Homebrew_PCBs
Archive for Homebrew_PCBs.
What size drill bits ?
2014-09-12 by alan00463@...
Getting ready to make my first PCB with through-hole parts.    What diameter s of carbide drill bits do I need for drilling holes and how many?
Thanks, Allan
Re: [Homebrew_PCBs] What size drill bits ?
2014-09-12 by James
For components,  0.8mm, 1.1mm, 1.4mm  covers most stuff, mostly 0.8mm.
As for carbide... if you have a (good) drill press, fine, if you are doing it by hand, I'd suggest starting with standard HSS bits, carbide is brittle, very easy to snap if you put any side-load on them.
On Sat, Sep 13, 2014 at 11:10 AM, alan00463@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
Thanks, Allan
2014-09-13 by alan00463@...
Thank you, James.
I don't have a drill press yet, no, but I do have a Proxxon IB/E high speed electric rotary milling tool.   I was thinking of getting a Proxxon Micromot MB 140/S drillstand for it, unless I find a regular drill press cheaper.    Even then,  a cheap drillstand might be a gamble as to how well it drills PCB material.
2014-09-13 by Harvey White
On 13 Sep 2014 11:56:44 -0700, you wrote:
>Thank you, James.
You don't want it to wobble from side to side at all. You may
consider doing the following:
1) elevate the board on a platform with a 1/4 inch hole in it.
2) light the board from above
3) have an optical crosshair and eyepiece focused on the bottom of the
board. I'd suggest using a 45 degree mirror.
4) have some sort of dust collector on the top
5) use a BB gun sight with the little red dot for the bottom sight
alignment if it works. The dot can be adjusted to match the exact
location of the hole you'll drill.
This way, you position the board over the cross hairs, then just
drill. If you ever have to align top and bottom boards, this makes
the alignment easy when you do the patterns first and glue the boards
together.
Harvey
Re: What size drill bits ?
2014-09-14 by Paul Alciatore
Generally you go by the size of the leads on the components. You want
a drill that is about 5 to 10 percent larger. But at least a minimum
of 0.002" to 0.004" larger in any case.
Specific sizes: Many components, including DIP packages, will be OK
with a #65 - #72, or a 1/32" or a 0.8mm. Half Watt and larger
resistors will need larger sizes. Capacitors are all over the map so
a 3/64", #55 - #60, or a 1.2mm would be a good second size. Beyond
that, you just have to measure your component leads. And do it BEFORE
making the board unless you want to make it twice.
Carbide may not be the best choice for your first efforts. Carbide
will break very easily so if you are using a hand drill or a drill
press with any amount of play, you may snap the small diameter ones
quickly. I would start with HSS (High Speed Steel) bits and work my
way into carbide after some experience. A good HSS bit can last for
many dozens, even hundreds of holes, even in fiberglass epoxy. And
you can buy several HSS bits for the price of one carbide one.
Re: [Homebrew_PCBs] Re: What size drill bits ?
2014-09-14 by Jim Pruitt
How does one resharpen bits this small? Or do you?
Thank you.
Jim Pruitt
From: Paul Alciatore palciatore@... [Homebrew_PCBs]
Sent: Saturday, September 13, 2014 8:30 PM
Subject: [Homebrew_PCBs] Re: What size drill bits ?
2014-09-14 by Jean-Paul Louis
Paul,
I will disagree with your statement of 2 to 4 mils above lead diameter. For the past 40 years, the standard play for through hole has been a minimum of 7 mils in order to have tin/lead solder flow easily and make a good solder joint. Lead-free solder flow less easily than tin-lead, so I would use at least 8 mils over the lead diameter.
But that is just what the industry is saying (check IPC recomendations), you might know better.
Jean-Paul
AC9GH
On Sep 13, 2014, at 11:30 PM, Paul Alciatore palciatore@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
2014-09-14 by Rafał Mróz
Proxxon rotary tool and proxxon drill stand are perfectly adequate for drilling pcbs with carbide bits. The runout of the tool is small enough not to break the bits.
14 wrz 2014 18:01 "Jean-Paul Louis louijp@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com> napisał(a):
Paul,
Jean-Paul
AC9GH
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBs
Yahoo Groups Links
<*> To visit your group on the web, go to:
    http://groups.yahoo.com/group/Homebrew_PCBs/
<*> Your email settings:
    Individual Email | Traditional
<*> To change settings online go to:
    http://groups.yahoo.com/group/Homebrew_PCBs/join
    (Yahoo! ID required)
    Homebrew_PCBs-digest@yahoogroups.com
    Homebrew_PCBs-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
    Homebrew_PCBs-unsubscribe@yahoogroups.com
<*> Your use of Yahoo Groups is subject to:
    https://info.yahoo.com/legal/us/yahoo/utos/terms/
2014-09-14 by craigl2@...
