Homebrew_PCBs
Green foil question
Green foil question
2013-11-18 by <w6nim@...>
Just tried using the green foil - first try (one pass thru laminator) didn't transfer much. 8-10 passes gave 100% transfer, but broadened the traces. Is there a suggested happy medium??
Norm
W6NIM
RE: Green foil question
2013-11-18 by <rtw@...>
I use 3 or 4 times and works good. With laminator heated up good. I wait about 20 minutes to heat up before I do it.
Norm
W6NIM
Re: [Homebrew_PCBs] Green foil question
2013-11-18 by Harvey White
I use two passes, generally results in 100% transfer. However, I've
had runs where the foil absolutely does not adhere, period. That can
mess up a board. Still, the boards are better with than without.
Harvey
>Norm
>W6NIM
