thoughts on electric paint sprayer for spray etching
2013-01-29 by Jeff
What are opinions on using an electric paint sprayer to spray etch a board?  Could an electric sprayer be modified to run etchant so it can resist corroding?  Would the spray pattern, droplet size, and spray force be acceptable?
Jeff
Re: [Homebrew_PCBs] thoughts on electric paint sprayer for spray etching
2013-01-29 by Todd F. Carney
> acceptable?
Jeff,
Just to clarify, do you mean for the sprayer to resist corrosion? If you
use ferric chloride, that doesn't seem likely. Maybe not even a persulfate
etchant.
I used to use shop-built bench-top (actually, lab-sink-top) spray-based
etching machine that was pretty much all plastic. It consisted of an
open-top plastic tank, an immersion heater (from a small hot-water heater),
an immersion pump from a "swamp" cooler, and sprayers made of PVC pipe, and
a holder that clamped the board to be etched in a frame. The sprayers hit
the board evenly on both sides at once. The little spray heads were made
for drip-irrigation use. We placed a sheet of plexiglass on top to contain
overspray and so we could monitor the etching. We used persulfate etchant
in it (which we left in it until it had to be replaced) so it was not a
source of staining-or-toxic ferric chloride. I don't know how or if that
damn stuff would work in such a machine. We never used it. I don't think
any professional or commercial pcb outfits use it either.
These days, a darkroom tray works for the one or two boards I might make in
a month. I use home-made peroxide-muriatic-salt etchant. I just hand
agitate the tray. I was toying with the idea of making a motorized rocking
agitator, but then I came to my senses.
73,
Todd
K7TFC / Medford, Oregon, USA / CN82ni / UTC-8
QRP (CW & SSB) / EmComm / SOTA / Homebrew / Design
RE: [Homebrew_PCBs] thoughts on electric paint sprayer for spray etching
2013-01-29 by Jeff Heiss
Todd, I like your ideas.  What is a "swamp" cooler pump?  I am not familiar with drip irrigation spray heads.  Are they like mister nozzles for gardens?
Jeff
Sent: Tuesday, January 29, 2013 2:35 AM
Subject: Re: [Homebrew_PCBs] thoughts on electric paint sprayer for spray etching
 > acceptable?
 Jeff,
 etchant.
 73,
 Todd
2013-01-29 by Randall Morgan
A "Swamp" cooler is a type of air conditioning device that works by
the evaporation process to cool air. They are very simple. Water is pumped
to the top of panels usually filled with burlap or hemp fibers. The water
runs down through the fibers soaking them. Air is then pulled through the
fiber panels and blown into the room. As the air is pulled through the
fibers it picks up maximum humidity. Once released into the room the air
evaporates its excess humidity to conform with
current atmospheric conditions. As the water is released from the air it
takes heat with it. Air itself is a very poor storage medium for heat and
stores most of its heat in the moisture contained in it.
Swamp pumps can be purchased at most hardware stores and even walmart.
> Jeff
> -----Original Message-----
> From: Todd F. Carney k7tfc@...>
> etching
> be
> > acceptable?
> Jeff,
> etchant.
> 73,
> Todd
If you ask me if it can be done. The answer is YES, it can always be done.
The correct questions however are... What will it cost, and how long will
it take?
I checked Walmart for immersion pump and swamp pump but did not see any listed.  Could you give a reference to one online?
Jeff
Sent: Tuesday, January 29, 2013 3:25 PM
> Jeff
> etching
> be
> > acceptable?
> Jeff,
> etchant.
> 73,
> Todd
it take?
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
2013-01-29 by Rick Sparber
Swamp coolers are common here in Arizona but never saw one until I came
here.
Rick
On Behalf Of Jeff Heiss
Sent: Tuesday, January 29, 2013 3:19 PM
Subject: RE: [Homebrew_PCBs] thoughts on electric paint sprayer for spray
etching
Jeff
etching
A "Swamp" cooler is a type of air conditioning device that works by the
evaporation process to cool air. They are very simple. Water is pumped to
the top of panels usually filled with burlap or hemp fibers. The water runs
down through the fibers soaking them. Air is then pulled through the fiber
panels and blown into the room. As the air is pulled through the fibers it
picks up maximum humidity. Once released into the room the air evaporates
its excess humidity to conform with current atmospheric conditions. As the
water is released from the air it takes heat with it. Air itself is a very
poor storage medium for heat and stores most of its heat in the moisture
contained in it.
for gardens?
> Jeff
> spray etching
> > spray force
> be
> > acceptable?
> Jeff,
> you use ferric chloride, that doesn't seem likely. Maybe not even a
> persulfate etchant.
