Homebrew_PCBs
Archive for Homebrew_PCBs.
[Homebrew_PCBs] PCB Drill Instructable
Re: [Homebrew_PCBs] PCB Drill Instructable
2014-09-18 by Harvey White
On Thu, 18 Sep 2014 12:07:12 -0400, you wrote:
>I've just uploaded my Instructable on how I implemented a pcb drill
>using a USB microscope. It uses an inverted configuration as per
>Harvey White (attribution given in the Instructable).
Thanks for the attribution. Interesting way to invert the drill press
itself, I hadn't thought of that. Since mine's a bit more
complicated, it's not as easily made without machining tools.
Well done.
Harvey
><http://www.instructables.com/id/USB-Microscope-Guided-PCB-Drill/>
>Mark Lerman
2014-09-18 by Mark Lerman
Thanks. Now I want to see how good a double sided board I can make.
Mark
>Well done.
>Harvey
> >Mark Lerman
>Posted by: Harvey White <madyn@...>
>http://groups.yahoo.com/group/Homebrew_PCBs
>Yahoo Groups Links
I found that the following helps:
1: assuming EAGLE (anything else will be similar), where the bottom
layer can be printed directly, and the top layer must be mirrored to
print....
Print the bottom layer long axis with the length of the paper, not the
width (print on the 11 inch axis). Do not mirror, do not reverse.
Print the top layer long axis with the length of the paper. Mirror
(required) but also reverse. This puts the same areas of the board on
top of each other. May help to minimize printer distortions.
Use stiff pins (I use push in map pins and a drill which almost
exactly fits them) to align the boards. The less wobble the better.
Practice a few holes with the drill press before you drill the
alignment holes, those are critical.
Best of luck.
Harvey
>Mark
>>Well done.
>>Harvey
>> >Mark Lerman
>>Yahoo Groups Links
