Inconsistent scaling with Samsung ML-2165
2012-06-24 by godzilera
Although I have been making successful single-sided PCBs for a while now, I just recently decided to try making a double sided board with SMD (.5mm TQFP) parts. So, I went out and bought a new inexpensive Samsung ML-2165 printer. The problem I am having is getting the scaling right. It's inconsistent and varies from print to print. Plain paper works pretty good, but the Pulsar paper comes out too short. I tried adjusting the scaling in the Kicad print dialog, but it seems to come out either too wide or too short. Very frustrating, and I have wasted four sheets of TTS paper so far.
I have a couple of boxes of HP glossy photo paper, so I may try that.
Any advice?
Pete
Re: Inconsistent scaling with Samsung ML-2165
2012-06-25 by tda7000
Scaling seems to be a problem with many (or all) laser printers.
But I have not had too much of an issue with it with my old Lexmark T522.
For toner-transfer, I print from KiCAD (PCBnew) directly with "Accurate Scale 1" chosen and both scale adjustments at 1.000000 (default)
I did measure recently a 100mm x 100mm square which came out to something like 99.5mm x 99.8mm which seems good enough for what I do (Through hole and large SMDs)
That was on plain paper. I don't know if it changes on TTS as I haven't used that yet.
So far, I've only used thin magazine paper taped onto plain paper.
For UV process I use negative resist, so I have to export from KiCAD as a negative plot postscript file (again, no scale changes) load in GIMP, and print out on a transparency (Then, I use the whiteboard marker trick to darken it)
I did find out however that I have to make sure to ignore borders and increase the page size to correct size in the print settings or it shrinks everything badly. Again, size is not exactly spot on, but it's good enough for me.
Of course, if all your printing is direct from KiCAD without other formats\software involved, then I guess it is the printer itself.
Are you changing the software settings for the different paper? Maybe try changing if you are not, or not changing them if you are... I don't know otherwise.
> Any advice?
> Thanks,
> Pete
Re: [Homebrew_PCBs] Inconsistent scaling with Samsung ML-2165
2012-06-25 by kabowers@NorthState.net
TTS paper so far.
>Any advice?
>Thanks,
>Pete
Make certain the printer properties don't have any sort
of "fit to page" option set. Sometimes they can slip in
a surprise 8=(
Keith Bowers WB4LSJ- Thomasville, NC
2012-06-25 by Dennis
I use multiple printers and suddenly all of them seemed to develop a similar problem to yours at the same time.
Turned out it was my son's A/C cycling and pulling the power down on that circuit. On my fastest printer you can actually hear the printer slow in sync with the power drop. It shouldn't effect the scaling but it did.
My oldest printer doesn't do this at all, so it tells me that manufacturers are probably making the power supplies as cheap as they can.
I've now got a power stabilizer thing for big home theaters and the problem is gone.
You may also want to make sure there are no power saving or toner saving settings turned on, no telling how the power or toner is "saved"!
> Any advice?
> Thanks,
> Pete
2012-06-25 by godzilera
Hello everyone,
thanks for the responses.
I forgot to mention that I was only getting scaling problems in the 'Y' direction. Speed of the paper through the printer is what affects this scaling.
After a few tests, I have gotten much better results, at least with the HP photo paper. I figured that the inexpensive printer was struggling to drag the paper out of the bin and into the unit, especially since the paper path of this printer is not straight at all.
So, instead of printing my PCB design at the top of the page, I asked the driver to flip the page upside down, so that the design now comes out at the bottom.
I think the printer is struggling to pull out the page and slows down at the beginning. Once the paper hits the fuser, I think this stabilizes, and the bottom of the page comes out a the right speed. I think this is more pronounced with the thicker paper, as there is a one inch difference between the position of the PCB layout on a page of regular paper and photo paper. This seems to confirm that the thicker photo paper moves more slowly through the printer, at least initially.
> > Any advice?
