tracing paper, laser and photoresist
2013-11-08 by Kerry Koppert
I have been using tracing paper (Vellum?) and a laser printer to produce transparencies for photoresist. I have some good results, but the large dark areas tend to be less than opaque having a speckled appearance which tends to be reproduced on the copper. I was reading about some spray cans which supposedly darkens the toner pattern (Toner Aide and Casey's toner darkener). Unfortunately I can't find a supplier in New Zealand and if I could it would probably be around $30-$40 a can. However they appear (from their MSDS sheets) to be a mixture of solvents sprayed from a can so I mixed some Acetone and Ethyl Acetate and sprayed this on the transparency from a small mister spray bottle I had. It worked, although the vellum curled up a little.
