Homebrew_PCBs
Etching woes: Press-n-Peel, Laminator, Etch Tank + Sodium Persulphate
2013-02-19 by phil.quinton@ymail.com
Hi,<br><br>First post, hopefully one of many..<br><br>To cut a long
story short, I'm having problems <b>after</b> etching with Sodium
Persulphate in my very old RS etch tank ( purchased from ebay many years
ago ). The etch tank has a working agitator which I've been
using.<br><br>The press-n-peel blue transfer ( Laserjet 4 ) to the 1.6mm
single sided copper board, via the laminator, appears to be pretty close
to spot on ( sometimes the lines are a little blurred, which I'm
guessing is due to too many passes ). <br><br>Issues:<br><blockquote>1.
Etching is taking a bit longer than I expect ( ~15 minutes ). The very
first couple of etches I did took < 5 minutes. Since then it's been
getting progressively worse. Assumption was that the etchant was getting
worn ( used 5 or 6 times ). So yesterday I cleared out the etchant,
mixed some fresh 2.5 litres with 500g of etchant and had another go.
Same, about 15 minutes.<br><br>2. The result looks pretty good ( post
etch ) with the toner still visible. If you check under a magnifying
glass you can see all the tracks in tact, nice clear and strong. I clear
the toner off with a little thinners and the end result is just plain
awful. A lot of copper tracks are etched straight through, most are very
thin thin indeed and pads look massacred, even though the toner above it
looked spot on. In short, it appears to be etching <b>under</b> the
toner somehow.<br></blockquote><br>My guess is that the etch tank is no
longer getting to the right temperature ( ~ 45 degrees ) and I'm etching
too long with the agitator on. I'm going to get myself a temperature
probe to confirm.<br><br>Has anyone had a similar experience ( Etch
looking fine until the toner is removed )?<br><br>Thanks in
advance,<br>Phil.<br>
Re: [Homebrew_PCBs] Etching woes: Press-n-Peel, Laminator, Etch Tank + Sodium Persulphate
2013-02-20 by Todd F. Carney
In the trade what you have what is called "undercutting." If the resist in
firmly applied, undercutting is usually caused by exhausted etchant and
therefore overlong etch times. It can also occur if too much agitation or
heat is applied. I don't know about the "tank" you are using, but a simple
photo tray (or Pyrex backing dish) and a gentle rocking agitation is all
one needs for one-off PCBs. Etching in a simple apparatus such as this
makes it easier to monitor the etch process and to stop it once the
unwanted copper is clear.
One other thing: do not use 2oz copper clad. Resist on 2oz copper will
often be undercut before all the unwanted copper is clear. 1oz is plenty
for every application. There are online tables that show the sectional area
of a 1oz trace versus temperature and current load. If needed, a trace is
made wider to handle more current. They're usually designed wide anyway. To
keep grounds at the same potential, they're almost always made a big as
possible--at least for analog and RF applications. Here is a nifty online
calculator for trace width vs. current calculations:
http://circuitcalculator.com/wordpress/2006/01/31/pcb-trace-width-calculator/
Best,
Todd
K7TFC / Medford, Oregon, USA / CN82ni / UTC-8
QRP (CW & SSB) / EmComm / SOTA / Homebrew / Design
On Tue, Feb 19, 2013 at 7:27 AM, phil.quinton@... <
phil.quinton@...> wrote:
> Hi,
> To cut a long
> story short, I'm having problems *after* etching with Sodium
> using.
> Issues:
> 1.
> looked spot on. In short, it appears to be etching *under* the
> toner somehow.
> probe to confirm.
> Thanks in
> advance,
> Phil.
Re: Etching woes: Press-n-Peel, Laminator, Etch Tank + Sodium Persulphate
2013-02-20 by tda7000
I have used the toner transfer method with the laminator described here: http://ultrakeet.com.au/write-ups/superfuser
I have not used Press-n-peel blue, just magazine paper. However I have not had undercutting (that I ever noticed!). I used old Ferric Chloride and later on the Hydrochloric acid and Hydrogen Peroxide mixture. Both worked great.
http://ultrakeet.com.au/write-ups/etchantComparison he describes Ammonium Persulphate as being much worse than Ferric Chloride. I have never used Ammonium Persulphate.
I don't know if it's any different to Sodium Persulphate in terms of undercutting, but if his article has any truth behind it I would probably try something else.
--- In Homebrew_PCBs@yahoogroups.com, "phil.quinton@..." <phil.quinton@...> wrote:
> Persulphate
<Snip>
Re: [Homebrew_PCBs] Re: Etching woes: Press-n-Peel, Laminator, Etch Tank + Sodium Persulphate
Either ammonium persulfate or sodium persulfate is used by commercial pcb
manufacturers. They do not use ferric chloride, not for decades. Only
hobbyists use the stuff. I'm using a peroxide-muriatic acid-sodium chloride
etchant. It's very cheap, and the chemicals are available either in a drug
store or at places such as Home Depot (for the acid). I use it "one-shot."
I use just enough to do the board I'm etching and then toss it away. It's
that cheap. This way, It works the same way--etch times, etc.--every time I
use it.
73,
Todd
> great.
> try something else.
> --- In Homebrew_PCBs@yahoogroups.com, "phil.quinton@..." wrote:
> > Hi,
> To cut a long
> > Persulphate
> > toner somehow.
> > probe to confirm.
> Thanks in
> > advance,
> Phil.
2013-02-20 by phil.quinton@ymail.com
Todd,
Thank you for the advice.
