Homebrew_PCBs
Archive for Homebrew_PCBs.
Color laser printers for toner transfer
2013-12-18 by Steve
Any difference or preference in using a color laser printer versus a
black and white laser printer for toner transfer?
I have a vague recollection of reading somewhere that a black and white
laser printer is best.
Advice?
Thanks.
Steve
Re: [Homebrew_PCBs] Color laser printers for toner transfer
2013-12-19 by <n0tt1@...>
Assuming that both color and black toner print equally
and are both rugged, I would go with the black, simply
because the colored toner is so much more expensive...
at least that's my understanding of it. But YMMV :D)
Charlie
On Wed, 18 Dec 2013 09:38:27 -0500 Steve <steve65@...> writes:
Advice?
Thanks.
Steve
Re: [Homebrew_PCBs] RE: Color laser printers for toner transfer
2014-01-02 by Brian Symons
I recently bought a colour laser.  I found that it can't handle any thick material at all because of the way the paper path & several passes works.
That info was buried in the manual & not on the brochures.
It does do nice colour on plain paer though.
I must add that although I have had several lasers, I needed tech assistance to set this one up.
The problem was that control panel settings on the printer will over ride the settings from the computer regardless of what you put in the driver settings.
My printer is a Lanier (Ricoh) SP C240DN / Aficio SP C240DN  -  Same printer different names.
It ws a cheapy on special to see what a colour laser could do because none of our printer suppliers shows print samples any more.
Brian
On 19-December-2013 23:08, leeleduc@... wrote:
Pulsar has some info about color laser printers. Here's the link, info at bottom of page.
http://www.pcbfx.com/main_site/pages/tech_support/miscellaneous.html
