Homebrew_PCBs
Archive for Homebrew_PCBs.
NC file question
NC file question
2014-11-09 by Boman33
Another question, this time about the PCB drill files.
We are using Protel 99SE and when the NC files are generated the tool number together with the NC data is in the header of the NC file and there is a separate file with the a drill table (.DRR).  The drill table again lists the size and also the plated/non-plated status of each drill size.
I am really surprised that the plated /unplated info is not included in the NC file header similar to the extended Gerber files that are self-contained with all the aperture info in the header.
How is this handled on a practical basis by the PCB houses?  The plated holes need to be drilled in the bare panel as a first step using part of the NC file and then after processing finally as the last step the NC file has to be used again to drill the unplated holes.
Do they manually have to split the NC file for the two steps?
Is there software available to automatically split the NC file?
What do other companies and PCB software do?
I am trying to standardize as much as possible the PCB process to make it easy for all parties and with as few chances as possible for creating errors.
Thanks in advance,
Bertho