If you use a tray for etching, how do you keep the temperature up for the sodium persulphate?
Or is it just a case of getting the water warm before you mix in the etchant?
It's possible that the agitator is too aggressive, especially as the etch time is taking so long.
Can there be a difference in the quality of the sodium persulphate? The current batch is from a difference source to the very first etching.
Thanks again,
Phil.
> use it.
> 73,
> Todd
> > great.
> > try something else.
> > --- In Homebrew_PCBs@yahoogroups.com, "phil.quinton@" wrote:
> > > Hi,
> > To cut a long
> > > Persulphate
> > > toner somehow.
> > > probe to confirm.
> > Thanks in
> > > advance,
> > Phil.
Phil,
I use an muriatic (hydrochloric) acid and peroxide etchant in a tray. I mix
the etchant just before use, and since the combination is *exothermic*, it
heats itself long enough to get the job done. I have used persulfate
etchants in trays, but the solution does have to be heated. This can be
done, as you suggest, by mixing the persulfate into *hot* water. I say hot
because as persulfate goes into solution, there is an *endothermic*
reaction--it cools down.
By the time it's fully dissolved it's still warm enough to etch,
particularly since it is a fresh solution and etching times will therefore
be short. If you reuse the etchant, you can always heat it carefully in a
microwave. It will also help to preheat the tray and pcb in hot tap water
so they don't draw heat from the etchant.
I suppose it's possible you got some bad persulfate on your second try. I
haven't used it for some time now, so I don't know good sources. I suspect,
though, that MG Chemicals would have good quality material.
http://www.mgchemicals.com/products/prototyping-and-circuit-repair/prototyping/
73,
Todd
On Tue, Feb 19, 2013 at 11:22 PM, phil.quinton@... <
> Todd,
> sodium persulphate?
> etchant?
> Thanks again,
> Phil.
> chloride
> drug
> "one-shot."
> time I
> > use it.
> > 73,
> > Todd
> here:
> not
> worked
> > > great.
> Ammonium
> probably
> > > try something else.
> > > > Hi,
> > > To cut a long
> > > > Persulphate
> > > > toner somehow.
> etching
> > > > probe to confirm.
> > > Thanks in
> > > > advance,
> > > Phil.
2013-02-20 by William Whyte
(excess quoting trimmed by moderator - please trim!)
Todd, What are your ratios, particuly the sodium chloride(salt) ?
Ollie k0lqk
--- On Tue, 2/19/13, Todd F. Carney <k7tfc@...> wrote:
Subject: Re: [Homebrew_PCBs] Re: Etching woes: Press-n-Peel, Laminator, Etch Tank + Sodium Persulphate
Date: Tuesday, February 19, 2013, 11:21 PM
use it.
73,
Todd
(snip excess by moderator - please trim!)
Ollie,
I'm actually no longer using the salt additive, just the muriatic
(hydrochloric) acid and peroxide. I wish I could find my link, but I think
my original source used salt as a means of getting more chloride ions into
depleted etchant without adding more acid. I tried it a few times when I
was reusing the etchant and it did seem to shorten long etch times. Now
that I use the etchant one-shot---a small amount that is then discarded---I
don't need to refresh used etchant.
My formula for the one-shot version is the typical 1 part ≈35% muriatic
(hydrochloric) to 2 parts 3% hydrogen peroxide (the drug-store variety). I
warm it a bit to ≈100°F (38°C), but since I use only about 6oz (170ml) of
solution in a tray, it cools down fairly quickly. I use the foam trays that
meat comes packaged with.
I learned the one-shot method as an industrial photographer. Not reusing
film (and paper) developer, but using small amounts one-shot, allowed for
precise control that cannot really be had with reuse/replenishment schemes.
Precise repeatability is possible with one-shot. It's not with reuse.
Much of the need for repeatability, in my mind, is that we DIYers use some
pretty dubious methods of applying etchant resist to our boards--toner
transfer being the most common, it seems--I use it myself. This means using
materials that are not optimum for the purpose and applying them with
make-shift methods: cloths irons, etc. Combined with less-than-thorough
surface preparation of the copper clad, all this means our resist patterns
are fragile and cannot withstand long etch times with repeatable results.
It's not just that the resists are probably not-all-that chemically
resistant, but that their mechanical bond with the copper is weak and
uneven. Flaking of the resist, or undercutting of it in long etch times, is
an ongoing problem for many of us. Fast etch times and
repeatably-predictable results can minimize these problems. Both point to
one-shot etching.
Now in my online poking around in the last few days on these issues, I am
now persuaded that I need to be much-more careful in the disposal of my
etchant--especially since I'm tossing out several ounces at a time for each
board. To be perfectly honest, I used to just dump the stuff down the drain
with plenty of running water. Bad news! So what I'm going to try is to dump
it into a five-gallon bucket filled about 3/4 full of wood shavings. I have
a whole bale of the stuff left from when we had hamsters (a rant for
another occasion). Saw dust or even shredded paper might work just as well.
I'll dump the spent etchant into the bucket, maybe stir the shavings around
a bit (maybe not), and then keep the bucket open and outside (not
inside!!!) but out of the rain. Before long, each dumping will dry in the
bucket, sequestered (oh that word!) in the wood or paper fibers. I guess I
should put a warning sign on the bucket. At some point I'll have to
double-bag the shavings before tossing them in the land-fill garbage, but
as I'm thinking now it might take many years before that will be necessary.
It may never be necessary in my lifetime, so I'll have to leave disposal
instructions in my will (wink wink).
Best,
Todd
