Homebrew_PCBs
Archive for Homebrew_PCBs.
Toner transfer question
2013-12-30 by Mukundan Parthasarathy
I'm starting out to make my first prototype pcb and I need help. I have decided to try the toner transfer method because that seems the easiest (no need to get special photo-sensitive chemicals, no UV etc.) If this doesn't work for me I'll try another method. I'm a hobbyist who has hopes of making products in the future that sell and make me pots of money. But for now I need some basic information. My understanding of toner transfer is a bit hazy, and this is how I think it works:
1) One prints the routed pcb tracks on plain paper on an ink-jet printer.
2) Place it on the copper-clad pcb surface.
3) Pass a hot iron on the paper (or use a laminator.)
4) Then etch with cupric chloride solution.
Have I over-simplified the process, or have I missed something?
I have seen many posts on vast details about printer types, and laminators etc. on this forum. So if someone can point me at a basic tutorial and a list of main issues to watch out for, I would appreciate very much.
I apologize for putting this basic question to a forum that is clearly highly advanced in this subject.
A million thanks to you all in advance.
-Mukundan
One additional question that I have is, I have seen numerous references in this forum to "printing on vinyl". Please enlighten me as to what this "vinyl" is.
-Mukundan
Re: [Homebrew_PCBs] Toner transfer question
2013-12-31 by Harvey White
No, not quite. You use a laser printer (B&W). Plain paper may work,
special kinds of paper (e.g. Pulsar paper) work better. You may have
to experiment with the paper, it will control your results.
Laminator is preferred. Be sure to print in reverse for a top layer,
and print the reversed bottom layer normally.
Pretty much, highly simplified, yes.
Make sure the board is clean before you transfer the pattern. A green
foil (not metallic) laid over the board and run through again will
help seal the toner.
You'll need to figure out whether or not you want to make single or
double sided boards. You may find that the best use for homemade
boards is for prototypes, and it may give you better results to use a
commercial board house for production quantities. That's in the
future, though.
It's a sign style of vinyl that substitutes for the paper. It may
work for you, I haven't tried it.
There's a bit of process tuning to do, most run the paper and board
through the laminator multiple times (I do, with my laminator, 8
passes, 4 paper up, and 4 paper down). It will take you a bit of
experimentation to figure out what is best for your equipment.
However, you do not use an inkjet (you *could*, but printing directly
on the board is likely to be a more advanced topic), you use a laser
printer. An old HP is likely to be available, and good. 1200 DPI is
better than 600 DPI because of the finer resolution ... needed for
fine pitch surface mount chips.
Harvey
>-Mukundan
2014-01-07 by Mukundan Parthasarathy
Thank you, Harvey, for the detailed response. It helped me greatly.
Mukundan
Sent: Tuesday, December 31, 2013 9:28 AM
Subject: Re: [Homebrew_PCBs] Toner transfer question
future, though.
Harvey
>-Mukundan
Re: Toner transfer question
2014-01-07 by Jim
--- In Homebrew_PCBs@yahoogroups.com, Mukundan Parthasarathy <mukundanparthasarathy@...> wrote:
I made some two sided boards a year ago and took pictures:
http://wb8nbs.wordpress.com/category/controller-area-network-2/
was very satisfied with the results.
I have an old Lexmark 4039 10+ laser printer set to "heavy" print. I used coated paper from an old Digikey catalog.
Re: [Homebrew_PCBs] Re: Toner transfer question
2014-01-10 by Mukundan Parthasarathy
Jim,
Thank you very much!  Your tutorial is excellent and the additional links you have provided were most informative. I hadn't realized that there is so much to etching.
Mukundan
Sent: Tuesday, January 7, 2014 8:32 PM
Subject: [Homebrew_PCBs] Re: Toner transfer question
