a span.yiv3585390643yshortcuts {
#yiv3585390643 .yiv3585390643green {
color:#628c2a;}
#yiv3585390643 .yiv3585390643MsoNormal {
margin:0 0 0 0;}
#yiv3585390643 o {
font-size:0;}
#yiv3585390643 #yiv3585390643photos div {
float:left;width:72px;}
#yiv3585390643 #yiv3585390643photos div div {
border:1px solid
#666666;height:62px;overflow:hidden;width:62px;}
#yiv3585390643 #yiv3585390643photos div label {
#yiv3585390643 #yiv3585390643reco-category {
font-size:77%;}
#yiv3585390643 #yiv3585390643reco-desc {
font-size:77%;}
#yiv3585390643 .yiv3585390643replbq {
margin:4px;}
#yiv3585390643 #yiv3585390643ygrp-actbar div a:first-child {
#yiv3585390643 #yiv3585390643ygrp-mlmsg {
sans-serif;}
#yiv3585390643 #yiv3585390643ygrp-mlmsg table {
font-size:inherit;font:100%;}
#yiv3585390643 #yiv3585390643ygrp-mlmsg select,
#yiv3585390643 input, #yiv3585390643 textarea {
#yiv3585390643 #yiv3585390643ygrp-mlmsg pre, #yiv3585390643
code {
font:115% monospace;}
#yiv3585390643 #yiv3585390643ygrp-mlmsg * {
line-height:1.22em;}
#yiv3585390643 #yiv3585390643ygrp-mlmsg #yiv3585390643logo {
padding-bottom:10px;}
#yiv3585390643 #yiv3585390643ygrp-msg p a {
font-family:Verdana;}
p#yiv3585390643attach-count span {
#yiv3585390643 #yiv3585390643ygrp-reco
#yiv3585390643reco-head {
#yiv3585390643 #yiv3585390643ygrp-reco {
#yiv3585390643 #yiv3585390643ygrp-sponsor #yiv3585390643ov
li a {
li {
ul {
margin:0;padding:0 0 0 8px;}
#yiv3585390643 #yiv3585390643ygrp-text {
font-family:Georgia;}
#yiv3585390643 #yiv3585390643ygrp-text p {
margin:0 0 1em 0;}
#yiv3585390643 #yiv3585390643ygrp-text tt {
font-size:120%;}
#yiv3585390643 #yiv3585390643ygrp-vital ul li:last-child {
border-right:none !important;
#yiv3585390643
2015-04-02 by camillus blockx
I would try different toners, it is said that brother toner does not work good either. So ask those company's that provide toner in bulk, they have good knowledge about this.
cb
On 4/2/2015 9:25:03 AM, Robert Nickels w9ran@... [Homebrew_PCBs] <homebrew_pcbs@yahoogroups.com> wrote:
as settings go.
the new HP 29X?
Thanks and 73,
Bob W9RAN
Re: Toner refills
2015-04-03 by bebx2000@...
I have used toner from,
http://www.tonerrefillkits.com/
with HP1320 and HP1102W printers. My experience is  that there is no difference between the OEM toner and their refills for PCB transfers.
2015-04-11 by soffee83@...
Thanks for the freezer tip Malcolm. I might try that on my next one. Soaking and rubbing the paper is a minor nuisance, but the toner's adhesion here is typically all or nothing. The areas that stick properly (ideally ALL of the board) are so tough that you'd almost need to scratch into them to get any off, while if there's a spot or two which didn't get the right amount of heat, that toner will almost float right off in the soapy water. Luckily, most of my problem areas are with larger black sections (ground pours,etc.), so I can usually go around and fix them with a paint marker. I'm trying to get in a habit of painting over larger black areas anyhow, as I sometimes get over-etched looking rough spots or an occasional pinhole in the ground pours.
All in all, I have pretty good success with toner PCBs, especially with the finer traces and hatch pattern pours. My iron has been modified with an eighth inch sheet of aluminum JB Welded to the base. The transfer is about three minutes max.
http://i5.photobucket.com/albums/y193/Jidis/rolleriron.jpg
@Bob-  I'm currently on an HP 3150, but spent a long time on a Laserjet 6L. It looks like my most recent cartridge may be from an eBay seller called "Image Warehouse". Their listings say "New Genuine", but I'm pretty sure I've used generics in the past. This cartridge looks like it's under fifteen bucks, but I am of course using ancient parallel port hardware.
Hope you can get things worked out!
