Why not use plated-through hole technology to print a circuit?
2013-08-17 by theminde@btinternet.com
Hello group.
When manufacturers of boards plate through the holes they use some kind of special fluid solution, this attracts copper thus the hole is plated in copper.
So I was wondering if it is possible to use the same solution to print the actual pattern, afterwards transferring copper (sulphate?) to build up the tracks.
Regards
Re: [Homebrew_PCBs] Why not use plated-through hole technology to print a circuit?
2013-08-17 by Charles R Patton
Not very practical.  The electroless copper first laid down is very thin
-- just enough copper to get electrical conductivity.  Furthermore you
have to have connections to all traces (no isolated traces) to allow the
electroplating to occur.  There is a variation though that has been used
over the years.
1) dip the plastic PCB (already drilled) in an electroless solution to
establish a conductive surface.
2) put on a reverse (i.e. traces are exposed, the rest of the bd is
covered)  resist
3) electroplate a working thickness 1/2oz, 1oz, or whatever thickness
you're after (and since the holes are also conductive at this point,
they'll be plated, too)
4) strip the resist
5) dip briefly in etchant to strip the electroless flash over the whole
bd (remember it is quite thin and will etch away long before any
significant etching takes place on the traces.)
Charles R. Patton
On 8/17/2013 3:00 AM, theminde@... wrote:
> Hello group.
> plated in copper.
> Regards
Re: Why not use plated-through hole technology to print a circuit?
2013-08-17 by jcarlosmor
Hello,
It is not just as simple. If possible, all the pcb fabs will do that.
Regards.
--- In Homebrew_PCBs@yahoogroups.com, "theminde@..." <theminde@...> wrote:
> Hello group.
> Regards
2013-08-17 by Harvey White
On Sat, 17 Aug 2013 10:00:08 -0000, you wrote:
>Hello group.
Kinda.
This description is an old process, they might do it differently now.
The fluid makes the edges of the hole conductive.  Since all the holes
are drilled first, every top and bottom hole is connected.
The board has a negative resist on it, resist where you do not want
copper.
They then plate the board with one oz copper thickness.  This shorts
(all of) the layers  together.
The resist is still on, so you have a thicker copper layer where there
is to be a trace.
They then plate tin on the board, This plates the traces.  At this
point, the board is solid copper covered with resist where there is to
be no copper, a thicker plated trace that goes through the holes, and
tin plating all over that.
They then strip off the photoresist, leaving tin plated traces and
bare copper.
Etch in Ammonium persulphate or the like, which does not attack tin,
but does attack copper.
unprotected copper is removed, not touching the tin plating.
The plating through hole chemicals (graphite in a solution has been
used, I think), don't support the action that you want (you'd have to
spray this on the board, it would have to be continuous to plate a
copper layer, etc....)
Harvey
>Regards
