Homebrew_PCBs
Archive for Homebrew_PCBs.
darkness requirements for UV PCB handling?
2014-09-01 by mattmoose1969@...
Just wondering how dark the handling space should be, when preparing a fresh UV PCB after removing the protective film.
I try to ensure that no light whatsoever reaches the board until the UV box is switched on. What can you realistically get away with, in your experience?
Matt
Re: [Homebrew_PCBs] darkness requirements for UV PCB handling?
2014-09-01 by Leon Heller
> experience?
I've never had any problems in ordinary room lighting.
Leon
Leon Heller
G1HSM
2014-09-02 by Randall Morgan
Most in-door lighting does not produce enough UV to cause an issue. However, if you have one of those full-spectrum or daylight lamps beware. I actually have used my daylight desk lamp to expose board. Also Halogen lamps may produce measurable amounts of UV so I suggest turning them off. Otherwise, normal room lighten is fine. Even during daylight hours as most home windows filter most of the UV out of sunlight coming through the windows.
On Tue, Sep 2, 2014 at 2:08 PM, DJ Delorie dj@... [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
I usually just unscrew the one bulb over the bench and the remaining
light in the basement doesn't seem to affect it significantly.
If you ask me if it can be done. The answer is YES, it can always be done. The correct questions however are... What will it cost, and how long will it take?
2014-09-03 by Harvey White
>> beware.
>Yeah, all my basement lights are CF "daylight" bulbs. Dunno if they're
>full spectrum, but they're not the usual yellow-y lights.
Don't use them then, you want incandescent not fluorescent, or if you
want fluorescent, then use yellow or red. A decent bug lamp (of the
yellow type) should be fine. A darkroom safe lamp will work as well.
Harvey
2014-09-03 by DJ Delorie
"Harvey White madyn@... [Homebrew_PCBs]"
<Homebrew_PCBs@yahoogroups.com> writes:
Thanks, but I'll keep using them. Most of the basement has another
purpose that's best served by daylight bulbs. Like I said, I remove the
one at the UV area when I'm doing UV, and I haven't had any problems.
2014-09-04 by Harvey White
OK, slight misunderstanding here.... "don't use them for the
photoresist".
Darkrooms, for instance, have a safelight lighting system and a
regular lighting system for tank developing, setting up trays, etc.
Harvey
2014-09-04 by DJ Delorie
> photoresist".
Right. I have "regular" lighting for most things, and "unscrew the
bulb" lighting for UV-sensitive steps ;-)
But the *other* bulbs in the basement, which are also daylight bulbs,
are ON when I'm doing UV stuff, and they don't seem to cause problems.
I only unscrew the one right at the UV area.
