Homebrew_PCBs
Index last updated: 2026-03-31 01:30 UTC
Want to plate drill holes for your double sided PCB's
2012-11-29 by smilingcat90254
I just posted on electronics-101 with an offer to post a constant current source design and theory of operation for use in plating PCBs.
If anyone is interested in 0-5 AMP constant current source speak up and I will post a schematic, BOM, and a layout here. It's relatively simple design. Power source for the circuit comes from an old 12V car battery charger. The stupid ones which doesn't know when the battery is topped off. They can supply 10,20 30AMPS at 12V.
I'm in a process of setting up a plating for my PCB's thus I designed a circuit for such use. component count was one reference supply voltage IC, 7 small signal transistors, one pot, trim pot optional, Analog panel meter so you know what you are putting out, power transistors and 9 resistors I think one small cap for feedback stabilization filter caps.
Sincerely,
Ms. smilingcat
Re: [Homebrew_PCBs] Want to plate drill holes for your double sided PCB's
2012-11-29 by Randall Morgan
I'd love to see your design!
On Wed, Nov 28, 2012 at 8:15 PM, smilingcat90254
> Sincerely,
> Ms. smilingcat
If you ask me if it can be done. The answer is YES, it can always be done.
The correct questions however are... What will it cost, and how long will
it take?
RE: [Homebrew_PCBs] Want to plate drill holes for your double sided PCB's
2012-11-29 by Jeff Heiss
What are you plating to the board? Tin, copper to copper, via holes?
Jeff
_____
On Behalf Of smilingcat90254
Sent: Wednesday, November 28, 2012 11:15 PM
Subject: [Homebrew_PCBs] Want to plate drill holes for your double sided
PCB's
Sincerely,
Ms. smilingcat
2012-11-29 by Rick Sparber
I'll certainly enjoy studying it.
Rick
Sent: Wednesday, November 28, 2012 9:15 PM
PCB's
Sincerely,
Ms. smilingcat
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
2012-11-29 by Kevin Byrne
I would also like to see your design. Is it posted yet? Kevin
Sent: Wednesday, November 28, 2012 11:36 PM
Subject: RE: [Homebrew_PCBs] Want to plate drill holes for your double sided PCB's
Rick
PCB's
Sincerely,
Ms. smilingcat
2012-11-29 by Vicent Colomar Prats
Me too, interested in that design.
2012/11/29 Kevin Byrne <kbyrne10@...>
> From: Rick Sparber <rgsparber@...>
> sided PCB's
> Rick
> -----Original Message-----
> PCB's
> 7
> think
> Sincerely,
> Ms. smilingcat
Re: Want to plate drill holes for your double sided PCB's
2012-11-29 by AlienRelics
He has posted a PNG of the schematic on the Electronics_101 Files area:
http://groups.yahoo.com/group/Electronics_101/files/Constant%20Current%20Source/ireg2.png
Discussion of the specific merits of the design and its construction should occur on that group.
Steve Greenfield AE7HD
--- In Homebrew_PCBs@yahoogroups.com, Vicent Colomar Prats <vicentecolomar@...> wrote:
> > sided PCB's
> > Rick
> > PCB's
> > 7
> > think
> > Sincerely,
> > Ms. smilingcat
I've also posted here as well. BTW, Steve I'm a gurrrlll. See it under Files/CONSTANT CURRENT SOURCE in this group.
Sincerely,
Ms. Smilingcat KI6YMF ;)
> --- In Homebrew_PCBs@yahoogroups.com, Vicent Colomar Prats <vicentecolomar@> wrote:
> > 2012/11/29 Kevin Byrne <kbyrne10@>
> > > From: Rick Sparber <rgsparber@>
> > > sided PCB's
> > > Rick
> > > PCB's
> > > 7
> > > think
> > > Sincerely,
> > > Ms. smilingcat
Oh someone wanted to know what am I plating?
I was going to plate my drilled out hole with copper so that on double sided PC, i'm not having to stick a piece of wire and solder both top and bottom copper.
You could also use it to plate tin if you want. But your plating solution would have to be different.
And minor correction At 5 Amp you can plate 6"x6" double sided PCB not 6"x12"
2012-11-30 by AlienRelics
Oops. There should be a nonspecific gender version of he/she/his/hers for the internet.
