Homebrew_PCBs
10 etchants
Re: 10 etchants
2012-12-10 by smilingcat90254
I've seen nurdRage. He does have good videos and this is no different.
Interesting about HCl + H2O2 (yes it does "decay").
And CuCl2 + HCl (stable). He says it can be regenerated but first line says that Chlorine is being used to create CuCl4 and use up HCl. I don't see how you can replenish Chlorine without adding more HCl.
Well he said he will have another video just on CuCL2 + HCl etchant.
He does have video on FeCl3 and tells you how to make it. Only thing I don't like is that FeCl3 stains everything. I guess the disposal of it is much easier. And I may go back to using FeCl3. Also easier to obtain or to make my own.
I can concentrate H2O2, so I can make it fairly quickly without diluting it too much.
Thanks!
--- In Homebrew_PCBs@yahoogroups.com, Russell Shaw <rjshaw@...> wrote:
> http://www.youtube.com/watch?v=Q4tWEse2rDI&feature=em-subs_digest
> <http://www.youtube.com/watch?annotation_id=annotation_37276&feature=iv&src_vid=Q4tWEse2rDI&v=43Xsh9J7S-g>
Re: 10 etchants
2012-12-10 by cunningfellow
Smiling Cat,
This has long been the definitive source of
info on CuCl around here.
http://members.optusnet.com.au/eseychell/PCB/etching_CuCl/index.html
You do need to top up with HCl every once
and a while. Only tiny amounts though.
--- In Homebrew_PCBs@yahoogroups.com, "smilingcat90254" <smilingcat@...> wrote:
> Thanks!
Re: [Homebrew_PCBs] Re: 10 etchants
2012-12-11 by Russell Shaw
> you can replenish Chlorine without adding more HCl. Well he said he will have
> own.
> too much.
> Thanks!
I used to remove iron-based rust stains using a biodegradeable rust killer gel
that is discontinued. Another biodegradeable non-acidic rust killer should work
such as Evaporust (a chelating agent).
Re: 10 etchants
2012-12-12 by jackinnj
Iron Ike removes a lot of "Fe" stains, although FeCl I haven't tried. Here's a link to the product:
http://www.herchem.com/specs/ironike.pdf
I used it on a porcelain tub which had rust stains.
--- In Homebrew_PCBs@yahoogroups.com, lists <Stuartlists@...> wrote:
> In article <ka57qa+rkkl@...>,
> Ferric Chloride stains can be removed with Oxalic acid or commercial stain
> remover.
> http://uk.rs-online.com/web/p/processing-chemicals/2162699/
> Stuart Winsor
> Only plain text for emails
> http://www.asciiribbon.org