> > Thanks,
> > Pete
Re: [Homebrew_PCBs] Re: Inconsistent scaling with Samsung ML-2165
2012-06-25 by Donald H Locker
Note to self - no Samsung ML-2165 printer.
Donald.
*Plain Text* email -- it's an accessibility issue
()  no proprietary attachments; no html mail
/\  ascii ribbon campaign - <www.asciiribbon.org>
> From: "godzilera" <yah.5.peteben@...>
> Sent: Monday, June 25, 2012 12:59:27 PM
> Subject: [Homebrew_PCBs] Re: Inconsistent scaling with Samsung ML-2165
> Hello everyone,
> this scaling.
> out at the bottom.
> initially.
> Thanks,
> > scaling but it did.
> > they can.
> > problem is gone.
> > "saved"!
> > > paper so far.
> > > that.
> > > Any advice?
> > > Thanks,
> > > Pete
2012-06-25 by KeepIt SimpleStupid
Somewhere, I read  that one of the things that a thicker paper setting does on an HP printer is to slow down the paper feed to primarily prevent jamming.  Then i would imagine that fuser temperature could also be altered as well based on the paper settings.
Date: Monday, June 25, 2012, 12:59 PM
      Hello everyone,
2012-06-25 by Jim
Hi Pete,
Inconsistencies of scale have been a problem with every printer I've ever used.  I don't make a lot of pcbs, let alone double sided, but the problem also shows up when you print schematic diagrams that are divided among several pages horizontally, or vertically, or worse, both.  The lines are close, but there can be vertical or horizontal gaps where they should meet.  My printers over the years have been either HP inkjets and IBM Laserjets.... no off brands.
However, I have printed things to "scale" using the free graphics viewer "Irfanview".  When printing, the size of the image can be adjusted in width or length by hundreths of a centimeter or inch. After printing something I need to 1:1 scale, I will measure the print's dimensions and use the software to adjust one or the other until it is right.  Recently made some "actual size" outlines of two GI7B Russian triode tubes from an image on a "spec sheet", glued them to cardboard and cut them out.  Needed to check the clearances in a proposed rf amplifier chassis; turned into a "tight" fit, but doable.  Much easier to visualize where everything is supposed to fit, including clearances because of the high voltages.
You might be able to do the same. Start with one side and print it on normal paper, adjusting the dimensions until they are "right".  Then do the same for the other side of the board, but hold them back to back against a light source.  Adjust the second layer to match the top layer.  Incorporating registration marks at the corners of the layers may help; usually its a "plus" sign by itself or in a circle.
Normal computer paper is dimensionally stable enough for you to check your work.  Make sure the printer's paper handling tracks and rollers are clean, too.
Now, if your pcb is bigger than a full size piece of computer paper, this method won't work!
Jimmie
> Any advice?
> Thanks,
> Pete
Interesting idea...
For convenience, I load all my good paper from the front feeder in my printer, which as I think about it, has a very straight path all the way to the fuser.
Only standard copy paper comes from the bottom tray.
I'm guessing your printer doesn't have an alternative paper input?
> Hello everyone,
> Thanks,
> > > Any advice?
> > > Thanks,
> > > Pete
2012-06-26 by DJ Delorie
When I did TT, my process was to print a "calibration board" and go
through all the steps until just before etching, and measure the pcb
itself to find out what the X and Y scale factors are.  Each step along
the way might alter the dimensions somewhat, so it's important to just
check the results you care about.
gEDA/PCB, btw, has separate X and Y calibration values you can fill in
to adjust printouts, just for toner transfer.
2012-06-28 by godzilera
It's not a question of just adjusting the scaling; the problem is that it's inconsistent. Sometimes it would come out too small, sometimes it would come out too big...
However I have now managed to print at least three perfect copies using the HP photo paper by printing my layout at the bottom of the page. This seems to confirm that the speed of the paper is only inconsistent at the top of the page. I think that is because the roller that pulls the paper out of the tray is also responsible for pushing it over the drum, and some slippage occurs with the thicker and glossier paper. Once the paper hits the fuser though, then there is enough pressure to pull the paper with a constant speed.
