XRX-LM1910 Foil setting? 2014-12-07 by jtmiller47@... Finally getting around to doing some boards and hauled out the 1910 I bought ages ago.I've lost the manual of course. What does the "foil" setting do on the RHS slider? I assume I'll dial the temp to max on the LHS knob.ThanksJim ab3cv
Re: XRX-LM1910 Foil setting? 2014-12-08 by jtmiller47@... Figured it out. Foil setting apparently gets the toner hot enough to act as an adhesive for making foil lettering.I'll use it along with a high temp setting.jim ab3cv
