Developer box
2013-07-08 by gail21
I have had great success with my home made light developer box, I used
facial tanning tubes complete units can be bought off ebay complete with the
timer circuit
See this link for a range of units, I used the Philips one
http://www.ebay.co.uk/sch/i.html?_trksid=p2047675.m570.l1313.TR2.TRC0.A0.Xfa
cial+tanner.TRS0&_nkw=facial+tanner&_sacat=0&_from=R40
I then searched ebay for a cheap but deep scanner box took all the parts out
of the scanner unit and adapted it
http://www.ebay.co.uk/sch/i.html?_trksid=p5197.m570.l1313.TR3.TRC0.A0.Xusb+s
canner.TRS0
<http://www.ebay.co.uk/sch/i.html?_trksid=p5197.m570.l1313.TR3.TRC0.A0.Xusb+
scanner.TRS0&_nkw=usb+scanner&_sacat=0&_from=R40>
look for an old scanner even a parallel port
cheap and with reasonable depth
my own website has a photo of the finished unit
I did take several pictures during the making of the developer box, for me
it was key to have a timing unit and the facial tanners such as the Philips
have them .
http://www.qsl.net/g4xcp/Projects.html
a pcb I developed using the scanner can be seen here
http://www.qsl.net/g4xcp/Interface.html
for me the timer, which is mechanical was important
you then produce little test wedges of circuit board with different timer
settings
make a note on the back of the pcb but also write notes such as whom you
bought the pcb board from
keep the timing figures, where you bought the board from in a dust free
folder.
Regards
gail
timer circuit
canner.TRS0
have them .
settings
folder.
Regards
gail
