Spray etcher completed
2012-09-15 by cunningfellow
2012-09-16 by tda7000
--- In Homebrew_PCBs@yahoogroups.com, "cunningfellow" <andrewm1973@...> wrote:
> Only took five years
> http://www.instructables.com/id/The-Etchinator-low-cost-spray-etcher/
> Please give any feed back.
> I am working on the laser plotter write up now.
2012-09-16 by Stefan Trethan
2012-09-16 by Andrew Volk
2012-09-16 by Robin Whittle
> http://www.instructables.com/id/The-Etchinator-low-cost-spray-etcher/I doubt if there is an absolute need for the vanes at the bottom of each
2012-09-16 by cunningfellow
--- In Homebrew_PCBs@yahoogroups.com, "Andrew Volk" <amvweb@...> wrote:
> You might need a lathe, but you don't need a metal lathe. A wood lathe
> would do.
> On the issue of the impeller at the bottom (clever repurposing there), would
> any angling of the blades help with startup or pressure? Could you build a
> sort of Archimedes screw in the bottom section?
> From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
> On Behalf Of tda7000
> Sent: Saturday, September 15, 2012 5:35 PM
> Subject: [Homebrew_PCBs] Re: Spray etcher completed
> I've only just had a quick glance through but it does look really nice, and
> cheap too.
> Lack of a lathe will hinder my ability to make one though, unfortunately.
> <mailto:Homebrew_PCBs%40yahoogroups.com> , "cunningfellow" <andrewm1973@>
> Robin Wrote:Early versions didn't have vanes.
> vanes at the bottom of each rotating tube
> <SNIP>
> <SNIP>Without the strips you do get banding.
> Likewise, I doubt that the three vertical
> strips you glued inside the tube would be
> necessary
> <SNIP>
> <SNIP>No lower bearing. Thats why care is needed
> I didn't see any lower bearing. Do you
> have the end of the rotating tubes rubbing
> against the lower plastic framework?
> <SNIP>I have done this speed modulation and it did
> I think the problem of evenly distributing
> the etchant on the PCB might be solved to
> some degree by cycling the speed of
> rotation.
> <SNIP>Yes the one I used was "icon" brand from
> went to my
> brother's place for lunch. Lo and behold
> he had some of the same plastic containers
> in his pantry! The were made by Icon:
> http://www.iconplastics.com.au
> near Melbourne. He recalls he bought them
> at Bunnings.
2012-09-16 by Malcolm Parker-Lisberg
2012-09-16 by designer_craig
2012-09-17 by tda7000
--- In Homebrew_PCBs@yahoogroups.com, "designer_craig" <cs6061@...> wrote:
> Nice job.
> I built a splash etcher years ago and found the trick is to get some randomness to the splash. I did this by making the radial edge of the splashier paddle very irregular.
> I am wondering if some external surface features on your tubes may make a finer spray pattern. I got this idea from cleaning paint rollers with the garden hose. With the water hose stream you can spin up the rollers really fast but the interesting thing is the fine spray of water that departs the spinning roller. All the little hairs of the roller nap act like little emitters. I saw a likely roller cover at the home center a few weeks ago, the tube was PVC but not sure about the nap. It would have to be tested to see its resistance to the chemistry.
> Craig
> --- In Homebrew_PCBs@yahoogroups.com, "cunningfellow" <andrewm1973@> wrote:
2012-09-23 by jcarlosmor
2012-09-23 by Emil Johnsen
> Only took five yearsLooks like a very nice design. Can't wait to see the laser plotter :)
2012-09-24 by cunningfellow
> Emil Johnsen wrote:Motors I have at the moment pull only 9
> <SNIP>
> How many watts does the motors need to be?
2012-09-29 by Daniel
2012-10-01 by Daniel
--- In Homebrew_PCBs@yahoogroups.com, "Daniel" <dandumit@...> wrote:
> First of all you have made an excellent article !
> regarding a sophisticated impeller/fan . There a lot of activity / enthusiasts that are building at home made 3D printers (also there is a group on yahoo). Also are available commercial services for this. On a such a printer can be made this impeller fairly easy . Also I am interested to participate on this "improvement" since I was planning for a long time ago to build a spray etcher...
> Regards,
> Daniel
2012-10-04 by cunningfellow
> Daniel wrote:I may try play with a 3D printer to improve the
> This kind of turbine would work ?
> http://grabcad.com/library/francis-turbine-runner--1
2012-10-08 by Daniel
>Do you have a link or image about it? I understand that you consider that would be needed exactly the opposite impeller that I have proposed?
> I would like to try an axial inflow radial out.
2012-10-11 by Andrew
> > <SNIP>
> They had startup reliability problems.
> The vanes fixed the startup issues.
> The BEST solution for the bottom is
> a radial that is a conical shape with
> a very slight axial inflow.
> I knew people would complain about
> needing a lathe. I didn't want to
> make an impeller that needed a 5
> axis CNC machine to make :D
> (The toy wheel was something to make
> it easy for the average person to do)
> > <SNIP>
> > necessary
> > <SNIP>
> I think it was Alien Relics here that tried
> to make his tube with a spiral of holes
> and found his banding was the exact distance
> of the spirals.
> RoelCNC made his tubes with a bottom bearing
> and it does not have such banding. (even
> without the dams/strips)
> This indicates to me the out of round
> condition is causing the issue.
> > <SNIP>
> in the building to keep it round.
> > <SNIP>
> > rotation.
> even out the banding.
> I have also used a gear head motor to slowy
> cycle the PCB holder up and down.
> Neither is now neccesary now I have the
> banding issues sorted at the source.
> > <SNIP>
> > went to my
> > at Bunnings.
> bunnies (where lower prices where just at
> the begining)
2012-10-11 by cunningfellow
> Andrew "awakephd" wrote:Files > Etchinator > Impeller.png
> <SNIP>
> Is this what you have in mind for "the
> best solution"? If not, any chance of a
> drawing to show what you have in mind?
2012-10-12 by cunningfellow
> Daniel wrote:Daniel,
