Homebrew_PCBs
HP Laser Jet 1320 Printer adequate ?
2013-05-26 by Randall
I am looking for an opinion on whether a HP Laser Jet 1320 printer is good enough to make print outs for PCBs on Press-n-peel Blue or magazine paper.
thanks
Re: [Homebrew_PCBs] HP Laser Jet 1320 Printer adequate ?
2013-05-26 by kabowers@...
>thanks
I've messed with almost every model of laser printer HP
has ever sold and never had a problem with any of them.
You do want to set the printer/driver for maximum resolution
and density. Over the years there have been problems with refilled
toner cartridges, so it's probably worthwhile to keep a
"real HP" toner cartridge for PCB work and use the refills
and third party cartridges for day-to-day printing. Branch out to
the less expensive stuff after you have your process down pat.
At present I'm using an HP1022 with a toner cartridge from
dx.com (IIRC around $30 delivered) with no problems.
The "real HP" it replaced MAY have been a bit better.
Keith Bowers WB4LSJ- Thomasville, NC
Re: HP Laser Jet 1320 Printer adequate ?
2013-05-26 by bebx2000
I used it when I first started with toner transfer and it worked just fine. I could never figure out how to set the print density with the driver software so I used this program,
http://www.victechsoftware.com/ljconfig.html
I now mostly use a HP1102W and you can configure this setting from its web page. Also, I have noticed no difference in the the quality of the refill toner from here and the genuine HP cartridges,
http://tonerrefillkits.com/
Baxter
> thanks
