Making film
Making film
2012-08-08 by Jefferson Siy
Am choosing between LaserStar and JetStar premium for making Masks.
Anyone who has tried them both?
I usually use 85 GSM tracing paper, but the black areas are full of holes.
Will the Jetstar/LaserStar have fully black areas?
Jeff
Re: [Homebrew_PCBs] Making film
2012-08-08 by Leon Heller
On 08/08/2012 13:00, Jefferson Siy wrote:
> Hi,
It depends on the printer. I get excellent results with an HP Deskjet
5940 printer using JetStar Premium film.
Leon
Leon Heller
G1HSM
2012-08-08 by John Anhalt
If you have problems with holes, try my dry erase/white board method.  I posted pictures here and on my blog here: http://www.electro-tech-online.com/blogs/jpanhalt/213-improved-laserjet-transparencies-pcb.html
John
  Sent: Wednesday, August 08, 2012 8:00 AM
  Subject: [Homebrew_PCBs] Making film
  Jeff
Re: Making film
2012-08-08 by tda7000
For UV photoresist PCBs I've been using a generic brand of laser printer transparencies from the local Warehouse Stationery.
I don't get many holes to begin with because I am using the negative process so most of the transparency is left .. transparent.
I touch it up with the whiteboard marker trick anyway, and have found so far to have no big issues, except with cleaning the marker residue off afterwards. I found a soft brush and detergent worked well.
> > Hi,
> Leon
> Leon Heller
> G1HSM
Re: [Homebrew_PCBs] Making film - laser printed "Mylar" phototools
2012-08-09 by Robin Whittle
Short version:  I have had success making phototools for negative
                photoresist film (Riston) using both the MegaUK
                LaserStar and an un-named A4 transparency film from
                Canada.  The Canadian film is superior in that one side
                is gloss, the printing side is near gloss and the
                material itself, in total with its surfaces,
                creates no appreciable diffusion of light. I don't have
                any problems with "holes" in the toner, with either
                of these films, using a Brother HL-5250DN laser
                printer.
(In the archives, to see this message with proper indentation, please
use Show Message Option > Use Fixed Width Font.)
Hi Jefferson,
I assume you are referring to:
  http://www.megauk.com/artwork_films.php
I have used Laserstar with a Brother HL-5250DN for making negative
phototools (generally black but transparent where the copper tracks will
remain) and have had no trouble with "holes" in the toner.
There could be various reasons for such holes or unwanted distribution
of toner.  One is the toner sliding around on the surface after being
deposited (or while being deposited) by the drum and before (or while)
being melted by the fuser rollers.  I think the toner might be shaken
around if the film vibrated inside the printer, between the drum and the
fuser rollers.  This may happen more if it is stiff and is used in a
relatively small piece, so one end or the other is flapping around,
hitting things, inside the laser printer while the toner is supposed to
be sitting still on it.
Another cause of "holes" in the toner may be that the fuser roller
temperature and pressure is inadequate to completely bond the toner to
the film.  (I have read that Brother laser printers have a higher fuser
roller temperature than printers of other companies.  However I don't
have any solid references for this.)  Again, a shiny film is probably
harder to bond toner to than one with a special coating or one which
simply has a matte surface, and therefore a more complex, non-flat,
surface to bond to.
It is my impression that these problems are worsened by the film having
a completely smooth - that is shiny/glossy - surface.
As far as I know, the LaserStar is simply drafting film - matte on both
sides and perhaps with the plastic itself having a somewhat milky
(optical diffusing) nature, though most likely the plastic itself is
water-clear transparent.  As far as I know, this material is what is
commonly referred to by the DuPont tradename "Mylar".  I have a roll of
drafting film from the early 1980s for a big old (piano-sized) Benson
plotter.  It is slightly thicker (90 microns) but otherwise looks the
same as LaserStar - and it behaves just the same.   I suspect that any
"Mylar" drafting film will work the same way.  I know of no evidence
that the LaserStar is coated with anything, or that it is is "specially
formulated".  It is about 88 microns thick.
As best I understand it the following terms refer to the same material:
1 - Mylar.
2 - boPET = Biaxially Oriented Polyethylene Terephthalate:
    http://en.wikipedia.org/wiki/BoPET
    Polyethylene Terephthalate has a far more complex structure than
    ordinary Polyethylene ("Polythene").
    The Biaxially Oriented film is made by stretching the amorphous
    film so the polymer molecules are stretched, aligned parallel to
    the surface and then heat treated to set them in this position and
    make them transparent.  (Many soft-drink and other plastic bottles
    are made of Polyethylene Terephthalate using a blowing processs,
    which I guess does a similar job of aligning the molecules.)
