Expo Drill Stand 14211
2013-09-03 by <v321uk@...>
Archive for Homebrew_PCBs.
2013-09-05 by <arvidj@...>
It appears to be the same as a "PZ541 Vertical Drill Stand".
I do not have either one. Just wanted to pass along an additional set of 'tokens' to Google for information.
--- In homebrew_pcbs@yahoogroups.com, <v321uk@...> wrote:Does anyone here have experience in using an Expo 14211 mini drill stand?
Intended use occasional PCB making.
Is there much 'run out' ?
Would you recommend it ?
I tried searching the group but cant see a text search only a message number search.
Thanks, John G3UGY
Here are some other links that I ran across looking for a solution. Note that this is not an endorsement of any of them. Simply trying to share what little knowledge I have.
Someone who seems to have had experience with the style you were looking at:
http://www.electro-tech-online.com/electronic-projects-design-ideas-reviews/134856-pcb-drill-press-ideas-revisited.html
Other options that I have found:
http://www.vanda-layindustries.com/html/drill_press_plus.html
http://www.megauk.com/pcb_drilling_machines.php
http://shop.prox-tech.com/p/micromot-drill-stand-mb-200
http://www.proxxon-direct.com/acatalog/micromot_drill_stand_mb_140s.html
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_26711_-1
Arvid
--- In homebrew_pcbs@yahoogroups.com, <arvidj@...> wrote:It appears to be the same as a "PZ541 Vertical Drill Stand".
Thanks, John G3UGY
2013-09-05 by John
I
2013-09-28 by <arvidj@...>
As a follow up to this thread ...
I ordered the Jameco Drill Stand Works with Mini Drill (Part 26702) ...
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=26711
Note that I did not order the Miniature Drill 12000 RPM associated with it ...
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&productId=26702&catalogId=10001&CID=MERCH
because I have a Dremel 4000 and was hoping to use that.
Regretfully the stand is not capable of supporting the Dremel 4000 securely. The Dremel 4000 is just too big and heavy.
I am not sure if I will bother to get the "correct" motor. While I will admit that for $28 plus shipping the stand is reasonably solid I feel the term "will not be solid enough even with the smaller motor" applies.
---In homebrew_pcbs@yahoogroups.com, <v321uk@...> wrote:Here are some comments I found on the PZ541From: arvidj@...Sent: Thursday, September 05, 2013 4:50 PMSubject: [Homebrew_PCBs] RE: Expo Drill Stand 14211
Thanks, John G3UGY
2013-09-28 by John
Note
because
I
I
2013-09-29 by Jim
>Just to add to this discussion:
> Thanks, John G3UGY
