[Homebrew_PCBs] Question for Harvey White
2014-08-15 by Mark Lerman
Archive for Homebrew_PCBs.
2014-08-15 by Harvey White
>Hello Harvey,OK, in short. The optical stuff is a 12 volt/24vac camera with almost
>I'm interested in getting more information on your drilling setup,
>mostly the optical stuff - camera, software, monitor. What supplies
>the reticule image for the crosshairs?
>Thanks.
>Mark
2014-08-16 by Mark Lerman
>On Fri, 15 Aug 2014 12:52:18 -0400, you wrote:
> >Hello Harvey,
>any lens that works well. You want to move it out away from the CCD
>so that you have the equivalent of a closeup extender.
>That goes to a standard color monitor. This is an LCD monitor that I
>found (runs off 12 volts DC), and has an overlay with a graticule on
>it. I've been tempted to make it more complicated by adding a
>crosshair generator, but that'd be another PC board and some video
>work. The graticule is easier. Just make the pattern on a
>transparency and put it over the monitor itself. Almost any old TV
>would work.
>The software is custom, and is a simple Z axis setup. There are two
>pushbuttons (green/red) and a rotary encoder with a push switch
>(Electronics goldmine sold them). There's an end travel (and top
>travel) led sensor.
>Boot up, the display says to push green to home. That homes the drill
>and runs it up to the rest position. pushing the footswitch (or the
>green pushbutton) starts a drill cycle, three speeds possible, up to
>the drill top position. At that point the drill retreats back to the
>rest position and turns off the Proxxon tool (solid state relay, works
>better with the 12 volt model and transformer).
>Pushing the red button puts the drill at the top position, which is
>where I can change the bit from the top.
>Pushing in the rotary switch/encoder put it into an adjust mode, where
>I can set the rest and top positions (stored in the processor's
>eprom).
>Basically, the software is not all that complicated, but does rely on
>an infrastructure of display drivers (it's a smart display that I
>built), a modified keyboard driver package, and a few other bits and
>pieces.
>Physically, the camera is mounted on a PACE hot air station stand (I
>managed to find two for not so much money), which gives me an
>overarching arm for the camera. I can move it up and down to focus
>the camera and move it out of the way for drill change. I suppose
>another enhancement would be to put a stepper drive on that.
>You will have to align the camera center point to the tip of the
>drill. In my case, the adjustment is entirely mechanical, with the
>camera swinging left/right on the mounting screw, but tilted (spring
>used on screw) forwards/backwards as needed. That's a trifle awkward,
>and the electronic crosshair generator would be better. That would
>require a small CPLD, a sync separator, a synchronized pixel clock,
>and some counters. Ideally, the graticule has ticks on both axis
>lines, since that helps align the center of large holes.
>The smallest hole I drill is 0.021 for a via, and I estimate that I
>can repeat that hole to within 0.002 inches roughly. The size of that
>hole on the monitor is the critical part.
>You'll want to backlight the board. Red light may be most useful, but
>I haven't experimented with that yet.
>Hope that this helps.
>Harvey
> >Thanks.
> >Mark
>Posted by: Harvey White <madyn@...>
>http://groups.yahoo.com/group/Homebrew_PCBs
>Yahoo Groups Links
2014-08-16 by Harvey White
>Thanks, Harvey, for the detailed description - Very interestingI do double sided boards, with the boards made from two .021 boards
>setup. One of these days I'll work on something similar, though I
>rarely drill a lot of holes. I use almost exclusively smt and usually
>make single sided pcbs using zero ohm resistors as jumpers.
>Mark
>> >Hello Harvey,
>>would work.
>>travel) led sensor.
>>eprom).
>>pieces.
>>Harvey
>> >Thanks.
>> >Mark
>>Yahoo Groups Links
>epoxied together (use 1 hour epoxy!). Alignment is very critical and
>the drilling setup (finally!) makes that work a lot better. Since I'm
>doing 64/100/144 pin TQFP chips, I can't live with the luxury of
>exclusively resistive jumpers.
>Latest project involves a graphics panel driver with an S1D13781
>graphics chip (Epson, anyone wanting to use it please talk to me,
>there are some non-obvious things you need to do to make it work). an
>Xmega, a touch panel controller, -24 volt supply, I2C communications
>(dual channel).
>Harvey
> >Mark
> >> >Hello Harvey,
> >>would work.
> >>travel) led sensor.
> >>eprom).
> >>pieces.
> >>Harvey
> >> >Thanks.
> >> >Mark
> >>Yahoo Groups Links
>Yahoo Groups Links
2014-08-16 by David Bobb
I think the thing that would ease alignment of vias isn't just via size, but via landing size.
David Bobb -- N5MUX
On Aug 16, 2014 10:12 AM, "Mark Lerman mlerman@... [Homebrew_PCBs]" <Homebrew_PCBs@yahoogroups.com> wrote:
A little out of my league <smile>. My needs are simpler, though I
often do use TQFP packages. Those, however, often need vias under the
chip, which I can't do. To make alignment less critical I would use
larger vias so you can't "miss" as easily.
Mark
>(dual channel).
>Harvey
> >Mark
> >> >Hello Harvey,
> >>would work.
> >>travel) led sensor.
> >>eprom).
> >>pieces.
> >>Harvey
> >> >Thanks.
> >> >Mark
> >>Yahoo Groups Links
>Yahoo Groups Links
>Well....
>Mark
>>(dual channel).
>>Harvey
>> >Mark
