Homebrew_PCBs
flatbed scanner lamps
2013-02-23 by dave_donlan
Has anyone got any idea of the suitability of the scanner lamp for pcb exposure.
If ok I was planning on positioning the lamp further away from the glass and using reflectors to spread the light
Any help greatfully accepted
Dave
Re: [Homebrew_PCBs] flatbed scanner lamps
2013-02-23 by Leon Heller
> exposure.
You need UV lamps (long wave for positive resist)!
Leon
Leon Heller
G1HSM
RE: [Homebrew_PCBs] flatbed scanner lamps
2013-02-23 by Tony Smith
> >Leon
> >Leon Heller
> >G1HSM
> 405nm?
> Cristian
About that, some boards need closer to 370nm. That's in the UVA band. The
germicidal ones are UVC (200nm-ish).
The UV LEDs you can buy are usually around 400nm or so, which is why they
work. I've seen shorter wavelength ones, but they were a bit $$$. Those
little nail polish curing lamps are probably the cheapest (off eBay).
Tony
Re: flatbed scanner lamps
2013-02-24 by dave_donlan
Thanks all
> > >Leon
> > >Leon Heller
> > >G1HSM
> > 405nm?
> > Cristian
> Tony
