gerber file
gerber file
2012-11-23 by trvrlock
I have two small pcb designs that I need converted to gerbers
Is there anyone that does that.
I have the copper tracks and silk in pdf files
all firms I have asked to make the pcb,s
say they can not do without gerber file
so as a model railway fan prefer not to have to learn
all about making these files
will/would pay for  convertion to gerber file
trevor
Re: [Homebrew_PCBs] gerber file
2012-11-23 by Andrew Hakman
If you already have the layout done, most software will export to a gerber.
The only ones that I'm aware of that won't are the ones that are tied to
one PCB manufacturer, such as expressPCB, but then you can just get it made
with them directly, and there's no need to export to gerber. I would
suggest googling for "[whatever layout program you used] export gerber" and
I'm sure you'll find some simple instructions.
> trevor
Re: gerber file
2012-11-24 by David
If I understand you correctly, is it only Pdf files you have? this being the case, I dont think there is any software that can make gerber files from pdf's, send me the images silkscreens and the schematics with dimensions and specifics for any components you will be using, I will see if I can make the gerber files for you.
 David
--- In Homebrew_PCBs@yahoogroups.com, Andrew Hakman <andrew.hakman@...> wrote:
> > trevor
RE: [Homebrew_PCBs] Re: gerber file
2012-11-24 by Boman33
If the PDF files are high enough resolution and accuracy they possibly could
be used directly for etching a PCB if scaled as required.
In that case the only missing data is to generate the drill file.
Bertho
From: David   Sent: Saturday, November 24, 2012 16:14
David
<mailto:Homebrew_PCBs%40yahoogroups.com> , Andrew Hakman <andrew.hakman@...>
gerber.
made
and
> > trevor
