Homebrew_PCBs
No plating through-hole plating
2014-02-04 by Steve Greenfield
I wonder if LPKF will sell this to people who don't own one of their machines.
http://www.lpkf.com/products/rapid-pcb-prototyping/through-hole-plating/chemical-free/index.htm
Basically, you squeegee the paste through the holes, then vacuum them out, then bake.
Steve Greenfield AE7HD
http://www.linkedin.com/in/stevenjgreenfield
RE: No plating through-hole plating
2014-02-05 by <dgminala@...>
The website for their US operations is www.lpkfusa.com. Click the Store link and look for the ProConduct and the EasyContac products. Quite expensive to get set up. IMHO, unless you regularly have to make prototype boards, and need fast turnaround, you're much better off by using hollow rivets for the vias and component through-holes, or by going to prototyping services such as ExpressPCB or one of the many off-shore producers.
For instance, for the ProConduct paste & vacuum system, you'll start off with a $2000 bill, and go from there. The paste and film consumables are pretty costly as well.
Cheers,
Dave M
Re: [Homebrew_PCBs] RE: No plating through-hole plating
2014-02-08 by cheater00 .
Isn't the paste just solder paste? Couldn't you do the same thing with the right solder paste and a simple vacuum cleaner? I think the idea is great but we need to hack it :-) so to speak.
D.
Cheers,
Dave M
2014-02-08 by Cecil Bayona
I would think that solder paste once heated would bead away from the
insulated whole just like it does on the top of the board.
You would need something that would really stick to the fiberglass
and not let go, like conducting epoxy
>D.
><http://www.lpkfusa.com>www.lpkfusa.com. Click the Store link and
>Cheers,
>Dave M
Cecil - k5nwa
< http://thepartsplace.k5nwa.com/ > < http://www.softrockradio.org/ >
Never take life seriously. Nobody gets out alive anyway.
I do not know that this is true. Have you tried? Maybe it being a hole
makes the difference?
I guess following your logic it might also be a different alloy. I
wonder what this does to the stability of the solder in the soldered
assembly.
D.
2014-02-08 by Harvey White
Hasn't seemed to work when I've tried it. I normally use either
soldered eyelets or thin wire and solder. Solder "wets" metals to
adhere, there's nothing in there to adhere to.
>assembly.
I think that it's a conductive epoxy, so there's a limit to how good a
conductor it is. People have used windshield heating element repair
compound, no idea of how well it works.
I've seen graphite used, but that's before copper plating.
Harvey
>D.
Solder has a huge surface tension, which tends to pull it onto a
blob, have you seen how if you put too much paste it all pulls back
into the pad or if you put a line of solder paste across some pins it
all pulls back so there is only solder on the pins, the same thing
will happen with solder in a hole with no metal in it. It has nothing
to adhere to so surface tension pulls on it and away from the hole to
the trace where the solder is adhering.
One does not want the holes plugged up that is why a vacuum cleaner
is used to only leave a thin layer stuck on the walls, so it must be
either an exotic alloy paste or a conductor with some kind of glue
like binder to make it stick to the walls. I'm thinking that a silver
compound like the one used to repair traces might work.
> >assembly.
>Harvey
> >D.
Cecil - k5nwa
Re: No plating through-hole plating
2014-02-11 by Paul Alciatore
I wonder if adding some powdered metal that does not melt at
soldering temperatures to the solder paste would help it to coat the
walls of the via. It may be a question of finding the right alloy and
the right particle size. You may need different sized particles for
different size vias.
Re: [Homebrew_PCBs] Re: No plating through-hole plating
2014-02-11 by cheater00 .
Interesting. What's your reasoning why that would help?
Cheers,
D.
2014-02-11 by psykhon@...
Silver and Cooper powder or flask with solder mask a the adhesive/aglutinant
Both sides should be laminated with something "peelable" prior to drilling
Lots of testing to find the right proportions,but I guess more than 90% metals
> Cheers,
> D.
Pardon me?
Sorry, I meant to reply to Paul mainly and also to the general discussion
> Pardon me?
soldermask as glue will work because its made to endure wave and reflow solder, its stands +-280 celcius without any damage
--- In Homebrew_PCBs@yahoogroups.com, <indigo_red@...> wrote:
> I like that idea: a higher temp powder mixed in might keep surface tension from wicking the solder out of the via to the surface conductors during heating. hmmm...