--- In Homebrew_PCBs@yahoogroups.com, "smilingcat90254" <smilingcat@...> wrote:
> Sincerely,
RE: [Homebrew_PCBs] Re: Want to plate drill holes for your double sided PCB's
2012-11-30 by Jeff Heiss
What are you using for through-hole activation?
Jeff
_____
Sent: Thursday, November 29, 2012 5:55 PM
Subject: [Homebrew_PCBs] Re: Want to plate drill holes for your double sided
PCB's
copper.
6"x12"
2012-11-30 by smilingcat90254
I've ground up artist's charcoal using 400 grit or 800 grit sharpening stone then add the powdered charcoal into india ink based on some polymer. I checked to see that the artist graphite did indeed conduct. Measured about 500 ohms per 6 "squares" (distance/cross sectional area) or so. Not very scientific but it will do.
Smilingcat
> Jeff
> _____
> PCB's
> copper.
> 6"x12"
How are you getting the charcoal/ink mix into the holes? What size holes
are you using?
Jeff
_____
Sent: Thursday, November 29, 2012 11:52 PM
PCB's
Smilingcat
<mailto:Homebrew_PCBs%40yahoogroups.com> , "Jeff Heiss" <jeff.heiss@...>
> Jeff
> _____
<mailto:Homebrew_PCBs%40yahoogroups.com> ]
> To: Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs%40yahoogroups.com>
sided
> PCB's
sided
> copper.
> 6"x12"
The ink I'm using is Higgins black magic. Says its waterproof after it dries and it IS.
The minimum hole size I currently have are 20mils in diameter. some are at 28mils and others are at 32mils. mounting holes are 100mils.
The charcoal is very fine probably below one mil in diameter. Very fine dust. mixture can be painted on but that's messy. My boards are pretty small so I have only limited number of holes and its just as easy to use a sewing needle. Dip the needle into the ink mixture and get a drop on the needle. insert the tip of the needle into the hole. Capillary action pulls the ink into the hole. I tap the board on a table, covered in throw away paper to catch the excess droplets popped out of the hole. I do this about every ten holes or so. Then I dry it out completely to cure the ink. With only about 20holes or so, the ohmic reading I get from one side to the other side is around 100-200ohms. I think its good enough. Will see.
This idea isn't mine, it came from Thinktink.com. I don't like the idea of agitating the plating solution with aeration. I think that's only bad idea from them. Rest seems pretty sound.
And their lack of good current source.
BTW, you will see a revised schematic for the current source and a thermal shutdown. If people are more inclined in opamp implementation I can do that too.
Thermal shutdown circuit has not been built yet. I will do that tomorrow and check its behavior against my analysis. Past experience says that Vt+ is actually lower than designed value by about 50mV to 100mV. Vt- should be very close to Vbe at onset of turn on so I should be within 10mV or less. Based on crude first pass design. Took me about 5 minutes to do :).
I think I will create a new artwork for this discrete implementation. I use TO-92 transistors and 1206 sized caps and resistors. Anything smaller and my old eyes and my unsteady hand has trouble.
sincerely,
Shawn
> are you using?
> Jeff
Re: [Homebrew_PCBs] Re: Want to plate drill holes for your double sided PCB's
2012-11-30 by John
I'd be interested in some details on how you are going to do the through hole plating.
John
Sent: Thursday, November 29, 2012 10:54 PM
Subject: [Homebrew_PCBs] Re: Want to plate drill holes for your double sided PCB's
2012-11-30 by John
OK already seen your reply to others.
John
Sent: Friday, November 30, 2012 7:51 AM
To: Homebrew_PCBs@yahoogroups.com ; smilingcat@...
Subject: Re: [Homebrew_PCBs] Re: Want to plate drill holes for your double sided PCB's
John
2012-11-30 by Howard Chester
Conductive Ink;- I remember reading of a conductive ink for THP made from Indian ink and Grapite power mixed together to form a "gummy" solution.
The Graphite power is obtained from most locksmith suppliers, used for lubrication in car locks in freezing weather conditions.