3 - Polyester.  "Polyethylene Terephthalate" is too much of a
    mouthful, so the term "Polyester" is used instead.  This
    does not imply that the material has been biaxially oriented,
    but as far as I know, any "polyester" film used like a piece
    of paper for printing or drawing would be BOPET.
    http://en.wikipedia.org/wiki/Polyester
The double-matte nature of the LaserStar film seems to be quite friendly
to the toner.  Even though the drum of my printer is quite old, I get
images which are solid enough and consistent enough to expose Riston
well.  (I am using a 500 watt quartz halogen incandescent floodlight -
see my previous messages.)  With a photodiode, using white incandescent
light, I can tell the black areas pass only about 1/7 of the light which
are passed by the clear areas.  There is some variation in darkness, and
the lighter parts of the toner are the limiting factor, but these are
smaller than the size of the photodiode so I don't know how they
attenuate light.  I guess the worst case would be a 4:1 or 5:1 reduction
in light.  In my experience this level of contrast is quite sufficient
to get clear exposures with Riston.
I recently bought some (presumably) BOPET film which I think is even
better.  The double-matte nature of LaserStar means that some light is
reflected by both surfaces and all the light which passes through both
surfaces is diffused.  Therefore LaserStar does not produce a clear
shadow.  This may not matter if the toner side is pressed to within a
few microns or tens of microns of the thin BOPET protective film on top
of the Riston.  This can be hard to achieve.  In general, it would be
better to have a phototool which did not diffuse the light at all,
especially with a narrrow light-source such as the incandesent 400W lamp
at 45cm or so, with most of the light coming from an angle of 0.15
radians.  I bent the reflector a little to make the light source more
compact, but I think this is generally not necessary with the film I am
describing.
This inkjet / laser transparency film from Canada is 11 microns thick
and is available in A4 and A3 sizes.  It is gloss on one side and very
close to gloss on the treated side, which works well with my HL-5250DN
(true 1200DPI mono), and my 600DPI color Brother HL-4040CN.  There is no
appreciable diffusion of the light which passes through this material,
so for the purposes of a phototool creating a shadow, I regard it as
being as transparent and non-diffusing as a photographic film phototool.
  http://asc365.com/?ID=WW00013
This is from ASC365.COM in Toronto (with an office in Miami).
In Melbourne (Australia) there is an eBay seller who is evidently
associated with the above company:
  http://myworld.ebay.com.au/printingsupplies2009/
  http://stores.ebay.com.au/ascscreenprinting
They only ship to Australian destinations, so if viewed from other eBay
sites, this seller may show nothing is available.
asc360.com apparently ship to all countries, but they need to
communicate via email regarding shipping costs.  The A4 sheets are
USD$0.45 each and the A3 sheets are USD$0.90.
They also sell a "blackening agent" on the same page.
There are plenty of Brother laser printers available second hand, often
for $50 or so.  Most of them are 600DPI, but that will be fine for all
practical purposes.  A 600DPI laser printer will give a much sharper
image than is possible with any inkjet, as far as I know, since there is
no diffusion of liquid ink.
The 1200DPI Brother printers such as the now-obsolete HL-5250DN or its
current model equivalent HL-5350DN (and related models) are true 1200
DPI.  My old HL-5250DN produces an extraordinarily sharp image.  I have
used it to make Riston lines as small as 0.005 inch with 0.005 inch
spacings (127 micron)  That was pushing the limits, but the results were
really solid at 0.010 inch (254 micron) which is as small a track as I
would probably want on a PCB.  (Etching is another matter, which I don't
yet have much experience with.)
The HL-5250DN will handle legal paper - 8.5 x 14 inches (216 x 355mm) -
while the current model series has a maximum paper size of A4 (210 x 297
mm).
  - Robin   http://www.firstpr.com.au/pcb-diy/
2012-08-10 by DJ Delorie
I use an Epson R280 inkjet with Jetstar Premium and some custom driver
software, and get "nearly perfect" black films out of it.  You have to
use the custom driver so that you have control over every ink drop,
though, as normal software doesn't know about the ultra-fast trying and
tends to "dither" the ink, which IMHO ruins the films.  A larger number
of smaller drops, with a more regular pattern, leads to better films.
One thing I do, though, is clean the heads before every print, then do a
test print on plain paper (same driver, different settings, same ink
drops but fewer of them) to verify the head is clean.  Dirty heads tend
to place the drops more randomly off-center.
2012-08-12 by Jefferson Siy
Planing to Use a canon printer with the jetstar Premium.
Anyone had used a canon on this film?
I would like to get the Epson because of the cheaper inks, but am afraid
the ink will get stuck in the printhead because i wont be printing that
often. For the canon, it will be easier to clean the head with an
ultrasonic cleaner if it gets stuck. I think.
Jeff
2012-08-12 by Leon Heller
You might not need the Premium film for a Canon printer. It definitely
is needed for some HP printers, like the 5940 that I use.
Leon
Leon Heller
G1HSM
