PCB cutting
PCB cutting
2012-12-18 by Richard
a neighbor gave one of these,
Roberts Quik-Cut Vinyl Tile Cutter
can be found at Home Depot
Model # 30002
Internet # 100038849
Store SKU # 729019
$50.00
this is the best way to cut FR4 i have found, straight smooth edges, near no effort to cut 1/16 board, board does not skew either, has a cast aluminum frame, the blade is pinned at both ends giving increased leverage and keeps the blade from wandering and skewing the cut.
RD
Re: [Homebrew_PCBs] PCB cutting
2012-12-18 by Mark Schoonover
I've also have been looking for a better way to cut PCB material and I
think I've found it:
http://www.youtube.com/watch?v=3RyJHKz8LFU
Not only does it say "circuit board" on the outside box, it can also be
used to cut just about anything needed to make project boxes, etc.
73 - Mark Schoonover - KA6WKE
http://www.ka6wke.net
2012-12-18 by Eldon Brown
RD,
Very good,
I am going to recommend this to some of my  PCB building friends.
Here is the HomeDepot URL:
http://www.homedepot.com/h_d1/N-5yc1v/R-100038849/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=729019&storeId=10051#.UNA3TKrwilg
Eldon Brown
73 - Eldon - WA0UWH - CN88xc - http://WA0UWH.blogspot.com/
> 729019
2012-12-18 by casy_ch@tbwil.ch
What a good idea! Thank you. Here it is available as well.
Vy 73 de Jean-Claude, HB3YDH
Am 18.12.2012 10:34, schrieb Eldon Brown:
> RD,
> Very good,
> Regards,
> Eldon Brown
> <mailto:rdheiliger%40msn.com>> wrote:
> > 729019
2012-12-18 by Stefan Trethan
I've seen a similar cutter for wood laminate flooring but it didn't
have the second lever, just a single blade.
Also the blade went down into a slot, cutting a thin strip out of the
wood, a bit like a nibbler just much longer.
The mechanics of this vinyl tile cutter seem much more suitable, too
bad vinyl tile is not very popular here...
ST
> Model # 30002
> Store SKU # 729019
> $50.00
> RD
2012-12-18 by Steve
Richard,
Thanks for that recommendation. How does this cutter do if you want
small pieces of 1/16in FR4? Seems that I often need a small board
perhaps on the order on one inch square.
Thanks.
Steve K8JQ
> Model # 30002
> Store SKU # 729019
> $50.00
> RD
2012-12-18 by Mitch Davis
On the rare occasion I need to (I'm a PCB supplier) I usually use
tinsnips.  If I had to do it more often I'd get my hands on a hand
(ie, not air, not electric) nibbler.  Based on how nibblers I've used
in the past have gone, I think it would do a fantastic job on FR4.
Mitch.
http://tinyurl.com/hvpcbfaq
Re: PCB cutting
2012-12-18 by RDHeiliger
I make my board a bit oversize, don’t have to align toner print as accurately, then trim after etch and drill, have been able to trim off as little as 1/8 inch.
RD
RE: [Homebrew_PCBs] PCB cutting
2012-12-19 by Rick Sparber
Funny you should mention this. I had a few small circuit boards to cut up
just now and tried my sheet metal snips. It is a rather massive hand tool,
not the ones with the thin jaws. It cut through the FR4 easily and with good
control. When the ships are dull, it is easy to re-sharpen it.
Rick
On Behalf Of Mark Schoonover
Sent: Monday, December 17, 2012 10:54 PM
Subject: Re: [Homebrew_PCBs] PCB cutting
I've also have been looking for a better way to cut PCB material and I think
I've found it:
Not only does it say "circuit board" on the outside box, it can also be used
2012-12-19 by casy_ch@tbwil.ch
Mark
You mean boxes to fit your reserve pcboards ???? hi3x
A very good idea this tool. I must have a look if it is available on
this side of the pond.
Am 18.12.2012 06:53, schrieb Mark Schoonover:
2012-12-20 by Jeff Heiss
How about the Proxxon circular saw for cutting copper clad ($125)?
Jeff
  _____
On Behalf Of Rick Sparber
Sent: Wednesday, December 19, 2012 11:21 AM
Subject: RE: [Homebrew_PCBs] PCB cutting
Rick
From: Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs%40yahoogroups.com>
<mailto:Homebrew_PCBs%40yahoogroups.com> ]
To: Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs%40yahoogroups.com>
I've found it:
2012-12-20 by Rick Sparber
I'm sure it is a nice machine. But if my sheet metal snips do the trick, why
buy something else?
Rick
On Behalf Of Jeff Heiss
Sent: Wednesday, December 19, 2012 6:21 PM
Jeff
  _____
Rick
<mailto:Homebrew_PCBs%40yahoogroups.com> ] On Behalf Of Mark Schoonover
I've found it:
2012-12-20 by A.Tahir DENGIZ
Proxxon circular saw is not powerfull enough.
