Old FeCl3 Still Good?
2012-11-18 by mark@ka6wke.net
I have about 2 gallons of the stuff that's been stored in the dark for about 10 years. Wondering if it's still good? By dark I mean in a closed cabinet inside the hazmat shipping box.
Thanks Mark
http://www.ka6wke.net
Re: [Homebrew_PCBs] Old FeCl3 Still Good?
2012-11-18 by Leon Heller
It should be OK.
Leon
Leon Heller
G1HSM
Re: Old FeCl3 Still Good?
2012-11-19 by tda7000
The only way you will really know is to just try it out and see. If it doesn't work, get some more. If it does, great!
> It should be OK.
> Leon
> Leon Heller
> G1HSM
2012-11-19 by Russell Shaw
It will be ok, except some solids may have settled out making it less potent.
The way to fix that (as i did with mine) is shake the bottle well and make sure
all solids are dispersed.
Then when you put some into an etching tank, add some HCl acid and it will
properly disolve any solids. You coud add the acid to the bulk container too.
Add more acid every few months, and keep the tank covered when not in use.
Stray HCl fumes corrodes metals near the tank.
