Homebrew_PCBs
Archive for Homebrew_PCBs.
updated my laser photoplotter
2014-05-01 by <elson@...>
Well, I finally got around to updating the laser photoplotter I built in 1996.  it was still
running on the creaky Cyrix-CPU ISA-bus PC with a DMA card.  I was worried about
how much longer that PC would still run.
I replaced it with a Beagle Bone, and used the PRU component of that processor
to emulate the DMA card in the PC.  I had a few software bugs that were
embarrassingly hard to find, but it now works just fine.
It does 1000 x 1000 DPI and is VERY accurate, I have made solder stencils
with it that match within a couple thousandths of an inch over an entire
8 x 12" PC board fabbed in China.  (I use it mostly for making the master
artwork to etch solder paste stencils, now that PC boards are so cheap
from China.)  Plotting speed is 0.6" per minute, and it can do up to
20 x 20" films.
See
Homemade Laser Photoplotter   for more info.
Jon
RE: [Homebrew_PCBs] updated my laser photoplotter
2014-05-01 by Jeff Heiss
Have you tried printing directly to photoresist?  Are there pictures of the results?
Jeff
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com] On Behalf Of elson@...
Sent: Wednesday, April 30, 2014 11:21 PM
Subject: [Homebrew_PCBs] updated my laser photoplotter
20 x 20" films.
See
General view of the Photoplotter. Drum drive motor and encoder are at upper right. Stepper motor is at lower right. Optical carriage is now about 1/3rd of the way t...
Preview by Yahoo
Jon
2014-05-01 by Boman33
I remember your laser plotter from you original posting.
A great project!
From: elson@...   Sent: Wednesday, April 30, 2014 23:21
20 x 20" films.
See
2014-05-01 by Malcolm Parker-Lisberg
Funny how the original Edison Bell phonograph gets updated and changed from sound recording to light recording.
Malcolm
I don't suffer from insanity I enjoy it!
Mene, mene, tekel, upharsin
The writing is on the wall.
Ha-ktovet al ha-kir
On Thu, 5/1/14, Boman33 <boman33@...> wrote:
Subject: RE: [Homebrew_PCBs] updated my laser photoplotter
Date: Thursday, May 1, 2014, 4:42 AM
I remember your
laser plotter from you original posting.A great
project!
was stillrunning on the creaky Cyrix-CPU ISA-bus PC
with a DMA card.  I was worried abouthow much
longer that PC would still run.I replaced it with a
processorto emulate the DMA card in the PC.  I
had a few software bugs that wereembarrassingly hard
to find, but it now works just fine.It does 1000 x
stencilswith it that match within a couple
thousandths of an inch over an entire  8 x
for making the masterartwork to etch solder paste
stencils, now that PC boards are so cheapfrom
can do up to20 x 20" films.SeeHomemade Laser
Re: updated my laser photoplotter
2014-05-01 by <cs6061@...>
John,
Glad you are still playing with it, I remember when you did the first posts.  A photo plotter is still on my to do list of projects.   I managed t scrounge up a large photo copier drum that should work well for the photo plotter drum once I make some end pieces.
Are you using a PID servo loop to run your motor at fixed speed?
I am thinking of using a Blue Ray  UV laser diode instead of the red laser to allow use of blue sensitive film and a red room safety light.  Though I have not looked at the availability of sheet film these days.
What sort of lens did you end up using and did you do any spot rounding?
What did you use to drive the pixel video to the laser diode?  I was just thinking of shunting out the lasers current source supply with a FET or transistor across across the laser diode.
Craig
2014-05-03 by <elson@...>
No, there is a classic phase locked loop using the 4044 phase detector, but the "oscillator"
is a DC motor turning an encoder.  So, the 4044 feeds an active filter and then a
boosted op-amp driving Darlington transistors to run the motor.  The motor is a
Yaskawa motor made for moving the print head back and forth on a Qume
daisy wheel printer from ages ago.  A nice, smooth motor optimized for low
speed operation.  I had to adapt a much better encoder on the back of it,
though.  So, the encoder produces 1024 pulses/rev (I only one one of the
quadrature channels), and then multiply this with a 74LS297 digital PLL
by 20 to generate 20480 pulses/rev.  The encoder index pulse is used to
gate the stream of pixel clock pulses that clock the bits into the laser.
The motor/drum spins at 600 RPM.
>> I
I finally used up my stock of Agfa red laser film and went to Kodak PRD
film.  I think this is used in the typesetting industry.  The old Agfa film
was 7 mil, this stuff is 3 mil, so I had to change the shim on my drum
to bring the diameter of the emulsion out a little more to get it at that
20.480" circumference.  Just luckily, I had the right thickness mylar
sheet left over from the bad old days with the crepe tape on mylar
sheets!  These phototypesetter films are made for red lasers and
HeNe lasers.  I buy mine on eBay, there are a bunch of guys
selling unopened film that is nearing the expiration date.  if you keep the
stuff in good conditions, you can use it DECADES past that date.
It is a 13 mm multi-element lens, probably quite similar to the objective
lens in a microfiche reader.  But, the optical system is more complicated.
Right in front of the laser, I have a 3 mm sphere lens glues into a
disc with a hole in it.  Right at the front of that, I have a piece of
aluminum foil with a pinhole in it, to block off the light coming through
the edge of the sphere.  This assembly is at one end of about a 4" tube
from the objective lens.  About in the middle of the tube is a double-concave
lens.  This makes the spot size smaller.  Well, the spot size is so small
that this lens may not be necessary.  I have to actually defocus the
thing slightly so that I don't leave gaps between the raster lines.
>> What
The pixel clock is 5 us (200 KHz) so it is not critical stuff at all!
I use a 2N2222 and a series resistor, and a little trimpot to set the
current.  Not a closed-loop system.  (I do have a closed-loop
analog driver that can be used with gray-scale film to record
images, it uses the sense diode in the laser package.)
Jon
Well, this sort of mechanism has been used for image printing and scanning for a
LONG time.  Early weather FAX machines did this starting around WW-II, I
think.  Newspapers had halftone converters that used a similar drum
scanning system back in the '30s, I think.
Jon
No, it would take a much more powerful laser at a shorter wavelength to print directly
to the resist.  And, this system requires the film be wrapped around a drum to
record on it.  So, while now possible with these new blue lasers, it would take
a comletely different machine.
Jon
2014-05-04 by <elson@...>
Well, not playing with it at all.  It has been one of the major tools in my shop for
18 years, and I need to keep it running, that's why I was worried the ancient
computer would croak one of these days.  While updating the computer, I
took the opportunity to fix a bunch of stuff that I'd always wanted to do
from the beginning.  Once I got the basic unit running 18 years ago, I
was just a little afraid to do too much and break something.
I never had the home switch, so I had to wind the carriage back to the
beginning manually.  I now have a home switch and it automatically runs
back to home before starting a plot.
I never had the PLL lock sensing set up, so I just had the PC wait for
a long time and assumed the PLL would be locked.  Now, the Beagle
Bone senses the lock indication and waits until it shows lock for a
continuous second before starting the plot.
Another project I ought to do is build a nice aluminum housing with
a hinged cover and light-tight seals.  Right now, I put a cardboard
box with the interior spray painted flat black over it when it
is plotting to keep the film from fogging.  It works, but it is
seriously ugly!
Jon