It has been tried one of my HAM friend.
It is only good for balsa wood for models.
A.Tahir DENGIZ, TA2T
Sent: Thursday, December 20, 2012 3:20 AM
Jeff
_____
From: mailto:Homebrew_PCBs%40yahoogroups.com [mailto:mailto:Homebrew_PCBs%40yahoogroups.com]
To: mailto:Homebrew_PCBs%40yahoogroups.com
Rick
From: mailto:Homebrew_PCBs%40yahoogroups.com <mailto:Homebrew_PCBs%40yahoogroups.com>
To: mailto:Homebrew_PCBs%40yahoogroups.com <mailto:Homebrew_PCBs%40yahoogroups.com>
I've found it:
http://www.ka6wke.net/
On Mon, Dec 17, 2012 at 9:37 PM, Richard <mailto:rdheiliger%40msn.com
2012-12-20 by Mark Schoonover
I use metal snips for boards no bigger than 2" because anything longer and
the board starts to curve up or down depending on which side I need to use.
I would like to use PCB material for project enclosures too, just can't
justify the costs for even small enclosures.
why
> buy something else?
> Rick
> -----Original Message-----
> Jeff
> _____
good
> Rick
think
> I've found it:
> Craftsman Trak-Cut track saw w/ miter base
used
Photos:
Photos:
2012-12-20 by Duane C. Johnson
I use a paper guillotine.
http://en.wikipedia.org/wiki/Paper_cutter
The first picture.
I think they are about $50us
This works much better than tin snips.
Duane
     Home of the $35 Solar Tracker      Receiver
    http://www.redrok.com/led3xassm.htm      [*]
   Powered by             &#92;  &#92;     &#92;        //|
  Thermonuclear   Solar Energy from the Sun / |
Energy (the SUN)           &#92;  &#92;     &#92;  /  /  |
Red Rock Energy             &#92;  &#92;     /   /   |
Duane C. Johnson   Designer  &#92;  &#92;  /  &#92; /    |
1825 Florence St  Heliostat,Control,& Mounts |
White Bear Lake, Minnesota    === &#92;   / &#92;    |
USA      55110-3364                ===   &#92;   |
(651)426-4766        use Courier New Font &#92;  |
redrok@...     (my email: address)  &#92; |
http://www.redrok.com  (Web site)          ===
Mark,
I can see how that curving could crack vias and thin traces.
Before I made my finger brake ( http://rick.sparber.org/smfb.pdf ), I used
aluminum "coil". It comes pre-painted on both sides with different colors
(your choice). The stuff bends with light finger pressure and cuts easily
with scissors. Yet when folded up into a small box, is plenty strong. Back
in Illinois, it was used to wrap wood on the outside of people's houses.
VERY resistant to weather. I bought a 50' x 1' wide roll about 25 years ago
and still have some left.
Rick
Sent: Wednesday, December 19, 2012 9:41 PM
Duane,
I have one of these paper cutters but it did not work well for me. The small
board squirmed as I started to cut. I can see it working with larger boards.
So maybe for boards less than 2" use the sheers and greater than 2" use the
cutter.
Rick
On Behalf Of Duane C. Johnson
Sent: Thursday, December 20, 2012 5:57 AM
The first picture.
Duane
Hi Rick;
 > for me.  The small board squirmed as I started to cut.
I added "Rubberized Shelf Liner" to the bed. I glued
this stuff down with rubber cement. Much better than the
hard slippery wood surface on the paper guillotine.
BTW, there are some paper cutters with anti skid surfaces.
 > greater than 2" use the cutter.
I agree. My tin snips are the old style that look like large
scissors, not the modern type with force multiplication.
The blades are a bit more than 4" long.
Longer boards than the blade length tend to warp the board
when it has to curl up over the handle.
The modern snips tend to warp even short boards though.
 > Rick
Duane
   Powered by             \  \     \        //|
Energy (the SUN)           \  \     \  /  /  |
Red Rock Energy             \  \     /   /   |
Duane C. Johnson   Designer  \  \  /  \ /    |
White Bear Lake, Minnesota    === \   / \    |
USA      55110-3364                ===   \   |
(651)426-4766        use Courier New Font \  |
redrok@...     (my email: address)  \ |
2012-12-20 by joe M
check this out: http://www.prc68.com/I/12InShear.shtml
cuts pcb like butter.
On Thu, Dec 20, 2012 at 9:55 AM, Duane C. Johnson <redrok@...> wrote:
> Hi Rick;
> > Rick
> Duane
I see it at Enco for $129:
http://www.use-enco.com/CGI/INPDFF?PMPAGE=577&PMCTLG=00
Nice tool. I'll have to see if I can make one.