Anyways, my board has been printed and etched, and it looks perfect. In the future, I think I will probably cut strips of TTS or photo paper and tape it to another sheet to make sure I always print on the bottom of the page without wasting a whole sheet.
In general, I think the straighter the paper path, the better. With the old  HP LJ 4 at the office I used to use the manual feed and open up the back, so that the paper would not curve up back to the front, but that is not possible on this ultra-small Samsung.
For now, the little Samsung at $90 works fine as long as I can work around its limitations.
Pete
2012-06-28 by eugenio
Hi guys, in the last two years i've implemented every imaginable way of
making pcb's at home.
One of these ways was Mark Lerman's direct laserjet printing, when i
finished the printer-machine i realized that the printer was
inconsistent in scaling.
After studying the inners of the machine i saw that the printer was
perfect in the execution, the brushless motor was synced perfectly with
laser and with a perfect constant speed and the clutches were working
perfect. The guilty is the micro-slips of the pcb with the rollers. It
can be seen testing that transparencies are more inconsistent than
normal paper for example.
The easy solution is to harden the springs of the rollers, and the
perfect but difficult solution is to make a carrier with the same speed
as the photosensible roller.
I was able to direct print multiple times in the same pcb and you
wouldn't notice, and i had perfect registration in two sides. I used a
fpga to substitute the sensors stuff of the machine.
For the curious, Mark Lermans's way didn't fit my needs so i discarded
it, but for other problems different that consistency, the most
important one was that toner is not a good resist for plating with 4-5
mils precission.
> Thanks,
> Pete
2012-06-28 by Leslie Schwartz
Possibly a printer like the old Espon Stylus 3000 which has a tractor feed
mechanism could produce more accurate direct prints? I would not be able to
modify and re-engineer the printer to work for this application, but it
seems you would be able to do it.
On Behalf Of eugenio
Sent: Thursday, June 28, 2012 4:39 AM
Subject: Re: [Homebrew_PCBs] Re: Inconsistent scaling with Samsung ML-2165
finished the printer-machine i realized that the printer was inconsistent in
scaling.
After studying the inners of the machine i saw that the printer was perfect
in the execution, the brushless motor was synced perfectly with laser and
with a perfect constant speed and the clutches were working perfect. The
guilty is the micro-slips of the pcb with the rollers. It can be seen
testing that transparencies are more inconsistent than normal paper for
example.
The easy solution is to harden the springs of the rollers, and the perfect
but difficult solution is to make a carrier with the same speed as the
I was able to direct print multiple times in the same pcb and you wouldn't
notice, and i had perfect registration in two sides. I used a fpga to
For the curious, Mark Lermans's way didn't fit my needs so i discarded it,
but for other problems different that consistency, the most important one
was that toner is not a good resist for plating with 4-5 mils precission.
come out too big...
speed.
its limitations.
> Thanks,
> Pete
>> along the way might alter the dimensions somewhat, so it's important
>> to just check the results you care about.
>> in to adjust printouts, just for toner transfer.
Photos:
pcb-specific laminator/exposure/etc printer...
2012-06-28 by DJ Delorie
Is it time for someone to purpose-design a direct-to-pcb printer?
Probably way too expensive to consider, but still...
Maybe something that laminates UV film on, and has a linear array of
high power UV LEDs to expose the film as it's being laminated, on both
sides...  Include an infeed tray with registration pins for pre-drilled
PCBs...  pre-drill, drop on pins, press button, when pcb comes out the
other side you wait 15 minutes, peel off the outer protective film, and
develop.  Maybe it could laminate (or just use a sticky-backed film) on
a UV-opaque film over the UV film after exposure, so you don't even need
a darkroom :-) Add a tiny inkjet head on the way out to print timestamp
and job information, and you're done!
ok, blue-skying over :-)
2012-06-28 by AlienRelics
Or you could add a gear to the platen and use a matching linear gear on the tray.
