Homebrew_PCBs
Application method for Liquid Soldermask (UV cured ink)
2013-11-25 by James
Soldermask UV cured ink is available on eBay in various colours either
in 10cc syringes or 100g pots.
In theory, you coat the board, cover with plastic, expose to artwork
(pads black) for a couple minutes, and clean off the pads, then
re-expose without artwork for 30-40 minutes.
In practice it can be very frustrating, firstly it has to be exposed
wet, you can't dry it, the type of plastic you cover it with is very
important (bonds to most when cured, you need something it doesn't bond
to), you can't have any air bubbles between the plastic and the ink or
it won't work, getting a smooth finish is tough because it's very
viscous, but you also have to get it very thinly coated because too
thick and it won't work well, then trying to align this whole mess over
your artwork! For small boards, a couple cm on a side, it's not too
bad, but once you're at something like 5x5 then it's a real pain.
Anyway I've been perservering on and off for a few months trying to get
a workable method for using it, and finally, I think I have come up with
something that is actually repeatable. Still needs a bit of practice
but so far this is working.
Supplies:
First you must find the "special plastic". I am using some
self-sealing cellophane gift style bags, I suspect that they are
actually OPP/BOPP ([Biaxially] Oriented Polypropylene), I bought mine
from a local cheap-chinese-junk shop, they look the same as these
http://www.craftumi.com.au/detail.asp?id=128785#prettyPhoto
you know the type of thing I'm sure, perfectly clear and flat, can be
sharply creased, very thin. I just pull them apart along the sides and
cut into two sheets.
Now the artwork, I'm just using laser printed tracing paper, single
sheet.
Some self adhesive transparent contact book covering film.
A glue stick (white/transparent), and some tape.
Process:
Cover your artwork with the contact book covering.
Spread some glue stick on top of the book covering.
Now stick a piece of your special plastic on top smoothly.
Trim one end so it's all the same length there.
Stick your PCB (etched, cleaned) down to your desk (or rather, some
cardboard/paper because it'll get ink on it for sure) lightly so it
won't move about, or if you have some extra length on the PCB you can
hold it there.
Take the prepared artwork and align it over the PCB, tape it down at
the trimmed end so that it now forms a hinge, check you can hinge it up
and down and that it will be aligned when down.
Lift the artwork, and place a bead of ink along the inside of the
hinge, now using something stiff as a squeege gently smooth the artwork
down slowly pushing the bead ahead of the "interface" between artwork
and pcb so that there is no air trapped, ideally you want a little to
ooze out of all the edges. Once it's down use the squeegee to smooth it
out more if necessary and ensure there is an even (as you can be
bothered) coverage.
Carefully remove the board from your bench and expose to UV for a few
minutes (clamping/vacuum framing it probably won't be necessary but if
you do, be gentle or you'll push all the ink out).
Peel off the artwork, wash the board gently with a solvent. Acetone
works very fast (literally wipes away the pads), but a bit too agressive
for the partially cured ink and can mess it up easily, you might have
better luck with isopropyl, or turpentine.
Expose again for a long exposure.
NB: If you have more than 1 of the same board to do, you can clean
off the ink from the special plastic, or peel it off totally if it's too
dirty and stick a new piece to your artwork (the glue stick just holds
it in place lightly, easy to peel off).
Re: Application method for Liquid Soldermask (UV cured ink)
2013-11-26 by Paul Alciatore
I have not heard of this soldermask and am puzzled. You expose it the
first time with the artwork and then expose it again for a lot longer
time without the artwork. I am curious as to how this works. It seems
like it would all just harden. Can you post some links to this that
may explain it better?
RE: Re: Application method for Liquid Soldermask (UV cured ink)
2013-11-26 by <twgray2007@...>
You can find the stuff on EBay, UV Curable Solder Mask, but you won't find any more information than that you see here.  The Chinese shops sell it but don't have any details on the stuff.
The step by step that James gives is essentially correct.  The special plastic is nothing more than celohane and can be purchased by the roll from Walmart in the wrapping paper section.  If you are using plastic transparencies you can dispense with the celophane layer and place it directly on the wet ink.  I have not had to perform the second step of UV exposure of the entire unmasked board though.  After a few minutes of exposure with your transparency mask in place, the ink under the transparency dries.  Any board area with ink uncovered by the plastic will still appear to be tacky.  For some reason the ink under the plastic overlay dries many times faster than uncovered ink.
This stuff works, BUT it is messy.  And, it requires some trial and error to get the ink thickness just right and to get the exposure time just so.  Different colors dry and expose at slightly different rates.
Re: [Homebrew_PCBs] RE: Re: Application method for Liquid Soldermask (UV cured ink)
2013-11-26 by Slavko Kocjancic
When you expose board with mask the ink harden. But if mask isn't full
black (the laser print isn't full black) then there is practice to not
expose too long time as unwanted area may be exposed too. So you just
keep the swet spot when difference exposed/unexposed is big enought to
wash the unwanted ink off. Then you expose developed board again to
fully harden the ink.
Re: [Homebrew_PCBs] Re: Application method for Liquid Soldermask (UV cured ink)
2013-11-26 by James Sleeman
The first exposure is long enough that the areas you want to stay on are
somewhat hard, take it out, remove the artwork, wash off the uncured
pads, then re-expose (without artwork since you have cleaned off the
areas you were masking anyway) to fully cure.