Rick
On Behalf Of joe M
Sent: Thursday, December 20, 2012 9:19 AM
> Hi Rick;
> I added "Rubberized Shelf Liner" to the bed. I glued this stuff down
> with rubber cement. Much better than the hard slippery wood surface on
> > use the cutter.
> I agree. My tin snips are the old style that look like large scissors,
> Longer boards than the blade length tend to warp the board when it has
> > Rick
> Duane
> http://www.redrok.com/led3xassm.htm [*] Powered by \ \ \ //|
> Thermonuclear Solar Energy from the Sun / | Energy (the SUN) \ \ \ / /
> | Red Rock Energy \ \ / / | Duane C. Johnson Designer \ \ / \ / |
> 1825 Florence St Heliostat,Control,& Mounts | White Bear Lake,
> Minnesota === \ / \ | USA 55110-3364 === \ |
> (651)426-4766 use Courier New Font \ | redrok@... (my email:
> address) \ | http://www.redrok.com (Web site) ===
Hi Rick;
Check the part@ directly:
http://www.use-enco.com/CGI/INLMKD?SIITEM001=130-5700&SIQTY001=1&SICOUNT=1
On sale for $89us.
 > Thanks,
 > Rick
Duane
2012-12-20 by joe M
and, no dust flying around.
Watch out with those rotary cutters. FR4 dust does not seem to be good for
the lungs. A pulmonologist said that they see a lot of silicosis patients
(ex-sandblasting workers, etc). Not sure how that translates to FR4 though.
On Thu, Dec 20, 2012 at 11:33 AM, Duane C. Johnson <redrok@...>wrote:
> Hi Rick;
> On sale for $89us.
> > Thanks,
> > Rick
> Duane
Re: PCB cutting
2012-12-21 by Mars Bonfire
I have the equivalent bench shear from Gizzly Tool...but in the 8" size (Grizzly didn't seem to carry the 12" anymore).  Looks almost identical to the enco with a somewhat different design for the hold down.
If it is the same quality as the Grizzly, it is a great tool.  I use it to shear everything from 1/8 plate down through 0.01" brass
shim stock.  The blades are hard and easily removable for resharpening which should be a snap.  It should cut PCB like butter though I hate to dull the blade cutting glass fiber.  For cutting PCBs are other plastics I use a Freud Diablo non-ferrous cutting 10" blade on a table saw (carbide, 80 tooth as I recall) it has a very interesting tooth profile and a low, if not negative "hook".  Cuts plastic and aluminum plate like butter...virtually no burrs.
Steve
--- In Homebrew_PCBs@yahoogroups.com, "Duane C. Johnson" <redrok@...> wrote:
> Hi Rick;
> On sale for $89us.
>  > Thanks,
>  > Rick
> Duane
Re: PCB cutting
2012-12-21 by nordhs
The best things I have found for PCB cutting involve a shearing cut, rather than stock removal, like a blade.  I was using my bandsaw and got great cuts without stressing the board but it dulled the blade very fast.  You could try a scroll saw for very small boards since the blades are cheap.
The aviation snips can curl the board.  PCB cutters are a shearing blade with lots of board support around it.  I should try my throatless metal shear...
If you set up a vacuum and wear an air filter, abrasives do a great job trimming and rounding corners.  Don't breathe the dust though.  It is very controlled board removal and 1x42 belts are cheap.
Steve
Re: [Homebrew_PCBs] Re: PCB cutting
2012-12-22 by Corey Minion
Why would fiberglass dull blades any faster than yellow or red brass or
any other metal for that matter?
If you want to cut boards on a tablesaw, I would recommend a plastics
and phenolics ready triple chip grind neg rake blade such as this one
http://www.toolstoday.com/p-5968-industrial-quality-plastic-cutting-saw-blades.aspx?variantids=10261,0&
> Steve
Re: PCB cutting
2012-12-22 by AlienRelics
Ask anyone who has tried to drill out a PCB using standard high speed steel drill bits, or tried to mill a PCB with a high speed steel engraving bit.
If cutting on a tablesaw, I'd strongly recommend a carbide tipped blade. For drilling and milling, again carbide.
Steve Greenfield AE7HD
> > Steve
2012-12-22 by jeremy youngs
because the glass reinforcement in the board is very hard
jeremy youngs
Odd, I have drilled out hundreds if not thousands of undersized holes in
boards (down to my last 25 boards after 3 years)
It was my first pcb design and I screwed that up, never occurred to me
that there were different sized leads on that first one.
Anyone lubing there bits and tools prior to cutting?
Also, are you use some sort of cooling?
I use compressed air when working on boards.
I have used 2 HSS bits over all that time, never noticed them dull much
more than any tool I may work with on polycarb or acrylic.