I have several Epson Stylus 3000 printers, if anyone is close to Lacey, WA USA and wants to experiment with one. But then we should move that discussion over to the inkjet PCB resist group.
Steve Greenfield AE7HD
> -----Original Message-----
> scaling.
> example.
> come out too big...
> speed.
> its limitations.
> > Thanks,
> > Pete
> Photos:
Re: pcb-specific laminator/exposure/etc printer...
2012-06-28 by James
I suspect it will be difficult to come up with something that will be affordable yet offer decent performance.
I'm intrigued at the thought of a laser photoplotter that would cure UV resist. Either an X-Y plotter table with a 405nm laser in place of a pen, or a scanner assembly from a laser printer with a feeder to run the board through.
Really though I've got the laser printer toner transfer process pretty well dialed in, and for any time I want more than one board and don't mind waiting, Seeed Studio is ridiculously cheap so it's easier to just send off for a batch after I've etched a prototype at home.
Re: [Homebrew_PCBs] pcb-specific laminator/exposure/etc printer...
2012-06-29 by Riley
might be more likely as a printhead for fab@home / reprap / makerbot
Riley
Subject: [Homebrew_PCBs] pcb-specific laminator/exposure/etc printer...
Date: Thursday, June 28, 2012, 1:36 PM
2012-06-29 by eugenio
In the fabs there's a system call LDI, laser direct imaging, it's
similar to the laser system of a laser printer but it's a uv laser
instead infrared, and instead focusing the laser in the roller it points
to the pcb dryfilm (a special more sensitive one). It's very fast and it
doesn't need masks.
2012-06-29 by designer_craig
Janes,
The UV laser has been done -- check back in the archives Zoltan built a system basically replacing the print head with a UV laser diode and raster scanning the board. It was a little slow but had stunning resolution and chrispness in the image.  It's on my project list, just not near the top.
Craig
Re: [Homebrew_PCBs] Re: pcb-specific laminator/exposure/etc printer...
2012-06-29 by Benjamin Blumer
I like the idea of an area of LEDs.  I wonder what kind of resolution /
LEDs/inch one could get.
Sent from my iPad
On 2012-06-29, at 8:30 AM, designer_craig <cs6061@...> wrote:
Janes,
Craig
through.
2012-06-30 by AlienRelics
A few people here did some tests with toner transfer to determine if 300dpi or 600dpi Laser printer resolution was sufficient.
The end result was that 600dpi was required.
So to make a board 2x3 inches, you'll need 2x3x600 = 30,000 LEDs. And they'll need to be about a thousandth of an inch square in size.
> Sent from my iPad
> Janes,
> Craig
> through.
2012-06-30 by DJ Delorie
Benjamin Blumer <b3nzilla@...> writes:
Standard LED laser printers are up to 1200 dpi (8.5*1200=10,200 LEDs),
no reason why you couldn't do 1000 dpi.  You'd only need one row of
them, so for a 12" wide machine you'd need a strip of 12,000.
The trick would be engineering an emitter that could do UV with
sufficient energy to expose the film as it passed by.
2012-06-30 by Andrew
DJ, this sounds like a project that is right up your alley! :)
2012-06-30 by Benjamin Blumer
I was thinking a single row of LEDs with the board being carried through by
push wheels.  Not quite as snazzy as one LED/pixel, though more feasible
perhaps.  Though, I don't really know how feasible it is to have a row of
2000+ Individually addressable LEDs anyways.
Although,  this does remind me of the 3D printers that harden layer by
layer of plastic using a projector.  Though, it would mean we'd need a
photoresist sensitive to visible light.
Sent from my iPad
> Sent from my iPad
> Janes,
> Craig
and
need
timestamp
> through.
off
2012-06-30 by BOOTS HUGHSTON
I had a Brother Printer that was an LED printer about 10 years ago, it worked great. I used it for years. It had a bar that went across the paper with 4 rows of LEDs. Very rugged machine, my guess it would expose UV film also. The LEDs looked red but I think they put out white light to fuse the toner to the paper. Check around you may be able to find a used one to hack.