Please add me to the list for your plating set-up....sounds good! chester
2012-11-30 by John Anhalt
One thing to consider about plating holes, so far as I know, is that the plating in commercial processes is generally done before circuit etching. Otherwise, getting an electrical contact to each hole may be challenging.
Another approach may be to simply prepare the board as usual, drill the holes, then use a reactive silver paint to "plate" the holes. In the past year, two such paints have been developed based on the Tollens reaction.
In the first reference, silver acetate is prepared and when heated in the presence of ammonia is reduced to silver. In the second article, diethylamine is used to produce formaldehyde upon heating, which then reduces the silver. ACS used to have the full abstract of the Walker and Lewis paper, which has sufficient experimental detail to repeat the results. Unfortunately. that abstract seems to have been taken down. Nevertheless, here are the references for those who may have access:
1) http://pubs.acs.org/doi/abs/10.1021/ja209267c
http://news.illinois.edu/news/12/0112ink_JenniferLewis.html
Citation: Walker, SB and Lewis, JA; JACS 2012,134(3):1419-1421.
2) http://pubs.acs.org/doi/abs/10.1021/am302505j
"DEA in the silver ink decomposes at temperatures higher than 50�C and
generates formaldehyde, which reacts spontaneously with silver ammonia ions to
form silver thin films." (Chen, S-P, et al., November, 2012)
Although the films are thin, they are highly conductive and might be suitable for conducting signals in a double-sided PCB.
John
Thanks, that is a nice review. An important point, which the review also mentions, is the difference between "paints" and reactive precipitates. In reactive silver precipitates, there is no binder to interfere with conduction.
I hope that review remains freely accessible. Unfortunately, it doesn't include experimental detail. I was a bit disappointed in the ACS for taking down the abstract.
John
Sent: Friday, November 30, 2012 7:50 AM
Advances in Conductive Inks across Multiple Applications and Deposition Platforms
http://www.ipcoutlook.org/pdf/advances_conductive_inks_ipc.pdf
No access restriction
John
2012-12-02 by Jeff Heiss
A youtube video shows plating surfaces using silver nitrate, ammonia, sugar,
and sodium hydroxide. Will this work for via plating or would the silver
rub off too easily? The video description says "thin layers of silver can
be wiped off with a cloth if the silver goes where you don't want it.
Thicker layers can be removed by applying hydrochloric acid." If it could
work, a big positive is it does not require hole activation and thus have no
limit on hole/via diameter.
http://www.youtube.com/watch?v=hUX_cpFWNso
_____
On Behalf Of John
Sent: Friday, November 30, 2012 3:05 AM
To: Homebrew_PCBs@yahoogroups.com; smilingcat@...
sided PCB's
John
; smilingcat@... <mailto:smilingcat%40earthlink.net>
sided PCB's
hole plating.
John
PCB's
copper.
6"x12"
2012-12-02 by John Anhalt
The mixture you describe is the Tollens reagent/reaction. As mentioned earlier in this thread, there are modified versions of that reagent that make more durable silver coatings and may therefore be superior for plating holes.
John
Sent: Sunday, December 02, 2012 12:26 AM
Subject: RE: [Homebrew_PCBs] Re: Want to plate drill holes for your double sided PCB's
_____
On Behalf Of John
sided PCB's
John
sided PCB's
hole plating.
John
PCB's
copper.
6"x12"
2012-12-02 by David
Has anyone tried this? I cannot see how the silver will deposit onto an unprepared fibreglass PCB, If it does then it would cover all the board! or am I missing something? from my assaying days as far as I am aware Hydrochloric [muriatic] acid will not disolve silver, nitric acid will, and a combination of the two [aqua regia] will disolve gold and silver and pretty much any other metal.
I may be way off, or i dont understand this process, perhaps someone more enlightened could shed some light on this, as I am also interested in thru hole plating.
> John
> From: Jeff Heiss
> _____
> On Behalf Of John
> sided PCB's
> John
> From: John
> sided PCB's
> hole plating.
> Thanks
> John
> From: smilingcat90254
> PCB's
> copper.
> 6"x12"
2012-12-03 by Russell Shaw
Except Ruthenium.
http://www.youtube.com/watch?v=H7Ng4sOVkns&noredirect=1