Generally people don't resharpen small drills. However I have seen several comments on the internet claiming that new, good quality, bits from reliable suppliers are not as sharp as they could or should be. If you want to try resharpening bits of this size do a Google search for "wishbone sharpener"
Craig
2014-09-14 by Leon Heller
Mega Electronics supplies resharpened carbide drills. They work just as
well as brand new ones, and are quite a lot cheaper.
Resharpening carbide drills is difficult at home.
Leon
Leon Heller
G1HSM
2014-09-15 by cs6061@...
Allan,
First off don't buy Carbide drill bits if you are hand drilling the holes.  The carbide is so brittle that you will snap them off on the first hole.   Buy high speed steel, they have some flex and don't snap as often.  However they will become dull much faster.  The good news all you need is a small fine bench stone to freshen up the cutting edge.  Only takes a few strokes at the correct angle (not running of course).   I have a little fine pocket stone about  1" x3" x .5" for the task.   To use carbide you really need a very rigid drill press,  even a slight side load will snap them.
What I use is a small  1" dia x 2.5"  long brush DC motor that came out of some old piece of military gear (ie has real ball bearings and a metal case)  The shaft is coupled to a small pin chuck.  I hand hold it when drilling like you would a Dremel but because its much smaller its easy to hold in the palm of your hand with two fingers an you thumb.  I run it at 30V with foot switch, the switch shorts the motor out when released.  The result is the motor runs very fast and stops very quickly.  The 30V is not a problem because the foot switch modulates the motor on and off for each hole so the average power is lower than you would expect.    Because the motor is stopped when going to the next hole the bit doesn't  want to walk as with a Dremel.  Center the bit on the hole hit the foot switch and the hole is through in a fraction of a second, foot off the switch and the bit is stopped for positioning to the next hole.  Works great.   It helps if the pads have a small hole in the copper from the artwork/etching.  This helps assure the drill is in the center of the pad.
Photo if the link works: PCB_Stuff
Craig
2014-09-15 by DJ Delorie
I have a box each of 13, 26, 35, and 43 mil (I think those are the right
numbers) carbide PCB drills. That plus a set of standard twist-drills
in letter/number/fraction sizes for weird holes.
The 13s are for vias (28 gauge brass wire is perfect for hand-soldering
these)
The 26s are for small parts (1/4w resistors, through-hole ICs, etc)
The 35s are for larger parts and sockets
The 43s are for soldering wires to the board (22ga etc).
As for drilling, I use a dremel on a custom stand for small boards:
http://www.delorie.com/pcb/dremel-stand/
or my CNC machine for big ones:
http://www.delorie.com/photos/cnc/
2014-09-15 by TheRojecas .
I found that Dremmel sell this set (see photo) that has all the standards
size drill bits of PCB for through-hole parts, including connectors and
headers ...
best regards,
TheRojecas
2014-09-12 18:10 GMT-05:00 alan00463@... [Homebrew_PCBs] <
Homebrew_PCBs@yahoogroups.com>:
> Thanks, Allan
2014-09-15 by Jim Wood
DJ - That is a VERY cool stand!! BRAVO
On Mon, Sep 15, 2014 at 12:43 PM, DJ Delorie dj@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
these)
Jim Wood
303-638-0302 (cell)
2014-09-16 by Slavko Kocjancic
> these)
> Posted by: DJ Delorie <dj@...>
That's nice stand, but by design they have side motion too. The tool
doesn't go straight down but in radius (12") of a circle. But of course
that's 100% beter than a dremel in hand. This kind of drills (at least
chinese copy) come badly balanced some time. that's a reaon why you have
vibrations...
Slavko.
2014-09-16 by DJ Delorie
Even if it were a perfect circle, a 0.25" plunge (about twice my normal)
on a 12" radius means it's offset by only 2-3 mil. I think the amount
of slop in the whole system is more than that, esp in the runout of the
bit itself. A normal plunge would be way less than the runout.
Plus, because there's two beams, at least the dremel is still vertical
as it plunges - it's not itself rotating about a point 12 inches away.
But either way, the results are good - I rarely break drill bits, and
usually when I do it's because of something stupid I did (like drop
them) and not the drill press.
2014-09-17 by alan00463@...
Thank you, Craig, and DJ, and Harvey, for showing me your setup's.    Now I realize that addressing the ergonomics of drilling holes will be worth my while if I decide to make more than one board.    Since my Proxxon rotary tool is AC powered, I will probably hook it up to a solid-state relay controlled by a footswitch so I can rapidly switch it
on/off.
2014-09-17 by Harvey White
>on/off.
Hmmm, don't. <grin> I tried the solid state relay approach, and it
works mostly. The tool does not completely stop, but vibrates just a
little. I'd picked up a transformer run 12 volt tool, and that works
with a solid state relay. I think you need a minimum load on a solid
state relay, and what the controller in the AC proxxon presents is not
load enough. I'd go with a simple old relay.
You could easily get a heavier duty footswitch and just run the tool
directly without even a relay.
Mine is controlled by the processor that does the drilling cycle.
The main thing is that if you want to do accurate double sided boards,
the accuracy of your alignment holes is absolutely critical.
Harvey