Good Luck, Boots-2b1
To: "Homebrew_PCBs@yahoogroups.com" <Homebrew_PCBs@yahoogroups.com>
Sent: Saturday, June 30, 2012 11:41 AM
Subject: Re: [Homebrew_PCBs] Re: pcb-specific laminator/exposure/etc printer...
Sent from my iPad
> Sent from my iPad
> Janes,
> Craig
and
need
timestamp
> through.
off
2012-06-30 by kabowers@NorthState.net
>Sent from my iPad
What says you can't space the LEDs farther apart across the narrow dimension and
place the board in a carrier? Then make multiple passes with the carrier along
the long dimension stepping the LED assembly sideways a small increment each
 pass.  This would require good tolerance/repeatability on the long dimension (which
wouldn't be difficult as it would only move back and forth). You get the same
result as a high density line of LEDs, just slower.
Writing the driver software would be interesting too 8=)
If you are into machining think of the way an automatic surface grinder works.
2012-06-30 by tda7000
Much easier to do this, I would think:
http://www.youtube.com/watch?v=fi4P-Bwc6g8
http://www.das-labor.org/wiki/LaserExposer
> >Sent from my iPad
das-labor.org UV scanner direct exposure of photoresist
2012-07-01 by Robin Whittle
In "Re: pcb-specific laminator/exposure/etc printer...", on 2012-07-01,
This looks difficult to do, by most standards, since there is customised
hardware and two microcontrollers.  There would be significant problems
calibrating it, correcting for the out-of-focus laser beam and the
non-linear sweep across the board.
Also, I think it would be difficult to align exposures for double-sided
compared to the alternative of aligning two phototools (or perhaps
transfer paper with toner) facing each other, and then slipping the PCB
material in between them.
I think it is a really great project, but I don't feel inclined to do
all this work myself.
  - Robin
RE: [Homebrew_PCBs] Re: pcb-specific laminator/exposure/etc printer...
2012-07-01 by Tony Smith
worked
rows of
paper.
Surprisingly they still make those, they don't seem to be very common
though.  They've been around for a while, I remember Brother & OkiData
models from over 20 years ago.
They work the same way as laser printers, except without the need to scan
the laser back & forth (so no moving parts).  In theory that makes them more
reliable and faster, but they've always been a bit of an also-ran.  I know
they'll do 1200 DPI, so the quality is ok.  I don't know why they never
really took off, licencing issues maybe?
I've never bother to have a look at the innards of one.  I assume the
technology is similar to the LED scanners you can get (Canon LIDE etc); LED
chips are pretty small so you can cram a few in there, but 1200 of them per
inch is rather impressive, especially across 8-11 inches or so.  Staggered
maybe?  Driving one of those would be an 'interesting' challenge, at 8"
that's 10,000 LEDs (triple for colour?)
There are also LCD printers, those just use a 'shutter' to control the
light.  I haven't seen one of those for ages.
Tony
2012-07-01 by Jeff Heiss
Could you provide a make/model of one that is still made today?
Jeff
  _____
On Behalf Of Tony Smith
Sent: Sunday, July 01, 2012 1:14 AM
Subject: RE: [Homebrew_PCBs] Re: pcb-specific laminator/exposure/etc
printer...
worked
rows of
paper.
Tony
Brother make a couple, eg
http://www.brother-usa.com/printer/ModelDetail.aspx?ProductID=HL3075CW but
tend not to mention it's a LED printer, just a 'colour printer'.  I guess
that's not to scare people looking for a 'laser printer'.
Oki seem to only do high-end ones, like
http://www.okiprinters.net.au/PRODUCTS/OKIFAXMACHINES/OKIC711nA4ColourLED442
05404Free3YrWarranty.
