Homebrew_PCBs
Diaphragm and peristaltic pumps
2013-09-20 by Robin Whittle
If anyone is looking for diaphragm pumps, such as for vacuum hold-down
of flexible PVC sheet to press a phototool to a PCB for UV exposure, or
maybe for spraying etchant, this eBay seller in Hong Kong has quite a
selection.
The seller's categorized listing is:
http://www.ebay.com/sch/haruyr_kb/m.html
but it can be hard to find the pumps. By using the search facility on
this page, for "pump":
http://stores.ebay.com/haruyr-kb/
quite a variety of pumps can be found:
http://stores.ebay.com/haruyr-kb/_i.html?_nkw=pump&submit=Search
I bought one of these:
http://www.ebay.com/itm/400569532731
Diaphragm Pump Water/AIR Pump 12V DC 400L/H 1.2MPa for Aquarium Fish tank
I haven't tried it for a PVC flexible phototool hold-down system, but I
think it would be suitable. I am only doing small PCBs and with the new
small source UV LED light source, I am happy using glass with foam
behind the PCB.
A search of eBay for "diaphragm pump" turns up 2,525 results and most of
them are too big and expensive for this application:
http://www.ebay.com/sch/i.html?_trksid=p2047675.m570.l1313&_nkw=Diaphragm+Pump&_sacat=0&_from=R40
- Robin
RE: Diaphragm and peristaltic pumps
2013-09-20 by <andrewm1973@...>
bought one of his $17 vacuum pumps to make a new frame a while ago. Looks the part but have not used it in anger yet
selection.
behind the PCB.
- Robin
Re: [Homebrew_PCBs] RE: Diaphragm and peristaltic pumps
2013-09-20 by Todd F. Carney / K7TFC
Go to Instructables and search for "vacuum pumps." There's a lot of projects for various type of pumps, including a reversible tire-pump like piston pump, and a DIY diffusion pump for pulling a very hard vacuum (like interplanetary space kind of vacuum). Lots of different ideas for and sizes of pumps.
Todd
K7TFC / Medford, Oregon, USA / CN82ni / UTC-7 (PDT)
selection.
behind the PCB.
- Robin
2013-09-25 by David Pickering
Thanks Andrew
Just ordered one from your last entry for just over £6, cant go wrong at that price.
Going to mod a manual pump chamber
will let you know results
Regards
Sent: Friday, 20 September 2013, 21:31
Subject: [Homebrew_PCBs] RE: Diaphragm and peristaltic pumps
selection.
behind the PCB.
- Robin