I find it dulls far less than working on ferrous metals, and less than
non-ferrous as well.
I am a college and real world trained silver(metal)smith since 89.
I have always been really conscious of tool sharpness
Worst material I have found so far to work with, industrial ceramics.
EATS tools. nam nam nam.
>>> Steve
Re: PCB cutting
2012-12-22 by smilingcat90254
Really should not be using HSS blades. Here is a link to information regarding FR4 PCB.
http://drum.lib.umd.edu/bitstream/1903/8362/1/umi-umd-5671.pdf
chapt 2. has information on the composition of the FR4 core. And it says "The woven glass (generally E-grade) fiber cloth acts as reinforcement for the laminate, primarily providing mechanical strength and electrical properties."
E-glass. It is basically the same kind of glass as in your windows, glass bottles... HSS blade will dull very quickly and be ruined. Have you tried to cut glass with HSS blade? I use a diamond scribe to score a glass. We also have a diamond coated abrasives to trim stained glass. We always use water. I have near phobia level fear of glass powder. Silicosis is not good at any age.
And those working with fiberglass fabric S-glass, E-glass, kevlar and carbon, they buy  scissors by the box load and throw them away as the blade gets dull. Pair of fabric scissors are lot cheaper than a tin snips. And tin snips last just as long as regular fabric scissors and not much more. If you want exercise in frustration, cut a glass fabric at an oblique angle to the direction of the weave. Hint, use adhesive tape near the cut.
And yes for this reason, preference is for carbide tipped blades and drill bits.
> jeremy youngs
Re: PCB cutting
2012-12-24 by AlienRelics
Widening a hole is asking a lot less than drilling a hole where none exists.
2012-12-24 by jeremy youngs
also to note when producing boards one is usually using a high speed
spindle and turning 15000 or more rpm
> exists.
jeremy youngs
2012-12-24 by Corey Minion
Yeah, I thought about that.
I can see that having a lot to do with the longevity.
Now that makes me wonder, as there are recommend speed rates for cutting
materials.
I can drill acrylic plastics with a 1/4" drill and at very different rpm
than nickel, which is at a very different rpm than brass, again, a
different speed than mild steel.
Change the bit size more than 10% in either direction and usually the
speeds for all will need to change again.
It can be rather a PITA when doing a number of different sized holes in
one material.
What are the correct rpms for through drilling "virgin" boards and
different dia holes?
>> exists.
2012-12-25 by Harvey White
>materials.
>one material.
Generally, from about #50 on down, I use at least 20000 RPM, and would
use 30 from #60 on down, if I had something that did it.
For #50 to about #40 I'd use 10K RPM or so, but that's a feel thing
rather than not.
The real thing to calculate is chip load (how much is drilled per
revolution) and SFM (surface feet/minute) which is computed at the
edge of the drill bit and is related directly to drill size (in terms
of RPM).
No idea of what it's supposed to be for FR4, and also needs to be
adjusted for tools used.
Harvey
>>> exists.
2012-12-25 by Mitch Davis
>>materials.
Not uncommon for the drilling machines in the fabs to run at
200,000RPM.  They are insane to watch.  The drill heads pop up and
down as fast as the needle on a sewing machine.  I took some video at
the recent Shenzhen China PCB show, but because Youtube is blocked in
China, it's difficult for me to show you.
Mitch.
RE: [Homebrew_PCBs] Re: PCB cutting
2012-12-25 by Jeff Heiss
200,000 RPM wow!  Are the air turbines like a dentist drill?
Jeff
  _____
On Behalf Of Mitch Davis
Sent: Tuesday, December 25, 2012 12:27 AM
Subject: Re: [Homebrew_PCBs] Re: PCB cutting
>>materials.
Mitch.
Re: PCB cutting
2012-12-29 by tda7000
If youtube has issues with it why not just upload the video files to something like rapidshare and we can all download a copy instead?
> >>materials.
> Mitch.
2012-12-29 by Mitch Davis
Coz that's blocked too.
Re: PCB cutting
I think I misunderstood - I thought Youtube was blocking your video, but if I am correct now you are in China and can't access Youtube?
Someone here must know a site that would work...
2012-12-29 by kabowers@NorthState.net
It would be a bit of work, but you could post it on one of the binary
newsgroups and someone here could pull it down and post it on youtube
etc.
Keith Bowers WB4LSJ- Thomasville, NC
2012-12-29 by Harvey White
IIRC, the Chinese Government has blocked "subversive" sites such as
Youtube....
Harvey
> Youtube....
Because of course, cute kittens are somehow dangerous.
Anyway, after all that I looked at my phone today, and it seems that I
unintentionally took a rather unconvincing still picture, rather than
video.  Sorry guys.
Mitch.