$1400 is a bit much, especially when a similar spec laser is only around
$750, see bottom of
http://www.okiprinters.net.au/PRODUCTS/COLOURPRINTERS/A4COLOURPRINTERS.
Still, there should be few used ones kicking around.
And yes, they still make dot matrix ones:
http://www.okiprinters.net.au/PRODUCTS/OKIDOTMATRIXPRINTERS.  Not cheap
either!  (Could be old stock from 1991...)
Tony
technology is
> similar to the LED scanners you can get (Canon LIDE etc); LED chips are
pretty
> small so you can cram a few in there, but 1200 of them per inch is rather
> impressive, especially across 8-11 inches or so. Staggered maybe? Driving
one of
Actually, just looking at the spec for the Oki C711 I see 1200 x 600 DPI, so
they're pulling the old scanner trick.  The LED portion is only 600 DPI, so
'only' 5,000 LEDs across.
Tony
Re: das-labor.org UV scanner direct exposure of photoresist
2012-07-01 by wayne.causey
Robin, thanks for providing the links for an outstanding Laser Direct Imaging project. Does anyone know of any similar projects?
Wayne
>   - Robin
2012-07-02 by tda7000
I believe I posted the links about the German project? ...Anyway...
Another idea was here: http://4hv.org/e107_plugins/forum/forum_viewtopic.php?66471
The first guy seems to have had an idea of using a grid of LEDs, but I don't think you can get them small enough.
However, in the 2nd half of that thread, there was another guy with a UV laser diode on a plotter table, the photos show that it looks like the board came out pretty well.
This is something I thought of trying out, but it looks expensive. Also double-sided would be a pain.
Laser-printed transparencies and toner-transfer still works well for me so far...
--- In Homebrew_PCBs@yahoogroups.com, "wayne.causey" <wayne.causey@...> wrote:
> Wayne
> >   - Robin
2012-07-02 by Robin Whittle
Hi Wayne,
It was tda7000 who first mentioned this project.  I responded with a new
subject in the hope that this would make it easier to find in the archives.
I think a closely spaced line of discrete SMD UV LEDs could be used,
with Riston or similar negative photo resist (exposure makes it
polymerize, resist development and so protect the copper).  The light
from the LED array could be focused by an old SLR camera lens or similar
into a row of points on the PCB.  Then, the whole array and lens
arrangement could be scanned X and Y by a plotter mechanism or a
purpose-built X-Y CNC table.  The more LEDs in the array the fewer scans
would be required.  There would be some finicky driving and alignment
problems to solve.
tda7000 also mentioned another project.  A single UV LED, focused on the
board, driven by a plotter as in the 6th message at:
http://4hv.org/e107_plugins/forum/forum_viewtopic.php?66471 and
http://www.youtube.com/watch?gl=DE&feature=channel_page&hl=de&v=JG5qUhn9sSM
seems to me a lot easier.  It would be relatively slow, but that should
not be a problem for must of us folks.  This is simple, since the LED is
driven by the signal which used to drive the pen solenoid.
I think some PCB programs still have a plotter driver.  I have just
bought the 500 pin limit Starter Kit of the Proteus ISIS Schematic and
ARES PCB system (USD$249, UKP150, E200):
  http://www.labcenter.com/products/pcb_overview.cfm
The ARES PCB system has a plotter driver, but I am yet to design a
board, so I can't be sure what it does.
  - Robin
> Wayne
2012-07-02 by wayne.causey
tda7000,
Thanks for all three links concerning Laser Direct Imaging for PCBs. Any further links/sources for info on this topic will also be appreciated.
Thanks.
Wayne
> --- In Homebrew_PCBs@yahoogroups.com, "wayne.causey" <wayne.causey@> wrote:
> > Wayne
> > >   - Robin
Re: [Homebrew_PCBs] Re: das-labor.org UV scanner direct exposure of photoresist
2012-07-02 by Duane C. Johnson
Where do you get UV SMD LEDs.
They seem very expensive?