> spray-based etching machine that was pretty much all plastic. It
> consisted of an open-top plastic tank, an immersion heater (from a
> small hot-water heater), an immersion pump from a "swamp" cooler, and
> sprayers made of PVC pipe, and a holder that clamped the board to be
> etched in a frame. The sprayers hit the board evenly on both sides at
> once. The little spray heads were made for drip-irrigation use. We
> placed a sheet of plexiglass on top to contain overspray and so we
> could monitor the etching. We used persulfate etchant in it (which we
> left in it until it had to be replaced) so it was not a source of
> staining-or-toxic ferric chloride. I don't know how or if that damn
> stuff would work in such a machine. We never used it. I don't think any
> make in a month. I use home-made peroxide-muriatic-salt etchant. I
> just hand agitate the tray. I was toying with the idea of making a
> motorized rocking agitator, but then I came to my senses.
> 73,
> Todd
The correct questions however are... What will it cost, and how long will it
take?
Re: thoughts on electric paint sprayer for spray etching
2013-01-29 by cunningfellow
Jeff,
Look at
http://www.instructables.com/id/The-Etchinator-low-cost-spray-etcher/
The instructable also contains a link to Adam
Seychells more professional etcher (a member
here also)
There are also a few more ideas such as the
splash etcher someone oft mentions here (search
is your friend)
All of them are reasonable ideas.  Most of them
would actually be cheaper than an electric
spray paint gun and NOT have corrosion problems.
Ferric Chloride does have its place BTW.  Just
not for PCBs unless you don't do them very often.
2013-01-30 by mvkkeller
Jeff,
The official name is "Evaporative Cooler"...
One source of parts online: http://www.plumbersurplus.com/Cat/Evaporative-Cooler-Pumps-Parts/1244/List
Another: http://www.homedepot.com/webapp/catalog/servlet/Search?storeId=10051&langId=-1&catalogId=10053&keyword=Evaporative%20Cooler%20pumps&Ns=None&Ntpr=1&Ntpc=1&selectedCatgry=Search+All
Another: http://www.johnstonesupply.com/storefront/hvacr-parts/air-conditioning-refrigeration-components/evaporative-cooler-parts/c1027991-c1027234-c1028291-p1.html
- Ken -
> Jeff
> From: Randall Morgan
> > Jeff
> > etching
> > be
> > > acceptable?
> > Jeff,
> > etchant.
> > 73,
> > Todd
> it take?
RE: [Homebrew_PCBs] Re: thoughts on electric paint sprayer for spray etching
2013-01-30 by Jeff Heiss
The prices of the pumps in the spray etcher projects were $180, $77, and
$100.  They all appear to be water pumps but I'm not sure how the builders
knew they would work with etchent.  Todd, how much did your pump cost?
Jeff
  _____
On Behalf Of cunningfellow
Sent: Tuesday, January 29, 2013 6:10 PM
Subject: [Homebrew_PCBs] Re: thoughts on electric paint sprayer for spray
etching
Jeff,
Look at
here also)
is your friend)
Re: [Homebrew_PCBs] Re: thoughts on electric paint sprayer for spray etching
2013-01-30 by Randall Morgan
Here is a link to a swamp (also called evaporative cooler) at Home Depot.
They seem to be seasonal items at walmart.
http://www.homedepot.com/h_d1/N-5yc1v/R-100158379/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=water+cooler+pump&storeId=10051#.UQiOimLAM-A
Cost less than $16 USD
> Jeff
> _____
> etching
> Jeff,
> Look at
> here also)
> is your friend)
it take?
I looked up the specs on the pumps.  They produce about 2psi at 6 gallons
per minute.  They look and work like pedestal sump pumps.  I guess they
won't work with etchant spray nozzles since the nozzles require 30psi.
Todd, did your nozzles have a lower psi requirement?
Jeff
On Behalf Of Randall Morgan
Sent: Tuesday, January 29, 2013 10:09 PM
Subject: Re: [Homebrew_PCBs] Re: thoughts on electric paint sprayer for
spray etching
> Jeff
> _____
> etching
> Jeff,
> Look at
> here also)
> is your friend)
it take?
2013-01-30 by Todd F. Carney
Jeff,
I did not build the etcher I described, and as I now recall it wasn't
shop-made at all. It was made by Kepro Circuit Systems (now defunct). I did
have occasion, though, to replace the pump. It was around $20 (but . . .
that was about 1985!!!!). Here's one that looks about like the one in the
Kepro:
http://www.capitolsupply.com/catalog/15000-2-mighty-cool-pump-c150002-cs6539900.html?cid=gkw_pa.
I think you can find them cheaper than at Capitol Supply.
Damn me if I didn't just find the Kepro etcher I used on eBay:
http://www.ebay.com/sch/i.html?_odkw=reproduction+doll&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313&_nkw=kepro+etcher&_sacat=0
The one I used was the BTD-201, the second on that eBay page. There are
several pictures, none very good. The seller wants $489 for it!!! Maybe if
it was new, that might be reasonable (I wouldn't pay it--I'd spend a
morning at the hardware store and the afternoon putting my own etcher
together). As it turns out, this one is an absolute wreck!!
73,
Todd
> Jeff
