Homebrew_PCBs
Tidying up circuit boards after cutting
2013-05-22 by Will Price
I thought I'd just post this tip I found out a while ago when I was in the
workshop cutting out some boards and tuning some plane blades...
After rough cutting a circuit board to size, you can use a hand plane (e.g.
http://fingerlakesguitarrepair.com/media/tuning%20a%209%2012%20stanley%20block%20plane/1.0%20stanley%20nine%20and%20a%20half%20block%20plane%20tune%20up.jpg)
to neaten the edges, turns out FR4 is even nicer to plane than wood...
who'd have known!?
I'm not sure how hard it's on the blade, but a couple of swipes resulted in
a glassy finish. I used a number 4 as it was what I had at hand at the
time, but a smaller block plane like the one above would be easier to use,
or perhaps a little bull nose plane (though they're more expensive than
block planes which can be had for a couple of pounds at a car boot sale).
Anyone else got any unexpectedly effective ways of either cutting or
tidying up boards?
Will
Re: [Homebrew_PCBs] Tidying up circuit boards after cutting
2013-05-22 by Phil@Yahoo
I use a 0.0625" cross-hatch carbide routing burr in a 30KRPM laminate edge
router on a CNC drilling machine to route the edges after drilling, leaving
small tabs for easy separation. The burr makes a nice smooth edge. After
separation, a little 120-grit sand paper smooths off the tab remnants
easily.
Never thought about using a hand plane. I should think depth of cut would be
critical, i.e. you would want a VERY shallow cut. And a VERY sharp blade.
Phil M.
Sent: Wednesday, May 22, 2013 1:25 PM
Subject: [Homebrew_PCBs] Tidying up circuit boards after cutting
> (e.g.
> who'd have known!?
> in
> tidying up boards?
> Will
> Photos:
2013-05-23 by Mitch Davis
> easily.
Personal opinion here, not backed up with knowledge, but AFAIK FR-4
isn't very hard, it's just terribly abrasive, on account of the glass
fibres.
Mitch.
Re: Tidying up circuit boards after cutting
2013-05-23 by Will Price
be
Compared to planing soft wood like plane, FR4 is no where near as finicky,
I don't think I even bothered adjusting the blade depth, it wasn't taking
that shallow a cut, but the blade was sharp, I treat anything I can't shave
my arm hair with as blunt.
Will
Re: [Homebrew_PCBs] Re: Tidying up circuit boards after cutting
2013-05-23 by Stefan Trethan
It sure won't stay that sharp for very long with FR4.
I suppose one could make a tiny edge plane with a piece of carbide as a blade.
Or maybe even use an insert, as-is without grinding.
ST
> be
> Will