What wavelength should I look for?
Duane
     Home of the $35 Solar Tracker      Receiver
    http://www.redrok.com/led3xassm.htm      [*]
   Powered by             &#92;  &#92;     &#92;        //|
  Thermonuclear   Solar Energy from the Sun / |
Energy (the SUN)           &#92;  &#92;     &#92;  /  /  |
Red Rock Energy             &#92;  &#92;     /   /   |
Duane C. Johnson   Designer  &#92;  &#92;  /  &#92; /    |
1825 Florence St  Heliostat,Control,& Mounts |
White Bear Lake, Minnesota    === &#92;   / &#92;    |
USA      55110-3364                ===   &#92;   |
(651)426-4766        use Courier New Font &#92;  |
redrok@...     (my email: address)  &#92; |
http://www.redrok.com  (Web site)          ===
No worries
I haven't found anything else so far, but I've come to realise that there are many good things on the internet that aren't easy to find as they're not in English :(
> tda7000,
> Thanks.
> Wayne
> > > Wayne
> > > >   - Robin
Ebay seems cheap: http://www.ebay.com/itm/200-x-SMD-SMT-0603-Super-bright-UV-Purple-LED-/110611085621
I got some 5mm UV LEDs from Chris on here, he originally got them from eBay and the listing says 395~400nm.
They work well with the cheap negative-acting resist I bought from a Chinese eBayer also.
I'm not sure what the exact wavelength you're supposed to use but I would assume most any LED rated UV would work.
> Duane
>    Powered by             \  \     \        //|
> Energy (the SUN)           \  \     \  /  /  |
> Red Rock Energy             \  \     /   /   |
> Duane C. Johnson   Designer  \  \  /  \ /    |
> White Bear Lake, Minnesota    === \   / \    |
> USA      55110-3364                ===   \   |
> (651)426-4766        use Courier New Font \  |
> redrok@...     (my email: address)  \ |
Riston MM540 from Czech Republic and UV wavelengths
In "Re: das-labor.org UV scanner direct exposure of photoresist", Duane
There are multiple types of DuPont Riston, and I guess many other
non-DuPont negative photoresist films with the same or similar
characteristics.
I recently bought some Riston from Martin Dusek in the Czech Republic:
*  http://myworld.ebay.com/gaminn/
*  http://www.tech-place.com/content/4-about-us
I bought this item, but via his eBay store:
*  http://www.tech-place.com/pyralux/23-photosensitive-film.html
It is sold as 20 A5 sheets, but it is actually a single roll 318 x 2000
mm.  I wrote about modifying a cheap laminator to laminate it successfully:
*  http://tech.groups.yahoo.com/group/Homebrew_PCBs/message/30148
The datasheet is:
http://www2.dupont.com/Imaging_Materials/en_US/assets/downloads/datasheets/mm500series.pdf
This states that the "peak response" of the material is 350nm
(nanometre) to 380nm.  This is the same as in the other Riston
datasheets I looked at, but I did not look at them all.  The shorter the
wavelength of light, the more energy per electron is coupled, so 350nm
light is more energetic than 380nm.
According to:
*  http://en.wikipedia.org/wiki/Ultraviolet
this is in the "Near UV" (NUV) range.  A quick look at:
*  http://en.wikipedia.org/wiki/Black_light
indicates that fluorescent "black light" tubes emit energy in or near
the 350 to 380nm range.  A quick look at:
* http://en.wikipedia.org/wiki/Light-emitting_diode
indicates that there are NUV "black light" LEDs which emit in the 375 to
395nm range.  "365nm" is mentioned as one such wavelength.
Googling:
*  LED "365nm"
finds many LEDs.  SMT may be harder to get, such as:
*  http://www.osa-opto.com/uv_light.html
There are more hits searching for:
*  LED NUV SMT
*  LED NUV SMD
 - Robin
(Asterisks added to thwart Yahoo Groups web archive's gobbling of
leading spaces.)
