good media for toner transfer
2014-03-09 by KPL
Looks like most here are using photo process, but in case anybody
still uses toner transfer, I can recommend a really excellent
materials, available on ebay. Last time I ordered two items from
different sellers to try, and both of them work well. Basically a 100%
transfer, without anything left on paper.
https://www.dropbox.com/s/i90kd7rx9gyjho8/pcbtest1.jpg
http://www.ebay.com/itm/400458893126
http://www.ebay.com/itm/251461615744
One of them was packaged much better than the other, but I am not sure
which of them :(
I have no connection to sellers, just a happy customer.
I have been using similar plastic-coated paper for years, but all the
last I had ordered did not work, until now.
I'm using modified laminator, then the board is cooled, and paper just
peeled off. Then it is etched in FeCl.
KPL
Re: good media for toner transfer
2014-03-15 by <Tda7000@...>
Yours looks like it came out good. I saw some similarly priced stuff on eBay which was yellow, but I never tried it.
I do most of my boards with the photo-resist process now, toner-transfer was good to start with but it's hard to get a printer that does big area fills etc without leaving little holes everywhere. Toner-transfer is fast and easy and cheaper on boards with medium\thin traces and no fills, though.
I might buy some of that one you linked to and keep it handy ;)
---In Homebrew_PCBs@yahoogroups.com, <kpl.listes@...> wrote :
which of them :(
KPL
Re: [Homebrew_PCBs] Re: good media for toner transfer
2014-03-15 by KPL
I had several of those yellow ones, most of them did not work at all. Some of white papers did not work very well too, seems like the plastic coating was not uniform.
---In Homebrew_PCBs@yahoogroups.com, wrote :
which of them :(
KPL
KPL
2014-03-15 by K M Zahidur Rahman Samrat
which of them :(
KPL
KPL
2014-03-19 by self self
I agree this stuff works but the toner is thin, often with micro holes which can cause the etching to leave a sand like effect. A work around is to apply heat at a lower temperature and reduce pressure. Of course the PCB must be dust free and really clean.
On Saturday, March 15, 2014 11:57 AM, K M Zahidur Rahman Samrat <kmzahid.samrat@...> wrote:
get on my blog of : smartelectronicslab.blogspot.com
 fills, though.
>>Hi,
>>which of them :(
>>KPL
>KPL
